Wine Font Optimization. Issue with letter spacing
So as you can see from this picture below, notice how the font spacing isn’t optimized and covers up important information.
Does anyone know how I can fix this?
Looks like it’s falling back to a mono space font.
You probably need to install the Microsoft ttf packs through winetricks. At least, that’s my first guess. If you look on winehq you might be able to see what others have done.
I was looking to manually change the fonts or lower the DPI through regedit or something, anything. Couldn’t figure it out so I moved on for the time being, messed around with some stuff, broke my OS, reinstalled and just started over from scratch and after starting clean my program is working perfect from the start! This is wonderful because this software had me keep a windows drive around but now I’m not sure I need one.
Did you fix it? If yes, how?
You can try adjusting the winecfg dpi setting, I often use 110 which helps application font.
