Windows offset on second monitor
Hello!
I didn't know, how to google it and didn't see anyone posting something like this here before.
I have a problem. I have 2 monitors (main is 1080p and second is 768p). When I'm running a full screen program on main monitor and have other than native resolution on it, then it offsets all the windows on secondary monitor.
It looks like something like this:
On second monitor Firefox is offset even if it's maximized.
Maybe those specs are needed:
OS: Windows 7 Home
GPU: GTX 950
I feel your pain, I have a similar set-up myself, usually Alt-Tab twice does the trick, if not try running the game in Windowed Borderless, lemme know if that helps!
Nope, that doesn't seem to work for me.
