Is there a utility out there that can monitor a specific running program and tell me what DLL’s and / or support files on Win 10 that software touches when running?
Need it for some fault finding. Cheers.
See also procmon for monitoring system calls. eg: if you want to see what directories are accessed, and what files the process reads and writes to. and much more
fault finding
sometimes there are hints in the built in Event Viewer Logs
