I am using the recent Debian stable release.
Kernel Version
input:
uname -r
output:
5.10.0-13-amd64
Virtual Machine Manager
v3.2.0
Virsh Version
library and default hypervisor version
input:
virsh --version
output:
7.0.0
libvirt daemon version
input:
libvirtd --version
output:
bash: libvirtd: Kommando nicht gefunden.
qemu version
input:
/usr/bin/qemu-system-x86_64 --version
output:
QEMU emulator version 5.2.0 (Debian 1:5.2+dfsg-11+deb11u1)
Copyright (c) 2003-2020 Fabrice Bellard and the QEMU Project developers
kvm version
input:
kvm --version
output:
looking glass B5.0.1
scream 3.9
virtio-win10-prewhql-0.1-161
Windows Version should be:
Win10_21H2_English International x64
But I can’t check because it won’t start.
GPU driver
radeon-software-adrenalin-2020-21.10.2-win10-win11-64bit-oct25.exe
I think there is something wrong with the VM / Debian because it even crashes when just starting the VM and letting it run at the UEFI shell with a spice VGA adapter not even starting looking glass or scream.
What kind of logs / dumps would be helpful should I write a bug report?
Would it help getting a newer version of virtmanager and libvirt from the backports?
A really weird thing that is happening is that I get an access denied in the UEFI shell when trying to edit fs0:\efi\boot\startup.nsh
It seems that I can’t unbind the NVME SSD anymore without crashing the system.
Any ideas how to solve that problem?
Maybe a part of the kern.log file is useful to identify the problem see end of post.
I looked at the mounted partitions and the NVME SSD that I want to pass through is not mounted, but it is in the GRUB menu could that be the culprit?
Could it be some Debian update or a DOS?
kern.log excerpt 1:
Apr 7 04:59:09 Computer kernel: [ 1601.964942] [drm:amdgpu_pci_remove [amdgpu]] *ERROR* Hotplug removal is not supported
Apr 7 04:59:09 Computer kernel: [ 1601.965337] amdgpu 0000:2d:00.0: amdgpu: amdgpu: finishing device.
Apr 7 04:59:09 Computer kernel: [ 1601.965872] ------------[ cut here ]------------
Apr 7 04:59:09 Computer kernel: [ 1601.965873] refcount_t: underflow; use-after-free.
Apr 7 04:59:09 Computer kernel: [ 1601.965882] WARNING: CPU: 16 PID: 2792 at lib/refcount.c:28 refcount_warn_saturate+0xa6/0xf0
Apr 7 04:59:09 Computer kernel: [ 1601.965893] Modules linked in: nfnetlink rfkill edac_mce_amd snd_hda_codec_realtek kvm_amd snd_hda_codec_generic ledtrig_audio binfmt_misc ccp snd_hda_codec_hdmi rng_core kvm nls_ascii snd_hda_intel nls_cp437 snd_intel_dspcfg vfat soundwire_intel fat ghash_clmulni_intel soundwire_generic_allocation snd_soc_core aesni_intel snd_compress soundwire_cadence libaes crypto_simd snd_hda_codec cryptd glue_helper joydev snd_hda_core snd_hwdep rapl wmi_bmof soundwire_bus pcspkr efi_pstore sp5100_tco k10temp watchdog snd_pcm snd_timer snd soundcore evdev acpi_cpufreq vfio_pci vfio_virqfd vfio_iommu_type1 vfio irqbypass msr parport_pc ppdev lp parport fuse configfs efivarfs ip_tables x_tables autofs4 ext4 crc16 mbcache jbd2 raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx xor raid6_pq libcrc32c crc32c_generic raid1 raid0 multipath linear md_mod amdgpu hid_generic radeon usbhid hid gpu_sched i2c_algo_bit ttm drm_kms_helper ahci cec libahci xhci_pci xhci_hcd r8169 libata realtek
Apr 7 04:59:09 Computer kernel: [ 1601.965962] nvme crc32_pclmul mdio_devres usbcore drm crc32c_intel scsi_mod nvme_core libphy i2c_piix4 t10_pi crc_t10dif usb_common crct10dif_generic crct10dif_pclmul crct10dif_common wmi button
Apr 7 04:59:09 Computer kernel: [ 1601.965988] CPU: 16 PID: 2792 Comm: bash Not tainted 5.10.0-13-amd64 #1 Debian 5.10.106-1
Apr 7 04:59:09 Computer kernel: [ 1601.965990] Hardware name: Micro-Star International Co., Ltd. MS-7C37/X570-A PRO (MS-7C37), BIOS H.A0 09/07/2020
Apr 7 04:59:09 Computer kernel: [ 1601.965992] RIP: 0010:refcount_warn_saturate+0xa6/0xf0
Apr 7 04:59:09 Computer kernel: [ 1601.965994] Code: 05 24 26 3e 01 01 e8 28 00 42 00 0f 0b c3 80 3d 12 26 3e 01 00 75 95 48 c7 c7 a0 07 b2 b5 c6 05 02 26 3e 01 01 e8 09 00 42 00 <0f> 0b c3 80 3d f1 25 3e 01 00 0f 85 72 ff ff ff 48 c7 c7 f8 07 b2
Apr 7 04:59:09 Computer kernel: [ 1601.965996] RSP: 0018:ffffa993823a3d10 EFLAGS: 00010282
Apr 7 04:59:09 Computer kernel: [ 1601.965998] RAX: 0000000000000000 RBX: 0000000000000001 RCX: ffff92203ee1ca08
Apr 7 04:59:09 Computer kernel: [ 1601.965999] RDX: 00000000ffffffd8 RSI: 0000000000000027 RDI: ffff92203ee1ca00
Apr 7 04:59:09 Computer kernel: [ 1601.966000] RBP: ffff9201d2126800 R08: 0000000000000000 R09: ffffa993823a3b30
Apr 7 04:59:09 Computer kernel: [ 1601.966001] R10: ffffa993823a3b28 R11: ffff9220bf26bfe8 R12: ffff9201a3e80000
Apr 7 04:59:09 Computer kernel: [ 1601.966002] R13: 00000000ffffffff R14: ffff92018114a180 R15: ffff92018114a1a0
Apr 7 04:59:09 Computer kernel: [ 1601.966004] FS: 00007f2e728be740(0000) GS:ffff92203ee00000(0000) knlGS:0000000000000000
Apr 7 04:59:09 Computer kernel: [ 1601.966005] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Apr 7 04:59:09 Computer kernel: [ 1601.966006] CR2: 0000564549129454 CR3: 0000000108ea6000 CR4: 0000000000750ee0
Apr 7 04:59:09 Computer kernel: [ 1601.966007] PKRU: 55555554
Apr 7 04:59:09 Computer kernel: [ 1601.966008] Call Trace:
Apr 7 04:59:09 Computer kernel: [ 1601.966091] amdgpu_fbdev_fini+0xa2/0x110 [amdgpu]
Apr 7 04:59:09 Computer kernel: [ 1601.966178] amdgpu_device_fini+0xb1/0x4a6 [amdgpu]
Apr 7 04:59:09 Computer kernel: [ 1601.966235] amdgpu_pci_remove+0x36/0x50 [amdgpu]
Apr 7 04:59:09 Computer kernel: [ 1601.966239] pci_device_remove+0x3b/0xa0
Apr 7 04:59:09 Computer kernel: [ 1601.966242] __device_release_driver+0x17a/0x250
Apr 7 04:59:09 Computer kernel: [ 1601.966245] device_driver_detach+0x3c/0xa0
Apr 7 04:59:09 Computer kernel: [ 1601.966247] unbind_store+0x113/0x130
Apr 7 04:59:09 Computer kernel: [ 1601.966251] kernfs_fop_write_iter+0x124/0x1b0
Apr 7 04:59:09 Computer kernel: [ 1601.966254] new_sync_write+0x11c/0x1b0
Apr 7 04:59:09 Computer kernel: [ 1601.966256] vfs_write+0x1c2/0x260
Apr 7 04:59:09 Computer kernel: [ 1601.966258] ksys_write+0x5f/0xe0
Apr 7 04:59:09 Computer kernel: [ 1601.966262] do_syscall_64+0x33/0x80
Apr 7 04:59:09 Computer kernel: [ 1601.966264] entry_SYSCALL_64_after_hwframe+0x44/0xa9
Apr 7 04:59:09 Computer kernel: [ 1601.966266] RIP: 0033:0x7f2e729aff33
Apr 7 04:59:09 Computer kernel: [ 1601.966267] Code: 8b 15 61 ef 0c 00 f7 d8 64 89 02 48 c7 c0 ff ff ff ff eb b7 0f 1f 00 64 8b 04 25 18 00 00 00 85 c0 75 14 b8 01 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 55 c3 0f 1f 40 00 48 83 ec 28 48 89 54 24 18
Apr 7 04:59:09 Computer kernel: [ 1601.966269] RSP: 002b:00007ffdddc52498 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
Apr 7 04:59:09 Computer kernel: [ 1601.966270] RAX: ffffffffffffffda RBX: 000000000000000d RCX: 00007f2e729aff33
Apr 7 04:59:09 Computer kernel: [ 1601.966271] RDX: 000000000000000d RSI: 0000564549129450 RDI: 0000000000000001
Apr 7 04:59:09 Computer kernel: [ 1601.966272] RBP: 0000564549129450 R08: 000000000000000a R09: 000000000000000c
Apr 7 04:59:09 Computer kernel: [ 1601.966273] R10: 0000564549127110 R11: 0000000000000246 R12: 000000000000000d
Apr 7 04:59:09 Computer kernel: [ 1601.966274] R13: 00007f2e72a806a0 R14: 000000000000000d R15: 00007f2e72a808a0
Apr 7 04:59:09 Computer kernel: [ 1601.966276] ---[ end trace 293babf27b0823b6 ]---
Apr 7 04:59:09 Computer kernel: [ 1602.253545] ------------[ cut here ]------------
Apr 7 04:59:09 Computer kernel: [ 1602.253546] Still active user space clients!
Apr 7 04:59:09 Computer kernel: [ 1602.253590] WARNING: CPU: 16 PID: 2792 at drivers/gpu/drm/amd/amdgpu/amdgpu_gem.c:91 amdgpu_gem_force_release+0x142/0x150 [amdgpu]
Apr 7 04:59:09 Computer kernel: [ 1602.253590] Modules linked in: nfnetlink rfkill edac_mce_amd snd_hda_codec_realtek kvm_amd snd_hda_codec_generic ledtrig_audio binfmt_misc ccp snd_hda_codec_hdmi rng_core kvm nls_ascii snd_hda_intel nls_cp437 snd_intel_dspcfg vfat soundwire_intel fat ghash_clmulni_intel soundwire_generic_allocation snd_soc_core aesni_intel snd_compress soundwire_cadence libaes crypto_simd snd_hda_codec cryptd glue_helper joydev snd_hda_core snd_hwdep rapl wmi_bmof soundwire_bus pcspkr efi_pstore sp5100_tco k10temp watchdog snd_pcm snd_timer snd soundcore evdev acpi_cpufreq vfio_pci vfio_virqfd vfio_iommu_type1 vfio irqbypass msr parport_pc ppdev lp parport fuse configfs efivarfs ip_tables x_tables autofs4 ext4 crc16 mbcache jbd2 raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx xor raid6_pq libcrc32c crc32c_generic raid1 raid0 multipath linear md_mod amdgpu hid_generic radeon usbhid hid gpu_sched i2c_algo_bit ttm drm_kms_helper ahci cec libahci xhci_pci xhci_hcd r8169 libata realtek
Apr 7 04:59:09 Computer kernel: [ 1602.253611] nvme crc32_pclmul mdio_devres usbcore drm crc32c_intel scsi_mod nvme_core libphy i2c_piix4 t10_pi crc_t10dif usb_common crct10dif_generic crct10dif_pclmul crct10dif_common wmi button
Apr 7 04:59:09 Computer kernel: [ 1602.253617] CPU: 16 PID: 2792 Comm: bash Tainted: G W 5.10.0-13-amd64 #1 Debian 5.10.106-1
Apr 7 04:59:09 Computer kernel: [ 1602.253617] Hardware name: Micro-Star International Co., Ltd. MS-7C37/X570-A PRO (MS-7C37), BIOS H.A0 09/07/2020
Apr 7 04:59:09 Computer kernel: [ 1602.253644] RIP: 0010:amdgpu_gem_force_release+0x142/0x150 [amdgpu]
Apr 7 04:59:09 Computer kernel: [ 1602.253645] Code: fb 99 de c0 c6 05 11 59 53 00 01 e8 b7 5a 8c f4 0f 0b e9 76 ff ff ff 48 c7 c7 38 0a da c0 c6 05 f8 58 53 00 01 e8 9d 5a 8c f4 <0f> 0b e9 19 ff ff ff e8 92 db 8f f4 66 90 0f 1f 44 00 00 41 57 41
Apr 7 04:59:09 Computer kernel: [ 1602.253646] RSP: 0018:ffffa993823a3ce0 EFLAGS: 00010282
Apr 7 04:59:09 Computer kernel: [ 1602.253646] RAX: 0000000000000000 RBX: 00000000ffffffff RCX: ffff92203ee1ca08
Apr 7 04:59:09 Computer kernel: [ 1602.253647] RDX: 00000000ffffffd8 RSI: 0000000000000027 RDI: ffff92203ee1ca00
Apr 7 04:59:09 Computer kernel: [ 1602.253647] RBP: ffff9201a3e80000 R08: 0000000000000000 R09: ffffa993823a3b00
Apr 7 04:59:09 Computer kernel: [ 1602.253648] R10: ffffa993823a3af8 R11: ffff9220bf26bfe8 R12: ffff920200802200
Apr 7 04:59:09 Computer kernel: [ 1602.253648] R13: ffff9201a3e96328 R14: ffff9201a3e80100 R15: ffff92018114a1a0
Apr 7 04:59:09 Computer kernel: [ 1602.253649] FS: 00007f2e728be740(0000) GS:ffff92203ee00000(0000) knlGS:0000000000000000
Apr 7 04:59:09 Computer kernel: [ 1602.253649] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Apr 7 04:59:09 Computer kernel: [ 1602.253650] CR2: 0000564549129454 CR3: 0000000108ea6000 CR4: 0000000000750ee0
Apr 7 04:59:09 Computer kernel: [ 1602.253650] PKRU: 55555554
Apr 7 04:59:09 Computer kernel: [ 1602.253651] Call Trace:
Apr 7 04:59:09 Computer kernel: [ 1602.253681] gmc_v8_0_sw_fini+0xe/0x60 [amdgpu]
Apr 7 04:59:09 Computer kernel: [ 1602.253720] amdgpu_device_fini+0x2a8/0x4a6 [amdgpu]
Apr 7 04:59:09 Computer kernel: [ 1602.253745] amdgpu_pci_remove+0x36/0x50 [amdgpu]
Apr 7 04:59:09 Computer kernel: [ 1602.253747] pci_device_remove+0x3b/0xa0
Apr 7 04:59:09 Computer kernel: [ 1602.253749] __device_release_driver+0x17a/0x250
Apr 7 04:59:09 Computer kernel: [ 1602.253750] device_driver_detach+0x3c/0xa0
Apr 7 04:59:09 Computer kernel: [ 1602.253751] unbind_store+0x113/0x130
Apr 7 04:59:09 Computer kernel: [ 1602.253752] kernfs_fop_write_iter+0x124/0x1b0
Apr 7 04:59:09 Computer kernel: [ 1602.253754] new_sync_write+0x11c/0x1b0
Apr 7 04:59:09 Computer kernel: [ 1602.253755] vfs_write+0x1c2/0x260
Apr 7 04:59:09 Computer kernel: [ 1602.253756] ksys_write+0x5f/0xe0
Apr 7 04:59:09 Computer kernel: [ 1602.253757] do_syscall_64+0x33/0x80
Apr 7 04:59:09 Computer kernel: [ 1602.253758] entry_SYSCALL_64_after_hwframe+0x44/0xa9
Apr 7 04:59:09 Computer kernel: [ 1602.253759] RIP: 0033:0x7f2e729aff33
Apr 7 04:59:09 Computer kernel: [ 1602.253760] Code: 8b 15 61 ef 0c 00 f7 d8 64 89 02 48 c7 c0 ff ff ff ff eb b7 0f 1f 00 64 8b 04 25 18 00 00 00 85 c0 75 14 b8 01 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 55 c3 0f 1f 40 00 48 83 ec 28 48 89 54 24 18
Apr 7 04:59:09 Computer kernel: [ 1602.253760] RSP: 002b:00007ffdddc52498 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
Apr 7 04:59:09 Computer kernel: [ 1602.253761] RAX: ffffffffffffffda RBX: 000000000000000d RCX: 00007f2e729aff33
Apr 7 04:59:09 Computer kernel: [ 1602.253761] RDX: 000000000000000d RSI: 0000564549129450 RDI: 0000000000000001
Apr 7 04:59:09 Computer kernel: [ 1602.253762] RBP: 0000564549129450 R08: 000000000000000a R09: 000000000000000c
Apr 7 04:59:09 Computer kernel: [ 1602.253762] R10: 0000564549127110 R11: 0000000000000246 R12: 000000000000000d
Apr 7 04:59:09 Computer kernel: [ 1602.253763] R13: 00007f2e72a806a0 R14: 000000000000000d R15: 00007f2e72a808a0
Apr 7 04:59:09 Computer kernel: [ 1602.253763] ---[ end trace 293babf27b0823b7 ]---
Apr 7 04:59:09 Computer kernel: [ 1602.253764] ------------[ cut here ]------------
Apr 7 04:59:09 Computer kernel: [ 1602.253764] And also active allocations!
Apr 7 04:59:09 Computer kernel: [ 1602.253795] WARNING: CPU: 16 PID: 2792 at drivers/gpu/drm/amd/amdgpu/amdgpu_gem.c:94 amdgpu_gem_force_release+0x128/0x150 [amdgpu]
Apr 7 04:59:09 Computer kernel: [ 1602.253795] Modules linked in: nfnetlink rfkill edac_mce_amd snd_hda_codec_realtek kvm_amd snd_hda_codec_generic ledtrig_audio binfmt_misc ccp snd_hda_codec_hdmi rng_core kvm nls_ascii snd_hda_intel nls_cp437 snd_intel_dspcfg vfat soundwire_intel fat ghash_clmulni_intel soundwire_generic_allocation snd_soc_core aesni_intel snd_compress soundwire_cadence libaes crypto_simd snd_hda_codec cryptd glue_helper joydev snd_hda_core snd_hwdep rapl wmi_bmof soundwire_bus pcspkr efi_pstore sp5100_tco k10temp watchdog snd_pcm snd_timer snd soundcore evdev acpi_cpufreq vfio_pci vfio_virqfd vfio_iommu_type1 vfio irqbypass msr parport_pc ppdev lp parport fuse configfs efivarfs ip_tables x_tables autofs4 ext4 crc16 mbcache jbd2 raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx xor raid6_pq libcrc32c crc32c_generic raid1 raid0 multipath linear md_mod amdgpu hid_generic radeon usbhid hid gpu_sched i2c_algo_bit ttm drm_kms_helper ahci cec libahci xhci_pci xhci_hcd r8169 libata realtek
Apr 7 04:59:09 Computer kernel: [ 1602.253809] nvme crc32_pclmul mdio_devres usbcore drm crc32c_intel scsi_mod nvme_core libphy i2c_piix4 t10_pi crc_t10dif usb_common crct10dif_generic crct10dif_pclmul crct10dif_common wmi button
Apr 7 04:59:09 Computer kernel: [ 1602.253813] CPU: 16 PID: 2792 Comm: bash Tainted: G W 5.10.0-13-amd64 #1 Debian 5.10.106-1
Apr 7 04:59:09 Computer kernel: [ 1602.253813] Hardware name: Micro-Star International Co., Ltd. MS-7C37/X570-A PRO (MS-7C37), BIOS H.A0 09/07/2020
Apr 7 04:59:09 Computer kernel: [ 1602.253839] RIP: 0010:amdgpu_gem_force_release+0x128/0x150 [amdgpu]
Apr 7 04:59:09 Computer kernel: [ 1602.253840] Code: 48 8b 3c 24 48 83 c4 18 5b 5d 41 5c 41 5d 41 5e 41 5f e9 6b 82 90 f4 48 c7 c7 fb 99 de c0 c6 05 11 59 53 00 01 e8 b7 5a 8c f4 <0f> 0b e9 76 ff ff ff 48 c7 c7 38 0a da c0 c6 05 f8 58 53 00 01 e8
Apr 7 04:59:09 Computer kernel: [ 1602.253840] RSP: 0018:ffffa993823a3ce0 EFLAGS: 00010282
Apr 7 04:59:09 Computer kernel: [ 1602.253841] RAX: 0000000000000000 RBX: 00000000ffffffff RCX: ffff92203ee1ca08
Apr 7 04:59:09 Computer kernel: [ 1602.253841] RDX: 00000000ffffffd8 RSI: 0000000000000027 RDI: ffff92203ee1ca00
Apr 7 04:59:09 Computer kernel: [ 1602.253842] RBP: ffff920200802240 R08: 0000000000000000 R09: ffffa993823a3b00
Apr 7 04:59:09 Computer kernel: [ 1602.253842] R10: ffffa993823a3af8 R11: ffff9220bf26bfe8 R12: ffff920200802200
Apr 7 04:59:09 Computer kernel: [ 1602.253842] R13: ffff920200802258 R14: ffff9201a3e80100 R15: ffff9201d0065458
Apr 7 04:59:09 Computer kernel: [ 1602.253843] FS: 00007f2e728be740(0000) GS:ffff92203ee00000(0000) knlGS:0000000000000000
Apr 7 04:59:09 Computer kernel: [ 1602.253844] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Apr 7 04:59:09 Computer kernel: [ 1602.253844] CR2: 0000564549129454 CR3: 0000000108ea6000 CR4: 0000000000750ee0
Apr 7 04:59:09 Computer kernel: [ 1602.253844] PKRU: 55555554
Apr 7 04:59:09 Computer kernel: [ 1602.253845] Call Trace:
Apr 7 04:59:09 Computer kernel: [ 1602.253873] gmc_v8_0_sw_fini+0xe/0x60 [amdgpu]
Apr 7 04:59:09 Computer kernel: [ 1602.253913] amdgpu_device_fini+0x2a8/0x4a6 [amdgpu]
Apr 7 04:59:09 Computer kernel: [ 1602.253941] amdgpu_pci_remove+0x36/0x50 [amdgpu]
Apr 7 04:59:09 Computer kernel: [ 1602.253943] pci_device_remove+0x3b/0xa0
Apr 7 04:59:09 Computer kernel: [ 1602.253944] __device_release_driver+0x17a/0x250
Apr 7 04:59:09 Computer kernel: [ 1602.253944] device_driver_detach+0x3c/0xa0
Apr 7 04:59:09 Computer kernel: [ 1602.253945] unbind_store+0x113/0x130
Apr 7 04:59:09 Computer kernel: [ 1602.253946] kernfs_fop_write_iter+0x124/0x1b0
Apr 7 04:59:09 Computer kernel: [ 1602.253947] new_sync_write+0x11c/0x1b0
Apr 7 04:59:09 Computer kernel: [ 1602.253948] vfs_write+0x1c2/0x260
Apr 7 04:59:09 Computer kernel: [ 1602.253948] ksys_write+0x5f/0xe0
Apr 7 04:59:09 Computer kernel: [ 1602.253949] do_syscall_64+0x33/0x80
Apr 7 04:59:09 Computer kernel: [ 1602.253950] entry_SYSCALL_64_after_hwframe+0x44/0xa9
Apr 7 04:59:09 Computer kernel: [ 1602.253950] RIP: 0033:0x7f2e729aff33
Apr 7 04:59:09 Computer kernel: [ 1602.253951] Code: 8b 15 61 ef 0c 00 f7 d8 64 89 02 48 c7 c0 ff ff ff ff eb b7 0f 1f 00 64 8b 04 25 18 00 00 00 85 c0 75 14 b8 01 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 55 c3 0f 1f 40 00 48 83 ec 28 48 89 54 24 18
Apr 7 04:59:09 Computer kernel: [ 1602.253952] RSP: 002b:00007ffdddc52498 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
Apr 7 04:59:09 Computer kernel: [ 1602.253952] RAX: ffffffffffffffda RBX: 000000000000000d RCX: 00007f2e729aff33
Apr 7 04:59:09 Computer kernel: [ 1602.253953] RDX: 000000000000000d RSI: 0000564549129450 RDI: 0000000000000001
Apr 7 04:59:09 Computer kernel: [ 1602.253953] RBP: 0000564549129450 R08: 000000000000000a R09: 000000000000000c
Apr 7 04:59:09 Computer kernel: [ 1602.253953] R10: 0000564549127110 R11: 0000000000000246 R12: 000000000000000d
Apr 7 04:59:09 Computer kernel: [ 1602.253954] R13: 00007f2e72a806a0 R14: 000000000000000d R15: 00007f2e72a808a0
Apr 7 04:59:09 Computer kernel: [ 1602.253955] ---[ end trace 293babf27b0823b8 ]---
Apr 7 04:59:09 Computer kernel: [ 1602.253964] ------------[ cut here ]------------
Apr 7 04:59:09 Computer kernel: [ 1602.253990] WARNING: CPU: 16 PID: 2792 at drivers/gpu/drm/amd/amdgpu/amdgpu_vm.c:3227 amdgpu_vm_manager_fini+0x1e/0x50 [amdgpu]
Apr 7 04:59:09 Computer kernel: [ 1602.253991] Modules linked in: nfnetlink rfkill edac_mce_amd snd_hda_codec_realtek kvm_amd snd_hda_codec_generic ledtrig_audio binfmt_misc ccp snd_hda_codec_hdmi rng_core kvm nls_ascii snd_hda_intel nls_cp437 snd_intel_dspcfg vfat soundwire_intel fat ghash_clmulni_intel soundwire_generic_allocation snd_soc_core aesni_intel snd_compress soundwire_cadence libaes crypto_simd snd_hda_codec cryptd glue_helper joydev snd_hda_core snd_hwdep rapl wmi_bmof soundwire_bus pcspkr efi_pstore sp5100_tco k10temp watchdog snd_pcm snd_timer snd soundcore evdev acpi_cpufreq vfio_pci vfio_virqfd vfio_iommu_type1 vfio irqbypass msr parport_pc ppdev lp parport fuse configfs efivarfs ip_tables x_tables autofs4 ext4 crc16 mbcache jbd2 raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx xor raid6_pq libcrc32c crc32c_generic raid1 raid0 multipath linear md_mod amdgpu hid_generic radeon usbhid hid gpu_sched i2c_algo_bit ttm drm_kms_helper ahci cec libahci xhci_pci xhci_hcd r8169 libata realtek
Apr 7 04:59:09 Computer kernel: [ 1602.254005] nvme crc32_pclmul mdio_devres usbcore drm crc32c_intel scsi_mod nvme_core libphy i2c_piix4 t10_pi crc_t10dif usb_common crct10dif_generic crct10dif_pclmul crct10dif_common wmi button
Apr 7 04:59:09 Computer kernel: [ 1602.254008] CPU: 16 PID: 2792 Comm: bash Tainted: G W 5.10.0-13-amd64 #1 Debian 5.10.106-1
Apr 7 04:59:09 Computer kernel: [ 1602.254008] Hardware name: Micro-Star International Co., Ltd. MS-7C37/X570-A PRO (MS-7C37), BIOS H.A0 09/07/2020
Apr 7 04:59:09 Computer kernel: [ 1602.254035] RIP: 0010:amdgpu_vm_manager_fini+0x1e/0x50 [amdgpu]
Apr 7 04:59:09 Computer kernel: [ 1602.254035] Code: 66 2e 0f 1f 84 00 00 00 00 00 66 90 0f 1f 44 00 00 55 48 89 fd 48 81 c7 d0 54 00 00 48 83 ec 08 48 83 bd d8 54 00 00 00 74 14 <0f> 0b e8 fb 42 4f f4 48 89 ef 48 83 c4 08 5d e9 7e aa 00 00 31 f6
Apr 7 04:59:09 Computer kernel: [ 1602.254036] RSP: 0018:ffffa993823a3d18 EFLAGS: 00010282
Apr 7 04:59:09 Computer kernel: [ 1602.254036] RAX: ffff92018b7d0000 RBX: ffff9201a3e80000 RCX: 0000000000000000
Apr 7 04:59:09 Computer kernel: [ 1602.254037] RDX: ffff92018b7d0000 RSI: ffff9202012276d8 RDI: ffff9201a3e854d0
Apr 7 04:59:09 Computer kernel: [ 1602.254037] RBP: ffff9201a3e80000 R08: 0000000000000000 R09: 0000000000000000
Apr 7 04:59:09 Computer kernel: [ 1602.254037] R10: 0000000000000000 R11: ffff920200802240 R12: 0000000000000001
Apr 7 04:59:09 Computer kernel: [ 1602.254038] R13: ffff9201a3e96328 R14: ffff92018114a180 R15: ffff92018114a1a0
Apr 7 04:59:09 Computer kernel: [ 1602.254038] FS: 00007f2e728be740(0000) GS:ffff92203ee00000(0000) knlGS:0000000000000000
Apr 7 04:59:09 Computer kernel: [ 1602.254039] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Apr 7 04:59:09 Computer kernel: [ 1602.254039] CR2: 0000564549129454 CR3: 0000000108ea6000 CR4: 0000000000750ee0
Apr 7 04:59:09 Computer kernel: [ 1602.254040] PKRU: 55555554
Apr 7 04:59:09 Computer kernel: [ 1602.254040] Call Trace:
Apr 7 04:59:09 Computer kernel: [ 1602.254069] gmc_v8_0_sw_fini+0x16/0x60 [amdgpu]
Apr 7 04:59:09 Computer kernel: [ 1602.254105] amdgpu_device_fini+0x2a8/0x4a6 [amdgpu]
Apr 7 04:59:09 Computer kernel: [ 1602.254131] amdgpu_pci_remove+0x36/0x50 [amdgpu]
Apr 7 04:59:09 Computer kernel: [ 1602.254132] pci_device_remove+0x3b/0xa0
Apr 7 04:59:09 Computer kernel: [ 1602.254133] __device_release_driver+0x17a/0x250
Apr 7 04:59:09 Computer kernel: [ 1602.254134] device_driver_detach+0x3c/0xa0
Apr 7 04:59:09 Computer kernel: [ 1602.254135] unbind_store+0x113/0x130
Apr 7 04:59:09 Computer kernel: [ 1602.254136] kernfs_fop_write_iter+0x124/0x1b0
Apr 7 04:59:09 Computer kernel: [ 1602.254137] new_sync_write+0x11c/0x1b0
Apr 7 04:59:09 Computer kernel: [ 1602.254137] vfs_write+0x1c2/0x260
Apr 7 04:59:09 Computer kernel: [ 1602.254138] ksys_write+0x5f/0xe0
Apr 7 04:59:09 Computer kernel: [ 1602.254139] do_syscall_64+0x33/0x80
Apr 7 04:59:09 Computer kernel: [ 1602.254139] entry_SYSCALL_64_after_hwframe+0x44/0xa9
Apr 7 04:59:09 Computer kernel: [ 1602.254140] RIP: 0033:0x7f2e729aff33
Apr 7 04:59:09 Computer kernel: [ 1602.254141] Code: 8b 15 61 ef 0c 00 f7 d8 64 89 02 48 c7 c0 ff ff ff ff eb b7 0f 1f 00 64 8b 04 25 18 00 00 00 85 c0 75 14 b8 01 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 55 c3 0f 1f 40 00 48 83 ec 28 48 89 54 24 18
Apr 7 04:59:09 Computer kernel: [ 1602.254141] RSP: 002b:00007ffdddc52498 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
Apr 7 04:59:09 Computer kernel: [ 1602.254142] RAX: ffffffffffffffda RBX: 000000000000000d RCX: 00007f2e729aff33
Apr 7 04:59:09 Computer kernel: [ 1602.254142] RDX: 000000000000000d RSI: 0000564549129450 RDI: 0000000000000001
Apr 7 04:59:09 Computer kernel: [ 1602.254142] RBP: 0000564549129450 R08: 000000000000000a R09: 000000000000000c
Apr 7 04:59:09 Computer kernel: [ 1602.254143] R10: 0000564549127110 R11: 0000000000000246 R12: 000000000000000d
Apr 7 04:59:09 Computer kernel: [ 1602.254143] R13: 00007f2e72a806a0 R14: 000000000000000d R15: 00007f2e72a808a0
Apr 7 04:59:09 Computer kernel: [ 1602.254144] ---[ end trace 293babf27b0823b9 ]---
Apr 7 04:59:09 Computer kernel: [ 1602.407864] amdgpu: Move buffer fallback to memcpy unavailable
Apr 7 04:59:09 Computer kernel: [ 1602.407866] [TTM] Buffer eviction failed
Apr 7 04:59:09 Computer kernel: [ 1602.407877] [drm] amdgpu: ttm finalized
Apr 7 04:59:09 Computer kernel: [ 1602.408003] vfio-pci 0000:2d:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=io+mem:owns=none
Apr 7 04:59:25 Computer kernel: [ 1617.806038] vfio-pci 0000:01:00.0: vfio_ecap_init: hiding ecap 0x19@0x300
Apr 7 04:59:25 Computer kernel: [ 1617.806042] vfio-pci 0000:01:00.0: vfio_ecap_init: hiding ecap 0x1e@0x900
Apr 7 04:59:25 Computer kernel: [ 1617.806043] vfio-pci 0000:01:00.0: vfio_ecap_init: hiding ecap 0x25@0x910
Apr 7 04:59:25 Computer kernel: [ 1617.806045] vfio-pci 0000:01:00.0: vfio_ecap_init: hiding ecap 0x27@0x920
Apr 7 04:59:25 Computer kernel: [ 1617.806046] vfio-pci 0000:01:00.0: vfio_ecap_init: hiding ecap 0x26@0x9c0
Apr 7 04:59:25 Computer kernel: [ 1617.826285] vfio-pci 0000:2d:00.0: vfio_ecap_init: hiding ecap 0x19@0x270
Apr 7 04:59:25 Computer kernel: [ 1617.826297] vfio-pci 0000:2d:00.0: vfio_ecap_init: hiding ecap 0x1b@0x2d0
Apr 7 04:59:25 Computer kernel: [ 1617.826305] vfio-pci 0000:2d:00.0: vfio_ecap_init: hiding ecap 0x1e@0x370
Apr 7 04:59:25 Computer kernel: [ 1617.845895] vfio-pci 0000:2d:00.1: enabling device (0000 -> 0002)
Apr 7 05:00:33 Computer kernel: [ 1685.475293] general protection fault, probably for non-canonical address 0xfd79183e12d8e4d7: 0000 [#1] SMP NOPTI
Apr 7 05:00:33 Computer kernel: [ 1685.475299] CPU: 17 PID: 1740 Comm: kwin_x11 Tainted: G W 5.10.0-13-amd64 #1 Debian 5.10.106-1
Apr 7 05:00:33 Computer kernel: [ 1685.475301] Hardware name: Micro-Star International Co., Ltd. MS-7C37/X570-A PRO (MS-7C37), BIOS H.A0 09/07/2020
Apr 7 05:00:33 Computer kernel: [ 1685.475306] RIP: 0010:kmem_cache_alloc_trace+0x8f/0x200
Apr 7 05:00:33 Computer kernel: [ 1685.475308] Code: 27 38 4b 49 8b 00 49 83 78 10 00 48 89 04 24 0f 84 48 01 00 00 48 85 c0 0f 84 3f 01 00 00 41 8b 4c 24 28 49 8b 3c 24 48 01 c1 <48> 8b 19 48 89 ce 49 33 9c 24 b8 00 00 00 48 8d 4a 01 48 0f ce 48
Apr 7 05:00:33 Computer kernel: [ 1685.475309] RSP: 0018:ffffa993816fbc38 EFLAGS: 00010286
Apr 7 05:00:33 Computer kernel: [ 1685.475311] RAX: fd79183e12d8e2d7 RBX: ffff920230b54000 RCX: fd79183e12d8e4d7
Apr 7 05:00:33 Computer kernel: [ 1685.475312] RDX: 0000000000000e03 RSI: 0000000000000dc0 RDI: 00000000000330c0
Apr 7 05:00:33 Computer kernel: [ 1685.475313] RBP: ffff920180043500 R08: ffff92203ee730c0 R09: 0000000000000014
Apr 7 05:00:33 Computer kernel: [ 1685.475314] R10: 0000000000000000 R11: 0000000000000000 R12: ffff920180043500
Apr 7 05:00:33 Computer kernel: [ 1685.475315] R13: 0000000000000370 R14: ffffffffc0827f0a R15: 0000000000000dc0
Apr 7 05:00:33 Computer kernel: [ 1685.475317] FS: 00007f5b2f7b98c0(0000) GS:ffff92203ee40000(0000) knlGS:0000000000000000
Apr 7 05:00:33 Computer kernel: [ 1685.475318] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Apr 7 05:00:33 Computer kernel: [ 1685.475319] CR2: 00007f5a66685000 CR3: 0000000116a0c000 CR4: 0000000000750ee0
Apr 7 05:00:33 Computer kernel: [ 1685.475320] PKRU: 55555554
Apr 7 05:00:33 Computer kernel: [ 1685.475321] Call Trace:
Apr 7 05:00:33 Computer kernel: [ 1685.475340] radeon_bo_create+0x9a/0x200 [radeon]
Apr 7 05:00:33 Computer kernel: [ 1685.475356] ? radeon_gem_pwrite_ioctl+0x20/0x20 [radeon]
Apr 7 05:00:33 Computer kernel: [ 1685.475369] radeon_gem_object_create+0xb0/0x1a0 [radeon]
Apr 7 05:00:33 Computer kernel: [ 1685.475382] ? radeon_gem_pwrite_ioctl+0x20/0x20 [radeon]
Apr 7 05:00:33 Computer kernel: [ 1685.475393] radeon_gem_create_ioctl+0x66/0x120 [radeon]
Apr 7 05:00:33 Computer kernel: [ 1685.475396] ? tomoyo_path_number_perm+0x66/0x1d0
Apr 7 05:00:33 Computer kernel: [ 1685.475408] ? radeon_gem_pwrite_ioctl+0x20/0x20 [radeon]
Apr 7 05:00:33 Computer kernel: [ 1685.475420] drm_ioctl_kernel+0xaa/0xf0 [drm]
Apr 7 05:00:33 Computer kernel: [ 1685.475432] drm_ioctl+0x220/0x3c0 [drm]
Apr 7 05:00:33 Computer kernel: [ 1685.475445] ? radeon_gem_pwrite_ioctl+0x20/0x20 [radeon]
Apr 7 05:00:33 Computer kernel: [ 1685.475456] radeon_drm_ioctl+0x49/0x80 [radeon]
Apr 7 05:00:33 Computer kernel: [ 1685.475460] __x64_sys_ioctl+0x83/0xb0
Apr 7 05:00:33 Computer kernel: [ 1685.475463] do_syscall_64+0x33/0x80
Apr 7 05:00:33 Computer kernel: [ 1685.475466] entry_SYSCALL_64_after_hwframe+0x44/0xa9
Apr 7 05:00:33 Computer kernel: [ 1685.475468] RIP: 0033:0x7f5b35380cc7
Apr 7 05:00:33 Computer kernel: [ 1685.475469] Code: 00 00 00 48 8b 05 c9 91 0c 00 64 c7 00 26 00 00 00 48 c7 c0 ff ff ff ff c3 66 2e 0f 1f 84 00 00 00 00 00 b8 10 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 99 91 0c 00 f7 d8 64 89 01 48
Apr 7 05:00:33 Computer kernel: [ 1685.475471] RSP: 002b:00007ffcea4d6728 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
Apr 7 05:00:33 Computer kernel: [ 1685.475472] RAX: ffffffffffffffda RBX: 00007ffcea4d67a0 RCX: 00007f5b35380cc7
Apr 7 05:00:33 Computer kernel: [ 1685.475473] RDX: 00007ffcea4d67a0 RSI: 00000000c020645d RDI: 000000000000000c
Apr 7 05:00:33 Computer kernel: [ 1685.475474] RBP: 00000000c020645d R08: 0000000000000013 R09: 0000000000000000
Apr 7 05:00:33 Computer kernel: [ 1685.475475] R10: 00007ffcea5be080 R11: 0000000000000246 R12: 0000000000002000
Apr 7 05:00:33 Computer kernel: [ 1685.475476] R13: 000000000000000c R14: 000000000003c000 R15: 0000000000000000
Apr 7 05:00:33 Computer kernel: [ 1685.475478] Modules linked in: nfnetlink rfkill edac_mce_amd snd_hda_codec_realtek kvm_amd snd_hda_codec_generic ledtrig_audio binfmt_misc ccp snd_hda_codec_hdmi rng_core kvm nls_ascii snd_hda_intel nls_cp437 snd_intel_dspcfg vfat soundwire_intel fat ghash_clmulni_intel soundwire_generic_allocation snd_soc_core aesni_intel snd_compress soundwire_cadence libaes crypto_simd snd_hda_codec cryptd glue_helper joydev snd_hda_core snd_hwdep rapl wmi_bmof soundwire_bus pcspkr efi_pstore sp5100_tco k10temp watchdog snd_pcm snd_timer snd soundcore evdev acpi_cpufreq vfio_pci vfio_virqfd vfio_iommu_type1 vfio irqbypass msr parport_pc ppdev lp parport fuse configfs efivarfs ip_tables x_tables autofs4 ext4 crc16 mbcache jbd2 raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx xor raid6_pq libcrc32c crc32c_generic raid1 raid0 multipath linear md_mod amdgpu hid_generic radeon usbhid hid gpu_sched i2c_algo_bit ttm drm_kms_helper ahci cec libahci xhci_pci xhci_hcd r8169 libata realtek
Apr 7 05:00:33 Computer kernel: [ 1685.475527] nvme crc32_pclmul mdio_devres usbcore drm crc32c_intel scsi_mod nvme_core libphy i2c_piix4 t10_pi crc_t10dif usb_common crct10dif_generic crct10dif_pclmul crct10dif_common wmi button
Apr 7 05:00:33 Computer kernel: [ 1685.475539] ---[ end trace 293babf27b0823ba ]---
Apr 7 05:00:33 Computer kernel: [ 1685.641994] RIP: 0010:kmem_cache_alloc_trace+0x8f/0x200
Apr 7 05:00:33 Computer kernel: [ 1685.641996] Code: 27 38 4b 49 8b 00 49 83 78 10 00 48 89 04 24 0f 84 48 01 00 00 48 85 c0 0f 84 3f 01 00 00 41 8b 4c 24 28 49 8b 3c 24 48 01 c1 <48> 8b 19 48 89 ce 49 33 9c 24 b8 00 00 00 48 8d 4a 01 48 0f ce 48
Apr 7 05:00:33 Computer kernel: [ 1685.641996] RSP: 0018:ffffa993816fbc38 EFLAGS: 00010286
Apr 7 05:00:33 Computer kernel: [ 1685.641997] RAX: fd79183e12d8e2d7 RBX: ffff920230b54000 RCX: fd79183e12d8e4d7
Apr 7 05:00:33 Computer kernel: [ 1685.641998] RDX: 0000000000000e03 RSI: 0000000000000dc0 RDI: 00000000000330c0
Apr 7 05:00:33 Computer kernel: [ 1685.641998] RBP: ffff920180043500 R08: ffff92203ee730c0 R09: 0000000000000014
Apr 7 05:00:33 Computer kernel: [ 1685.641999] R10: 0000000000000000 R11: 0000000000000000 R12: ffff920180043500
Apr 7 05:00:33 Computer kernel: [ 1685.641999] R13: 0000000000000370 R14: ffffffffc0827f0a R15: 0000000000000dc0
Apr 7 05:00:33 Computer kernel: [ 1685.642000] FS: 00007f5b2f7b98c0(0000) GS:ffff92203ee40000(0000) knlGS:0000000000000000
Apr 7 05:00:33 Computer kernel: [ 1685.642001] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Apr 7 05:00:33 Computer kernel: [ 1685.642001] CR2: 00007f5a66685000 CR3: 0000000116a0c000 CR4: 0000000000750ee0
Apr 7 05:00:33 Computer kernel: [ 1685.642002] PKRU: 55555554
Apr 7 05:00:33 Computer kernel: [ 1685.642012] general protection fault, probably for non-canonical address 0xfd79183e12d8e4d7: 0000 [#2] SMP NOPTI
Apr 7 05:00:33 Computer kernel: [ 1685.642014] CPU: 17 PID: 265 Comm: kworker/17:1 Tainted: G D W 5.10.0-13-amd64 #1 Debian 5.10.106-1
Apr 7 05:00:33 Computer kernel: [ 1685.642014] Hardware name: Micro-Star International Co., Ltd. MS-7C37/X570-A PRO (MS-7C37), BIOS H.A0 09/07/2020
Apr 7 05:00:33 Computer kernel: [ 1685.642017] Workqueue: events efi_pstore_update_entries [efi_pstore]
Apr 7 05:00:33 Computer kernel: [ 1685.642019] RIP: 0010:kmem_cache_alloc_trace+0x8f/0x200
Apr 7 05:00:33 Computer kernel: [ 1685.642020] Code: 27 38 4b 49 8b 00 49 83 78 10 00 48 89 04 24 0f 84 48 01 00 00 48 85 c0 0f 84 3f 01 00 00 41 8b 4c 24 28 49 8b 3c 24 48 01 c1 <48> 8b 19 48 89 ce 49 33 9c 24 b8 00 00 00 48 8d 4a 01 48 0f ce 48
Apr 7 05:00:33 Computer kernel: [ 1685.642021] RSP: 0018:ffffa9938095bd80 EFLAGS: 00010286
Apr 7 05:00:33 Computer kernel: [ 1685.642022] RAX: fd79183e12d8e2d7 RBX: ffff920181294600 RCX: fd79183e12d8e4d7
Apr 7 05:00:33 Computer kernel: [ 1685.642022] RDX: 0000000000000e03 RSI: 0000000000000dc0 RDI: 00000000000330c0
Apr 7 05:00:33 Computer kernel: [ 1685.642023] RBP: ffff920180043500 R08: ffff92203ee730c0 R09: ffff9201a22ae000
Apr 7 05:00:33 Computer kernel: [ 1685.642023] R10: 0000000000000018 R11: 0000000000000018 R12: ffff920180043500
Apr 7 05:00:33 Computer kernel: [ 1685.642024] R13: 0000000000000400 R14: ffffffffb50a9ab5 R15: 0000000000000dc0
Apr 7 05:00:33 Computer kernel: [ 1685.642025] FS: 0000000000000000(0000) GS:ffff92203ee40000(0000) knlGS:0000000000000000
Apr 7 05:00:33 Computer kernel: [ 1685.642025] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Apr 7 05:00:33 Computer kernel: [ 1685.642026] CR2: 00007f5a66685000 CR3: 0000000116a0c000 CR4: 0000000000750ee0
Apr 7 05:00:33 Computer kernel: [ 1685.642026] PKRU: 55555554
Apr 7 05:00:33 Computer kernel: [ 1685.642027] Call Trace:
Apr 7 05:00:33 Computer kernel: [ 1685.642029] efivar_init+0x75/0x390
Apr 7 05:00:33 Computer kernel: [ 1685.642030] ? efi_pstore_open+0x10/0x10 [efi_pstore]
Apr 7 05:00:33 Computer kernel: [ 1685.642031] ? efi_pstore_update_entries+0x4c/0x70 [efi_pstore]
Apr 7 05:00:33 Computer kernel: [ 1685.642032] ? kmem_cache_alloc_trace+0xf5/0x200
Apr 7 05:00:33 Computer kernel: [ 1685.642033] efi_pstore_update_entries+0x23/0x70 [efi_pstore]
Apr 7 05:00:33 Computer kernel: [ 1685.642035] process_one_work+0x1b6/0x350
Apr 7 05:00:33 Computer kernel: [ 1685.642036] worker_thread+0x53/0x3e0
Apr 7 05:00:33 Computer kernel: [ 1685.642037] ? process_one_work+0x350/0x350
Apr 7 05:00:33 Computer kernel: [ 1685.642038] kthread+0x11b/0x140
Apr 7 05:00:33 Computer kernel: [ 1685.642039] ? __kthread_bind_mask+0x60/0x60
Apr 7 05:00:33 Computer kernel: [ 1685.642040] ret_from_fork+0x22/0x30
Apr 7 05:00:33 Computer kernel: [ 1685.642041] Modules linked in: nfnetlink rfkill edac_mce_amd snd_hda_codec_realtek kvm_amd snd_hda_codec_generic ledtrig_audio binfmt_misc ccp snd_hda_codec_hdmi rng_core kvm nls_ascii snd_hda_intel nls_cp437 snd_intel_dspcfg vfat soundwire_intel fat ghash_clmulni_intel soundwire_generic_allocation snd_soc_core aesni_intel snd_compress soundwire_cadence libaes crypto_simd snd_hda_codec cryptd glue_helper joydev snd_hda_core snd_hwdep rapl wmi_bmof soundwire_bus pcspkr efi_pstore sp5100_tco k10temp watchdog snd_pcm snd_timer snd soundcore evdev acpi_cpufreq vfio_pci vfio_virqfd vfio_iommu_type1 vfio irqbypass msr parport_pc ppdev lp parport fuse configfs efivarfs ip_tables x_tables autofs4 ext4 crc16 mbcache jbd2 raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx xor raid6_pq libcrc32c crc32c_generic raid1 raid0 multipath linear md_mod amdgpu hid_generic radeon usbhid hid gpu_sched i2c_algo_bit ttm drm_kms_helper ahci cec libahci xhci_pci xhci_hcd r8169 libata realtek
Apr 7 05:00:33 Computer kernel: [ 1685.642056] nvme crc32_pclmul mdio_devres usbcore drm crc32c_intel scsi_mod nvme_core libphy i2c_piix4 t10_pi crc_t10dif usb_common crct10dif_generic crct10dif_pclmul crct10dif_common wmi button
Apr 7 05:00:33 Computer kernel: [ 1685.642060] ---[ end trace 293babf27b0823bb ]---
Apr 7 05:00:33 Computer kernel: [ 1685.797759] RIP: 0010:kmem_cache_alloc_trace+0x8f/0x200
Apr 7 05:00:33 Computer kernel: [ 1685.797761] Code: 27 38 4b 49 8b 00 49 83 78 10 00 48 89 04 24 0f 84 48 01 00 00 48 85 c0 0f 84 3f 01 00 00 41 8b 4c 24 28 49 8b 3c 24 48 01 c1 <48> 8b 19 48 89 ce 49 33 9c 24 b8 00 00 00 48 8d 4a 01 48 0f ce 48
Apr 7 05:00:33 Computer kernel: [ 1685.797761] RSP: 0018:ffffa993816fbc38 EFLAGS: 00010286
Apr 7 05:00:33 Computer kernel: [ 1685.797762] RAX: fd79183e12d8e2d7 RBX: ffff920230b54000 RCX: fd79183e12d8e4d7
Apr 7 05:00:33 Computer kernel: [ 1685.797763] RDX: 0000000000000e03 RSI: 0000000000000dc0 RDI: 00000000000330c0
Apr 7 05:00:33 Computer kernel: [ 1685.797763] RBP: ffff920180043500 R08: ffff92203ee730c0 R09: 0000000000000014
Apr 7 05:00:33 Computer kernel: [ 1685.797764] R10: 0000000000000000 R11: 0000000000000000 R12: ffff920180043500
Apr 7 05:00:33 Computer kernel: [ 1685.797764] R13: 0000000000000370 R14: ffffffffc0827f0a R15: 0000000000000dc0
Apr 7 05:00:33 Computer kernel: [ 1685.797765] FS: 0000000000000000(0000) GS:ffff92203ee40000(0000) knlGS:0000000000000000
Apr 7 05:00:33 Computer kernel: [ 1685.797766] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Apr 7 05:00:33 Computer kernel: [ 1685.797766] CR2: 00007f5a66685000 CR3: 0000000116a0c000 CR4: 0000000000750ee0
Apr 7 05:00:33 Computer kernel: [ 1685.797767] PKRU: 55555554
Apr 7 05:00:34 Computer kernel: [ 1686.857570] general protection fault, probably for non-canonical address 0xfd79183e12d8e4d7: 0000 [#3] SMP NOPTI
Apr 7 05:00:34 Computer kernel: [ 1686.857576] CPU: 17 PID: 1362 Comm: Xorg:rcs0 Tainted: G D W 5.10.0-13-amd64 #1 Debian 5.10.106-1
Apr 7 05:00:34 Computer kernel: [ 1686.857577] Hardware name: Micro-Star International Co., Ltd. MS-7C37/X570-A PRO (MS-7C37), BIOS H.A0 09/07/2020
Apr 7 05:00:34 Computer kernel: [ 1686.857582] RIP: 0010:kmem_cache_alloc_trace+0x8f/0x200
Apr 7 05:00:34 Computer kernel: [ 1686.857584] Code: 27 38 4b 49 8b 00 49 83 78 10 00 48 89 04 24 0f 84 48 01 00 00 48 85 c0 0f 84 3f 01 00 00 41 8b 4c 24 28 49 8b 3c 24 48 01 c1 <48> 8b 19 48 89 ce 49 33 9c 24 b8 00 00 00 48 8d 4a 01 48 0f ce 48
Apr 7 05:00:34 Computer kernel: [ 1686.857586] RSP: 0018:ffffa993824239e0 EFLAGS: 00010286
Apr 7 05:00:34 Computer kernel: [ 1686.857588] RAX: fd79183e12d8e2d7 RBX: 0000000000000021 RCX: fd79183e12d8e4d7
Apr 7 05:00:34 Computer kernel: [ 1686.857589] RDX: 0000000000000e03 RSI: 0000000000000dc0 RDI: 00000000000330c0
Apr 7 05:00:34 Computer kernel: [ 1686.857590] RBP: ffff920180043500 R08: ffff92203ee730c0 R09: ffffa993824237cc
Apr 7 05:00:34 Computer kernel: [ 1686.857591] R10: ffff920230b54000 R11: 0006000000000002 R12: ffff920180043500
Apr 7 05:00:34 Computer kernel: [ 1686.857592] R13: 0000000000000350 R14: ffffffffc087ac64 R15: 0000000000000dc0
Apr 7 05:00:34 Computer kernel: [ 1686.857593] FS: 00007fc76077b700(0000) GS:ffff92203ee40000(0000) knlGS:0000000000000000
Apr 7 05:00:34 Computer kernel: [ 1686.857594] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Apr 7 05:00:34 Computer kernel: [ 1686.857595] CR2: 00007f5a66685000 CR3: 000000010653a000 CR4: 0000000000750ee0
Apr 7 05:00:34 Computer kernel: [ 1686.857597] PKRU: 55555554
Apr 7 05:00:34 Computer kernel: [ 1686.857597] Call Trace:
Apr 7 05:00:34 Computer kernel: [ 1686.857623] evergreen_cs_parse+0xc04/0x23f0 [radeon]
Apr 7 05:00:34 Computer kernel: [ 1686.857642] radeon_cs_ioctl+0x1bb/0x7b0 [radeon]
Apr 7 05:00:34 Computer kernel: [ 1686.857658] ? radeon_cs_parser_init+0x20/0x20 [radeon]
Apr 7 05:00:34 Computer kernel: [ 1686.857671] drm_ioctl_kernel+0xaa/0xf0 [drm]
Apr 7 05:00:34 Computer kernel: [ 1686.857682] drm_ioctl+0x220/0x3c0 [drm]
Apr 7 05:00:34 Computer kernel: [ 1686.857694] ? radeon_cs_parser_init+0x20/0x20 [radeon]
Apr 7 05:00:34 Computer kernel: [ 1686.857706] radeon_drm_ioctl+0x49/0x80 [radeon]
Apr 7 05:00:34 Computer kernel: [ 1686.857710] __x64_sys_ioctl+0x83/0xb0
Apr 7 05:00:34 Computer kernel: [ 1686.857717] do_syscall_64+0x33/0x80
Apr 7 05:00:34 Computer kernel: [ 1686.857721] entry_SYSCALL_64_after_hwframe+0x44/0xa9
Apr 7 05:00:34 Computer kernel: [ 1686.857724] RIP: 0033:0x7fc769377cc7
Apr 7 05:00:34 Computer kernel: [ 1686.857727] Code: 00 00 00 48 8b 05 c9 91 0c 00 64 c7 00 26 00 00 00 48 c7 c0 ff ff ff ff c3 66 2e 0f 1f 84 00 00 00 00 00 b8 10 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 99 91 0c 00 f7 d8 64 89 01 48
Apr 7 05:00:34 Computer kernel: [ 1686.857728] RSP: 002b:00007fc76077a9e8 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
Apr 7 05:00:34 Computer kernel: [ 1686.857730] RAX: ffffffffffffffda RBX: 00007fc75dbd3108 RCX: 00007fc769377cc7
Apr 7 05:00:34 Computer kernel: [ 1686.857731] RDX: 00007fc75dbd3108 RSI: 00000000c0206466 RDI: 0000000000000016
Apr 7 05:00:34 Computer kernel: [ 1686.857732] RBP: 00000000c0206466 R08: 0000000000000000 R09: 0000000000000000
Apr 7 05:00:34 Computer kernel: [ 1686.857733] R10: 0000000000000000 R11: 0000000000000246 R12: 000055bfceea0938
Apr 7 05:00:34 Computer kernel: [ 1686.857734] R13: 0000000000000016 R14: 00007fc75dbd71d0 R15: 000055bfceea08d8
Apr 7 05:00:34 Computer kernel: [ 1686.857736] Modules linked in: nfnetlink rfkill edac_mce_amd snd_hda_codec_realtek kvm_amd snd_hda_codec_generic ledtrig_audio binfmt_misc ccp snd_hda_codec_hdmi rng_core kvm nls_ascii snd_hda_intel nls_cp437 snd_intel_dspcfg vfat soundwire_intel fat ghash_clmulni_intel soundwire_generic_allocation snd_soc_core aesni_intel snd_compress soundwire_cadence libaes crypto_simd snd_hda_codec cryptd glue_helper joydev snd_hda_core snd_hwdep rapl wmi_bmof soundwire_bus pcspkr efi_pstore sp5100_tco k10temp watchdog snd_pcm snd_timer snd soundcore evdev acpi_cpufreq vfio_pci vfio_virqfd vfio_iommu_type1 vfio irqbypass msr parport_pc ppdev lp parport fuse configfs efivarfs ip_tables x_tables autofs4 ext4 crc16 mbcache jbd2 raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx xor raid6_pq libcrc32c crc32c_generic raid1 raid0 multipath linear md_mod amdgpu hid_generic radeon usbhid hid gpu_sched i2c_algo_bit ttm drm_kms_helper ahci cec libahci xhci_pci xhci_hcd r8169 libata realtek
Apr 7 05:00:34 Computer kernel: [ 1686.857785] nvme crc32_pclmul mdio_devres usbcore drm crc32c_intel scsi_mod nvme_core libphy i2c_piix4 t10_pi crc_t10dif usb_common crct10dif_generic crct10dif_pclmul crct10dif_common wmi button
Apr 7 05:00:34 Computer kernel: [ 1686.857797] ---[ end trace 293babf27b0823bc ]---
Apr 7 05:00:34 Computer kernel: [ 1687.026639] RIP: 0010:kmem_cache_alloc_trace+0x8f/0x200
Apr 7 05:00:34 Computer kernel: [ 1687.026640] Code: 27 38 4b 49 8b 00 49 83 78 10 00 48 89 04 24 0f 84 48 01 00 00 48 85 c0 0f 84 3f 01 00 00 41 8b 4c 24 28 49 8b 3c 24 48 01 c1 <48> 8b 19 48 89 ce 49 33 9c 24 b8 00 00 00 48 8d 4a 01 48 0f ce 48
Apr 7 05:00:34 Computer kernel: [ 1687.026641] RSP: 0018:ffffa993816fbc38 EFLAGS: 00010286
Apr 7 05:00:34 Computer kernel: [ 1687.026642] RAX: fd79183e12d8e2d7 RBX: ffff920230b54000 RCX: fd79183e12d8e4d7
Apr 7 05:00:34 Computer kernel: [ 1687.026642] RDX: 0000000000000e03 RSI: 0000000000000dc0 RDI: 00000000000330c0
Apr 7 05:00:34 Computer kernel: [ 1687.026643] RBP: ffff920180043500 R08: ffff92203ee730c0 R09: 0000000000000014
Apr 7 05:00:34 Computer kernel: [ 1687.026643] R10: 0000000000000000 R11: 0000000000000000 R12: ffff920180043500
Apr 7 05:00:34 Computer kernel: [ 1687.026644] R13: 0000000000000370 R14: ffffffffc0827f0a R15: 0000000000000dc0
Apr 7 05:00:34 Computer kernel: [ 1687.026644] FS: 00007fc76077b700(0000) GS:ffff92203ee40000(0000) knlGS:0000000000000000
Apr 7 05:00:34 Computer kernel: [ 1687.026645] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Apr 7 05:00:34 Computer kernel: [ 1687.026645] CR2: 00007f5a66685000 CR3: 000000010653a000 CR4: 0000000000750ee0
Apr 7 05:00:34 Computer kernel: [ 1687.026646] PKRU: 55555554
kern.log excerpt 2:
Apr 7 08:15:31 Computer kernel: [ 9512.574509] [drm:amdgpu_pci_remove [amdgpu]] *ERROR* Hotplug removal is not supported
Apr 7 08:15:31 Computer kernel: [ 9512.574850] amdgpu 0000:2d:00.0: amdgpu: amdgpu: finishing device.
Apr 7 08:15:31 Computer kernel: [ 9512.575325] ------------[ cut here ]------------
Apr 7 08:15:31 Computer kernel: [ 9512.575327] refcount_t: underflow; use-after-free.
Apr 7 08:15:31 Computer kernel: [ 9512.575335] WARNING: CPU: 9 PID: 8023 at lib/refcount.c:28 refcount_warn_saturate+0xa6/0xf0
Apr 7 08:15:31 Computer kernel: [ 9512.575336] Modules linked in: nfnetlink rfkill edac_mce_amd kvm_amd binfmt_misc ccp snd_hda_codec_realtek rng_core snd_hda_codec_generic nls_ascii ledtrig_audio kvm nls_cp437 snd_hda_codec_hdmi vfat fat ghash_clmulni_intel snd_hda_intel snd_intel_dspcfg soundwire_intel soundwire_generic_allocation snd_soc_core snd_compress soundwire_cadence aesni_intel joydev snd_hda_codec libaes crypto_simd snd_hda_core cryptd glue_helper snd_hwdep soundwire_bus snd_pcm rapl wmi_bmof sp5100_tco k10temp pcspkr efi_pstore snd_timer watchdog snd soundcore evdev acpi_cpufreq vfio_pci vfio_virqfd vfio_iommu_type1 vfio irqbypass msr parport_pc ppdev lp parport fuse configfs efivarfs ip_tables x_tables autofs4 ext4 crc16 mbcache jbd2 raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx xor raid6_pq libcrc32c crc32c_generic raid1 raid0 multipath linear md_mod hid_generic usbhid hid amdgpu radeon gpu_sched i2c_algo_bit ttm xhci_pci drm_kms_helper xhci_hcd ahci cec libahci libata r8169 nvme
Apr 7 08:15:31 Computer kernel: [ 9512.575386] drm crc32_pclmul realtek usbcore crc32c_intel nvme_core scsi_mod mdio_devres i2c_piix4 libphy t10_pi crc_t10dif usb_common crct10dif_generic crct10dif_pclmul crct10dif_common wmi button
Apr 7 08:15:31 Computer kernel: [ 9512.575398] CPU: 9 PID: 8023 Comm: bash Not tainted 5.10.0-13-amd64 #1 Debian 5.10.106-1
Apr 7 08:15:31 Computer kernel: [ 9512.575399] Hardware name: Micro-Star International Co., Ltd. MS-7C37/X570-A PRO (MS-7C37), BIOS H.A0 09/07/2020
Apr 7 08:15:31 Computer kernel: [ 9512.575402] RIP: 0010:refcount_warn_saturate+0xa6/0xf0
Apr 7 08:15:31 Computer kernel: [ 9512.575404] Code: 05 24 26 3e 01 01 e8 28 00 42 00 0f 0b c3 80 3d 12 26 3e 01 00 75 95 48 c7 c7 a0 07 f2 a9 c6 05 02 26 3e 01 01 e8 09 00 42 00 <0f> 0b c3 80 3d f1 25 3e 01 00 0f 85 72 ff ff ff 48 c7 c7 f8 07 f2
Apr 7 08:15:31 Computer kernel: [ 9512.575405] RSP: 0018:ffffbaf451cbbd10 EFLAGS: 00010282
Apr 7 08:15:31 Computer kernel: [ 9512.575407] RAX: 0000000000000000 RBX: 0000000000000001 RCX: ffff9e27bec5ca08
Apr 7 08:15:31 Computer kernel: [ 9512.575408] RDX: 00000000ffffffd8 RSI: 0000000000000027 RDI: ffff9e27bec5ca00
Apr 7 08:15:31 Computer kernel: [ 9512.575409] RBP: ffff9e0953673800 R08: 0000000000000000 R09: ffffbaf451cbbb30
Apr 7 08:15:31 Computer kernel: [ 9512.575410] R10: ffffbaf451cbbb28 R11: ffff9e283f26bfe8 R12: ffff9e09f8f00000
Apr 7 08:15:31 Computer kernel: [ 9512.575411] R13: 00000000ffffffff R14: ffff9e0b8c4d4a80 R15: ffff9e0b8c4d4aa0
Apr 7 08:15:31 Computer kernel: [ 9512.575412] FS: 00007fb9c447a740(0000) GS:ffff9e27bec40000(0000) knlGS:0000000000000000
Apr 7 08:15:31 Computer kernel: [ 9512.575413] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Apr 7 08:15:31 Computer kernel: [ 9512.575414] CR2: 00007fb9c463c730 CR3: 00000003fc35a000 CR4: 0000000000750ee0
Apr 7 08:15:31 Computer kernel: [ 9512.575415] PKRU: 55555554
Apr 7 08:15:31 Computer kernel: [ 9512.575416] Call Trace:
Apr 7 08:15:31 Computer kernel: [ 9512.575482] amdgpu_fbdev_fini+0xa2/0x110 [amdgpu]
Apr 7 08:15:31 Computer kernel: [ 9512.575572] amdgpu_device_fini+0xb1/0x4a6 [amdgpu]
Apr 7 08:15:31 Computer kernel: [ 9512.575629] amdgpu_pci_remove+0x36/0x50 [amdgpu]
Apr 7 08:15:31 Computer kernel: [ 9512.575632] pci_device_remove+0x3b/0xa0
Apr 7 08:15:31 Computer kernel: [ 9512.575637] __device_release_driver+0x17a/0x250
Apr 7 08:15:31 Computer kernel: [ 9512.575639] device_driver_detach+0x3c/0xa0
Apr 7 08:15:31 Computer kernel: [ 9512.575641] unbind_store+0x113/0x130
Apr 7 08:15:31 Computer kernel: [ 9512.575645] kernfs_fop_write_iter+0x124/0x1b0
Apr 7 08:15:31 Computer kernel: [ 9512.575648] new_sync_write+0x11c/0x1b0
Apr 7 08:15:31 Computer kernel: [ 9512.575651] vfs_write+0x1c2/0x260
Apr 7 08:15:31 Computer kernel: [ 9512.575652] ksys_write+0x5f/0xe0
Apr 7 08:15:31 Computer kernel: [ 9512.575655] do_syscall_64+0x33/0x80
Apr 7 08:15:31 Computer kernel: [ 9512.575657] entry_SYSCALL_64_after_hwframe+0x44/0xa9
Apr 7 08:15:31 Computer kernel: [ 9512.575659] RIP: 0033:0x7fb9c456bf33
Apr 7 08:15:31 Computer kernel: [ 9512.575661] Code: 8b 15 61 ef 0c 00 f7 d8 64 89 02 48 c7 c0 ff ff ff ff eb b7 0f 1f 00 64 8b 04 25 18 00 00 00 85 c0 75 14 b8 01 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 55 c3 0f 1f 40 00 48 83 ec 28 48 89 54 24 18
Apr 7 08:15:31 Computer kernel: [ 9512.575662] RSP: 002b:00007ffcfcf92758 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
Apr 7 08:15:31 Computer kernel: [ 9512.575663] RAX: ffffffffffffffda RBX: 000000000000000d RCX: 00007fb9c456bf33
Apr 7 08:15:31 Computer kernel: [ 9512.575664] RDX: 000000000000000d RSI: 0000562634e699f0 RDI: 0000000000000001
Apr 7 08:15:31 Computer kernel: [ 9512.575665] RBP: 0000562634e699f0 R08: 000000000000000a R09: 000000000000000c
Apr 7 08:15:31 Computer kernel: [ 9512.575666] R10: 0000562634e3f120 R11: 0000000000000246 R12: 000000000000000d
Apr 7 08:15:31 Computer kernel: [ 9512.575667] R13: 00007fb9c463c6a0 R14: 000000000000000d R15: 00007fb9c463c8a0
Apr 7 08:15:31 Computer kernel: [ 9512.575669] ---[ end trace 2e393deec3dd7bd6 ]---
Apr 7 08:15:31 Computer kernel: [ 9512.864104] ------------[ cut here ]------------
Apr 7 08:15:31 Computer kernel: [ 9512.864106] Still active user space clients!
Apr 7 08:15:31 Computer kernel: [ 9512.864190] WARNING: CPU: 8 PID: 8023 at drivers/gpu/drm/amd/amdgpu/amdgpu_gem.c:91 amdgpu_gem_force_release+0x142/0x150 [amdgpu]
Apr 7 08:15:31 Computer kernel: [ 9512.864191] Modules linked in: nfnetlink rfkill edac_mce_amd kvm_amd binfmt_misc ccp snd_hda_codec_realtek rng_core snd_hda_codec_generic nls_ascii ledtrig_audio kvm nls_cp437 snd_hda_codec_hdmi vfat fat ghash_clmulni_intel snd_hda_intel snd_intel_dspcfg soundwire_intel soundwire_generic_allocation snd_soc_core snd_compress soundwire_cadence aesni_intel joydev snd_hda_codec libaes crypto_simd snd_hda_core cryptd glue_helper snd_hwdep soundwire_bus snd_pcm rapl wmi_bmof sp5100_tco k10temp pcspkr efi_pstore snd_timer watchdog snd soundcore evdev acpi_cpufreq vfio_pci vfio_virqfd vfio_iommu_type1 vfio irqbypass msr parport_pc ppdev lp parport fuse configfs efivarfs ip_tables x_tables autofs4 ext4 crc16 mbcache jbd2 raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx xor raid6_pq libcrc32c crc32c_generic raid1 raid0 multipath linear md_mod hid_generic usbhid hid amdgpu radeon gpu_sched i2c_algo_bit ttm xhci_pci drm_kms_helper xhci_hcd ahci cec libahci libata r8169 nvme
Apr 7 08:15:31 Computer kernel: [ 9512.864232] drm crc32_pclmul realtek usbcore crc32c_intel nvme_core scsi_mod mdio_devres i2c_piix4 libphy t10_pi crc_t10dif usb_common crct10dif_generic crct10dif_pclmul crct10dif_common wmi button
Apr 7 08:15:31 Computer kernel: [ 9512.864243] CPU: 8 PID: 8023 Comm: bash Tainted: G W 5.10.0-13-amd64 #1 Debian 5.10.106-1
Apr 7 08:15:31 Computer kernel: [ 9512.864245] Hardware name: Micro-Star International Co., Ltd. MS-7C37/X570-A PRO (MS-7C37), BIOS H.A0 09/07/2020
Apr 7 08:15:31 Computer kernel: [ 9512.864304] RIP: 0010:amdgpu_gem_force_release+0x142/0x150 [amdgpu]
Apr 7 08:15:31 Computer kernel: [ 9512.864306] Code: fb 99 e3 c0 c6 05 11 59 53 00 01 e8 b7 5a c7 e8 0f 0b e9 76 ff ff ff 48 c7 c7 38 0a df c0 c6 05 f8 58 53 00 01 e8 9d 5a c7 e8 <0f> 0b e9 19 ff ff ff e8 92 db ca e8 66 90 0f 1f 44 00 00 41 57 41
Apr 7 08:15:31 Computer kernel: [ 9512.864307] RSP: 0018:ffffbaf451cbbce0 EFLAGS: 00010282
Apr 7 08:15:31 Computer kernel: [ 9512.864309] RAX: 0000000000000000 RBX: 00000000ffffffff RCX: ffff9e27bec1ca08
Apr 7 08:15:31 Computer kernel: [ 9512.864310] RDX: 00000000ffffffd8 RSI: 0000000000000027 RDI: ffff9e27bec1ca00
Apr 7 08:15:31 Computer kernel: [ 9512.864311] RBP: ffff9e09f8f00000 R08: 0000000000000000 R09: ffffbaf451cbbb00
Apr 7 08:15:31 Computer kernel: [ 9512.864312] R10: ffffbaf451cbbaf8 R11: ffff9e283f26bfe8 R12: ffff9e0b4d4e8c00
Apr 7 08:15:31 Computer kernel: [ 9512.864313] R13: ffff9e09f8f16328 R14: ffff9e09f8f00100 R15: ffff9e0b8c4d4aa0
Apr 7 08:15:31 Computer kernel: [ 9512.864314] FS: 00007fb9c447a740(0000) GS:ffff9e27bec00000(0000) knlGS:0000000000000000
Apr 7 08:15:31 Computer kernel: [ 9512.864316] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Apr 7 08:15:31 Computer kernel: [ 9512.864317] CR2: 00005632efda6580 CR3: 00000003fc35a000 CR4: 0000000000750ee0
Apr 7 08:15:31 Computer kernel: [ 9512.864318] PKRU: 55555554
Apr 7 08:15:31 Computer kernel: [ 9512.864319] Call Trace:
Apr 7 08:15:31 Computer kernel: [ 9512.864386] gmc_v8_0_sw_fini+0xe/0x60 [amdgpu]
Apr 7 08:15:31 Computer kernel: [ 9512.864475] amdgpu_device_fini+0x2a8/0x4a6 [amdgpu]
Apr 7 08:15:31 Computer kernel: [ 9512.864532] amdgpu_pci_remove+0x36/0x50 [amdgpu]
Apr 7 08:15:31 Computer kernel: [ 9512.864535] pci_device_remove+0x3b/0xa0
Apr 7 08:15:31 Computer kernel: [ 9512.864538] __device_release_driver+0x17a/0x250
Apr 7 08:15:31 Computer kernel: [ 9512.864541] device_driver_detach+0x3c/0xa0
Apr 7 08:15:31 Computer kernel: [ 9512.864542] unbind_store+0x113/0x130
Apr 7 08:15:31 Computer kernel: [ 9512.864545] kernfs_fop_write_iter+0x124/0x1b0
Apr 7 08:15:31 Computer kernel: [ 9512.864548] new_sync_write+0x11c/0x1b0
Apr 7 08:15:31 Computer kernel: [ 9512.864550] vfs_write+0x1c2/0x260
Apr 7 08:15:31 Computer kernel: [ 9512.864552] ksys_write+0x5f/0xe0
Apr 7 08:15:31 Computer kernel: [ 9512.864555] do_syscall_64+0x33/0x80
Apr 7 08:15:31 Computer kernel: [ 9512.864557] entry_SYSCALL_64_after_hwframe+0x44/0xa9
Apr 7 08:15:31 Computer kernel: [ 9512.864559] RIP: 0033:0x7fb9c456bf33
Apr 7 08:15:31 Computer kernel: [ 9512.864560] Code: 8b 15 61 ef 0c 00 f7 d8 64 89 02 48 c7 c0 ff ff ff ff eb b7 0f 1f 00 64 8b 04 25 18 00 00 00 85 c0 75 14 b8 01 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 55 c3 0f 1f 40 00 48 83 ec 28 48 89 54 24 18
Apr 7 08:15:31 Computer kernel: [ 9512.864562] RSP: 002b:00007ffcfcf92758 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
Apr 7 08:15:31 Computer kernel: [ 9512.864563] RAX: ffffffffffffffda RBX: 000000000000000d RCX: 00007fb9c456bf33
Apr 7 08:15:31 Computer kernel: [ 9512.864564] RDX: 000000000000000d RSI: 0000562634e699f0 RDI: 0000000000000001
Apr 7 08:15:31 Computer kernel: [ 9512.864565] RBP: 0000562634e699f0 R08: 000000000000000a R09: 000000000000000c
Apr 7 08:15:31 Computer kernel: [ 9512.864566] R10: 0000562634e3f120 R11: 0000000000000246 R12: 000000000000000d
Apr 7 08:15:31 Computer kernel: [ 9512.864567] R13: 00007fb9c463c6a0 R14: 000000000000000d R15: 00007fb9c463c8a0
Apr 7 08:15:31 Computer kernel: [ 9512.864569] ---[ end trace 2e393deec3dd7bd7 ]---
Apr 7 08:15:31 Computer kernel: [ 9512.864570] ------------[ cut here ]------------
Apr 7 08:15:31 Computer kernel: [ 9512.864571] And also active allocations!
Apr 7 08:15:31 Computer kernel: [ 9512.864638] WARNING: CPU: 8 PID: 8023 at drivers/gpu/drm/amd/amdgpu/amdgpu_gem.c:94 amdgpu_gem_force_release+0x128/0x150 [amdgpu]
Apr 7 08:15:31 Computer kernel: [ 9512.864639] Modules linked in: nfnetlink rfkill edac_mce_amd kvm_amd binfmt_misc ccp snd_hda_codec_realtek rng_core snd_hda_codec_generic nls_ascii ledtrig_audio kvm nls_cp437 snd_hda_codec_hdmi vfat fat ghash_clmulni_intel snd_hda_intel snd_intel_dspcfg soundwire_intel soundwire_generic_allocation snd_soc_core snd_compress soundwire_cadence aesni_intel joydev snd_hda_codec libaes crypto_simd snd_hda_core cryptd glue_helper snd_hwdep soundwire_bus snd_pcm rapl wmi_bmof sp5100_tco k10temp pcspkr efi_pstore snd_timer watchdog snd soundcore evdev acpi_cpufreq vfio_pci vfio_virqfd vfio_iommu_type1 vfio irqbypass msr parport_pc ppdev lp parport fuse configfs efivarfs ip_tables x_tables autofs4 ext4 crc16 mbcache jbd2 raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx xor raid6_pq libcrc32c crc32c_generic raid1 raid0 multipath linear md_mod hid_generic usbhid hid amdgpu radeon gpu_sched i2c_algo_bit ttm xhci_pci drm_kms_helper xhci_hcd ahci cec libahci libata r8169 nvme
Apr 7 08:15:31 Computer kernel: [ 9512.864670] drm crc32_pclmul realtek usbcore crc32c_intel nvme_core scsi_mod mdio_devres i2c_piix4 libphy t10_pi crc_t10dif usb_common crct10dif_generic crct10dif_pclmul crct10dif_common wmi button
Apr 7 08:15:31 Computer kernel: [ 9512.864679] CPU: 8 PID: 8023 Comm: bash Tainted: G W 5.10.0-13-amd64 #1 Debian 5.10.106-1
Apr 7 08:15:31 Computer kernel: [ 9512.864680] Hardware name: Micro-Star International Co., Ltd. MS-7C37/X570-A PRO (MS-7C37), BIOS H.A0 09/07/2020
Apr 7 08:15:31 Computer kernel: [ 9512.864737] RIP: 0010:amdgpu_gem_force_release+0x128/0x150 [amdgpu]
Apr 7 08:15:31 Computer kernel: [ 9512.864738] Code: 48 8b 3c 24 48 83 c4 18 5b 5d 41 5c 41 5d 41 5e 41 5f e9 6b 82 cb e8 48 c7 c7 fb 99 e3 c0 c6 05 11 59 53 00 01 e8 b7 5a c7 e8 <0f> 0b e9 76 ff ff ff 48 c7 c7 38 0a df c0 c6 05 f8 58 53 00 01 e8
Apr 7 08:15:31 Computer kernel: [ 9512.864739] RSP: 0018:ffffbaf451cbbce0 EFLAGS: 00010282
Apr 7 08:15:31 Computer kernel: [ 9512.864741] RAX: 0000000000000000 RBX: 00000000ffffffff RCX: ffff9e27bec1ca08
Apr 7 08:15:31 Computer kernel: [ 9512.864742] RDX: 00000000ffffffd8 RSI: 0000000000000027 RDI: ffff9e27bec1ca00
Apr 7 08:15:31 Computer kernel: [ 9512.864742] RBP: ffff9e0b4d4e8c40 R08: 0000000000000000 R09: ffffbaf451cbbb00
Apr 7 08:15:31 Computer kernel: [ 9512.864743] R10: ffffbaf451cbbaf8 R11: ffff9e283f26bfe8 R12: ffff9e0b4d4e8c00
Apr 7 08:15:31 Computer kernel: [ 9512.864744] R13: ffff9e0b4d4e8c58 R14: ffff9e09f8f00100 R15: ffff9e0bbdc5e058
Apr 7 08:15:31 Computer kernel: [ 9512.864746] FS: 00007fb9c447a740(0000) GS:ffff9e27bec00000(0000) knlGS:0000000000000000
Apr 7 08:15:31 Computer kernel: [ 9512.864747] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Apr 7 08:15:31 Computer kernel: [ 9512.864748] CR2: 00005632efda6580 CR3: 00000003fc35a000 CR4: 0000000000750ee0
Apr 7 08:15:31 Computer kernel: [ 9512.864749] PKRU: 55555554
Apr 7 08:15:31 Computer kernel: [ 9512.864749] Call Trace:
Apr 7 08:15:31 Computer kernel: [ 9512.864814] gmc_v8_0_sw_fini+0xe/0x60 [amdgpu]
Apr 7 08:15:31 Computer kernel: [ 9512.864898] amdgpu_device_fini+0x2a8/0x4a6 [amdgpu]
Apr 7 08:15:31 Computer kernel: [ 9512.864954] amdgpu_pci_remove+0x36/0x50 [amdgpu]
Apr 7 08:15:31 Computer kernel: [ 9512.864956] pci_device_remove+0x3b/0xa0
Apr 7 08:15:31 Computer kernel: [ 9512.864958] __device_release_driver+0x17a/0x250
Apr 7 08:15:31 Computer kernel: [ 9512.864960] device_driver_detach+0x3c/0xa0
Apr 7 08:15:31 Computer kernel: [ 9512.864962] unbind_store+0x113/0x130
Apr 7 08:15:31 Computer kernel: [ 9512.864964] kernfs_fop_write_iter+0x124/0x1b0
Apr 7 08:15:31 Computer kernel: [ 9512.864966] new_sync_write+0x11c/0x1b0
Apr 7 08:15:31 Computer kernel: [ 9512.864968] vfs_write+0x1c2/0x260
Apr 7 08:15:31 Computer kernel: [ 9512.864969] ksys_write+0x5f/0xe0
Apr 7 08:15:31 Computer kernel: [ 9512.864971] do_syscall_64+0x33/0x80
Apr 7 08:15:31 Computer kernel: [ 9512.864973] entry_SYSCALL_64_after_hwframe+0x44/0xa9
Apr 7 08:15:31 Computer kernel: [ 9512.864974] RIP: 0033:0x7fb9c456bf33
Apr 7 08:15:31 Computer kernel: [ 9512.864975] Code: 8b 15 61 ef 0c 00 f7 d8 64 89 02 48 c7 c0 ff ff ff ff eb b7 0f 1f 00 64 8b 04 25 18 00 00 00 85 c0 75 14 b8 01 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 55 c3 0f 1f 40 00 48 83 ec 28 48 89 54 24 18
Apr 7 08:15:31 Computer kernel: [ 9512.864977] RSP: 002b:00007ffcfcf92758 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
Apr 7 08:15:31 Computer kernel: [ 9512.864978] RAX: ffffffffffffffda RBX: 000000000000000d RCX: 00007fb9c456bf33
Apr 7 08:15:31 Computer kernel: [ 9512.864979] RDX: 000000000000000d RSI: 0000562634e699f0 RDI: 0000000000000001
Apr 7 08:15:31 Computer kernel: [ 9512.864980] RBP: 0000562634e699f0 R08: 000000000000000a R09: 000000000000000c
Apr 7 08:15:31 Computer kernel: [ 9512.864981] R10: 0000562634e3f120 R11: 0000000000000246 R12: 000000000000000d
Apr 7 08:15:31 Computer kernel: [ 9512.864981] R13: 00007fb9c463c6a0 R14: 000000000000000d R15: 00007fb9c463c8a0
Apr 7 08:15:31 Computer kernel: [ 9512.864983] ---[ end trace 2e393deec3dd7bd8 ]---
Apr 7 08:15:31 Computer kernel: [ 9512.865000] ------------[ cut here ]------------
Apr 7 08:15:31 Computer kernel: [ 9512.865060] WARNING: CPU: 8 PID: 8023 at drivers/gpu/drm/amd/amdgpu/amdgpu_vm.c:3227 amdgpu_vm_manager_fini+0x1e/0x50 [amdgpu]
Apr 7 08:15:31 Computer kernel: [ 9512.865061] Modules linked in: nfnetlink rfkill edac_mce_amd kvm_amd binfmt_misc ccp snd_hda_codec_realtek rng_core snd_hda_codec_generic nls_ascii ledtrig_audio kvm nls_cp437 snd_hda_codec_hdmi vfat fat ghash_clmulni_intel snd_hda_intel snd_intel_dspcfg soundwire_intel soundwire_generic_allocation snd_soc_core snd_compress soundwire_cadence aesni_intel joydev snd_hda_codec libaes crypto_simd snd_hda_core cryptd glue_helper snd_hwdep soundwire_bus snd_pcm rapl wmi_bmof sp5100_tco k10temp pcspkr efi_pstore snd_timer watchdog snd soundcore evdev acpi_cpufreq vfio_pci vfio_virqfd vfio_iommu_type1 vfio irqbypass msr parport_pc ppdev lp parport fuse configfs efivarfs ip_tables x_tables autofs4 ext4 crc16 mbcache jbd2 raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx xor raid6_pq libcrc32c crc32c_generic raid1 raid0 multipath linear md_mod hid_generic usbhid hid amdgpu radeon gpu_sched i2c_algo_bit ttm xhci_pci drm_kms_helper xhci_hcd ahci cec libahci libata r8169 nvme
Apr 7 08:15:31 Computer kernel: [ 9512.865092] drm crc32_pclmul realtek usbcore crc32c_intel nvme_core scsi_mod mdio_devres i2c_piix4 libphy t10_pi crc_t10dif usb_common crct10dif_generic crct10dif_pclmul crct10dif_common wmi button
Apr 7 08:15:31 Computer kernel: [ 9512.865099] CPU: 8 PID: 8023 Comm: bash Tainted: G W 5.10.0-13-amd64 #1 Debian 5.10.106-1
Apr 7 08:15:31 Computer kernel: [ 9512.865100] Hardware name: Micro-Star International Co., Ltd. MS-7C37/X570-A PRO (MS-7C37), BIOS H.A0 09/07/2020
Apr 7 08:15:31 Computer kernel: [ 9512.865158] RIP: 0010:amdgpu_vm_manager_fini+0x1e/0x50 [amdgpu]
Apr 7 08:15:31 Computer kernel: [ 9512.865159] Code: 66 2e 0f 1f 84 00 00 00 00 00 66 90 0f 1f 44 00 00 55 48 89 fd 48 81 c7 d0 54 00 00 48 83 ec 08 48 83 bd d8 54 00 00 00 74 14 <0f> 0b e8 fb 42 8a e8 48 89 ef 48 83 c4 08 5d e9 7e aa 00 00 31 f6
Apr 7 08:15:31 Computer kernel: [ 9512.865161] RSP: 0018:ffffbaf451cbbd18 EFLAGS: 00010286
Apr 7 08:15:31 Computer kernel: [ 9512.865162] RAX: ffff9e0991fd8000 RBX: ffff9e09f8f00000 RCX: 0000000000000000
Apr 7 08:15:31 Computer kernel: [ 9512.865163] RDX: ffff9e0991fd8000 RSI: ffff9e096004adb8 RDI: ffff9e09f8f054d0
Apr 7 08:15:31 Computer kernel: [ 9512.865164] RBP: ffff9e09f8f00000 R08: 0000000000000000 R09: 0000000000000000
Apr 7 08:15:31 Computer kernel: [ 9512.865164] R10: 0000000000000000 R11: ffff9e0b4d4e8c40 R12: 0000000000000001
Apr 7 08:15:31 Computer kernel: [ 9512.865165] R13: ffff9e09f8f16328 R14: ffff9e0b8c4d4a80 R15: ffff9e0b8c4d4aa0
Apr 7 08:15:31 Computer kernel: [ 9512.865167] FS: 00007fb9c447a740(0000) GS:ffff9e27bec00000(0000) knlGS:0000000000000000
Apr 7 08:15:31 Computer kernel: [ 9512.865168] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Apr 7 08:15:31 Computer kernel: [ 9512.865169] CR2: 00005632efda6580 CR3: 00000003fc35a000 CR4: 0000000000750ee0
Apr 7 08:15:31 Computer kernel: [ 9512.865170] PKRU: 55555554
Apr 7 08:15:31 Computer kernel: [ 9512.865170] Call Trace:
Apr 7 08:15:31 Computer kernel: [ 9512.865233] gmc_v8_0_sw_fini+0x16/0x60 [amdgpu]
Apr 7 08:15:31 Computer kernel: [ 9512.865314] amdgpu_device_fini+0x2a8/0x4a6 [amdgpu]
Apr 7 08:15:31 Computer kernel: [ 9512.865369] amdgpu_pci_remove+0x36/0x50 [amdgpu]
Apr 7 08:15:31 Computer kernel: [ 9512.865372] pci_device_remove+0x3b/0xa0
Apr 7 08:15:31 Computer kernel: [ 9512.865374] __device_release_driver+0x17a/0x250
Apr 7 08:15:31 Computer kernel: [ 9512.865376] device_driver_detach+0x3c/0xa0
Apr 7 08:15:31 Computer kernel: [ 9512.865377] unbind_store+0x113/0x130
Apr 7 08:15:31 Computer kernel: [ 9512.865379] kernfs_fop_write_iter+0x124/0x1b0
Apr 7 08:15:31 Computer kernel: [ 9512.865381] new_sync_write+0x11c/0x1b0
Apr 7 08:15:31 Computer kernel: [ 9512.865383] vfs_write+0x1c2/0x260
Apr 7 08:15:31 Computer kernel: [ 9512.865384] ksys_write+0x5f/0xe0
Apr 7 08:15:31 Computer kernel: [ 9512.865386] do_syscall_64+0x33/0x80
Apr 7 08:15:31 Computer kernel: [ 9512.865388] entry_SYSCALL_64_after_hwframe+0x44/0xa9
Apr 7 08:15:31 Computer kernel: [ 9512.865389] RIP: 0033:0x7fb9c456bf33
Apr 7 08:15:31 Computer kernel: [ 9512.865390] Code: 8b 15 61 ef 0c 00 f7 d8 64 89 02 48 c7 c0 ff ff ff ff eb b7 0f 1f 00 64 8b 04 25 18 00 00 00 85 c0 75 14 b8 01 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 55 c3 0f 1f 40 00 48 83 ec 28 48 89 54 24 18
Apr 7 08:15:31 Computer kernel: [ 9512.865391] RSP: 002b:00007ffcfcf92758 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
Apr 7 08:15:31 Computer kernel: [ 9512.865393] RAX: ffffffffffffffda RBX: 000000000000000d RCX: 00007fb9c456bf33
Apr 7 08:15:31 Computer kernel: [ 9512.865393] RDX: 000000000000000d RSI: 0000562634e699f0 RDI: 0000000000000001
Apr 7 08:15:31 Computer kernel: [ 9512.865394] RBP: 0000562634e699f0 R08: 000000000000000a R09: 000000000000000c
Apr 7 08:15:31 Computer kernel: [ 9512.865395] R10: 0000562634e3f120 R11: 0000000000000246 R12: 000000000000000d
Apr 7 08:15:31 Computer kernel: [ 9512.865396] R13: 00007fb9c463c6a0 R14: 000000000000000d R15: 00007fb9c463c8a0
Apr 7 08:15:31 Computer kernel: [ 9512.865398] ---[ end trace 2e393deec3dd7bd9 ]---
Apr 7 08:15:31 Computer kernel: [ 9513.020345] amdgpu: Move buffer fallback to memcpy unavailable
Apr 7 08:15:31 Computer kernel: [ 9513.020349] [TTM] Buffer eviction failed
Apr 7 08:15:31 Computer kernel: [ 9513.020366] [drm] amdgpu: ttm finalized
Apr 7 08:15:31 Computer kernel: [ 9513.020618] vfio-pci 0000:2d:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=io+mem:owns=none
Apr 7 08:15:56 Computer kernel: [ 9538.060792] general protection fault, probably for non-canonical address 0x21d0530eb99a3483: 0000 [#1] SMP NOPTI
Apr 7 08:15:56 Computer kernel: [ 9538.060797] CPU: 16 PID: 3760 Comm: Renderer Tainted: G W 5.10.0-13-amd64 #1 Debian 5.10.106-1
Apr 7 08:15:56 Computer kernel: [ 9538.060799] Hardware name: Micro-Star International Co., Ltd. MS-7C37/X570-A PRO (MS-7C37), BIOS H.A0 09/07/2020
Apr 7 08:15:56 Computer kernel: [ 9538.060803] RIP: 0010:kmem_cache_alloc_trace+0x8f/0x200
Apr 7 08:15:56 Computer kernel: [ 9538.060806] Code: 27 f8 56 49 8b 00 49 83 78 10 00 48 89 04 24 0f 84 48 01 00 00 48 85 c0 0f 84 3f 01 00 00 41 8b 4c 24 28 49 8b 3c 24 48 01 c1 <48> 8b 19 48 89 ce 49 33 9c 24 b8 00 00 00 48 8d 4a 01 48 0f ce 48
Apr 7 08:15:56 Computer kernel: [ 9538.060807] RSP: 0018:ffffbaf45125bc38 EFLAGS: 00010202
Apr 7 08:15:56 Computer kernel: [ 9538.060809] RAX: 21d0530eb99a3283 RBX: ffff9e09890bc000 RCX: 21d0530eb99a3483
Apr 7 08:15:56 Computer kernel: [ 9538.060811] RDX: 000000000000f045 RSI: 0000000000000dc0 RDI: 00000000000330c0
Apr 7 08:15:56 Computer kernel: [ 9538.060812] RBP: ffff9e0900043500 R08: ffff9e27bee330c0 R09: 0000000000000000
Apr 7 08:15:56 Computer kernel: [ 9538.060812] R10: 0000000000000000 R11: 0000000000000000 R12: ffff9e0900043500
Apr 7 08:15:56 Computer kernel: [ 9538.060814] R13: 0000000000000370 R14: ffffffffc0877f0a R15: 0000000000000dc0
Apr 7 08:15:56 Computer kernel: [ 9538.060815] FS: 00007f7f3c078700(0000) GS:ffff9e27bee00000(0000) knlGS:0000000000000000
Apr 7 08:15:56 Computer kernel: [ 9538.060816] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Apr 7 08:15:56 Computer kernel: [ 9538.060817] CR2: 00007f7f26515000 CR3: 000000034b76a000 CR4: 0000000000750ee0
Apr 7 08:15:56 Computer kernel: [ 9538.060819] PKRU: 55555554
Apr 7 08:15:56 Computer kernel: [ 9538.060820] Call Trace:
Apr 7 08:15:56 Computer kernel: [ 9538.060840] radeon_bo_create+0x9a/0x200 [radeon]
Apr 7 08:15:56 Computer kernel: [ 9538.060856] ? radeon_fence_activity+0x152/0x170 [radeon]
Apr 7 08:15:56 Computer kernel: [ 9538.060872] ? radeon_gem_pwrite_ioctl+0x20/0x20 [radeon]
Apr 7 08:15:56 Computer kernel: [ 9538.060886] radeon_gem_object_create+0xb0/0x1a0 [radeon]
Apr 7 08:15:56 Computer kernel: [ 9538.060899] ? radeon_gem_pwrite_ioctl+0x20/0x20 [radeon]
Apr 7 08:15:56 Computer kernel: [ 9538.060912] radeon_gem_create_ioctl+0x66/0x120 [radeon]
Apr 7 08:15:56 Computer kernel: [ 9538.060915] ? tomoyo_path_number_perm+0x66/0x1d0
Apr 7 08:15:56 Computer kernel: [ 9538.060928] ? radeon_gem_pwrite_ioctl+0x20/0x20 [radeon]
Apr 7 08:15:56 Computer kernel: [ 9538.060941] drm_ioctl_kernel+0xaa/0xf0 [drm]
Apr 7 08:15:56 Computer kernel: [ 9538.060953] drm_ioctl+0x220/0x3c0 [drm]
Apr 7 08:15:56 Computer kernel: [ 9538.060966] ? radeon_gem_pwrite_ioctl+0x20/0x20 [radeon]
Apr 7 08:15:56 Computer kernel: [ 9538.060978] radeon_drm_ioctl+0x49/0x80 [radeon]
Apr 7 08:15:56 Computer kernel: [ 9538.060982] __x64_sys_ioctl+0x83/0xb0
Apr 7 08:15:56 Computer kernel: [ 9538.060986] do_syscall_64+0x33/0x80
Apr 7 08:15:56 Computer kernel: [ 9538.060988] entry_SYSCALL_64_after_hwframe+0x44/0xa9
Apr 7 08:15:56 Computer kernel: [ 9538.060991] RIP: 0033:0x7f7f5a871cc7
Apr 7 08:15:56 Computer kernel: [ 9538.060992] Code: 00 00 00 48 8b 05 c9 91 0c 00 64 c7 00 26 00 00 00 48 c7 c0 ff ff ff ff c3 66 2e 0f 1f 84 00 00 00 00 00 b8 10 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 99 91 0c 00 f7 d8 64 89 01 48
Apr 7 08:15:56 Computer kernel: [ 9538.060994] RSP: 002b:00007f7f3c075c38 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
Apr 7 08:15:56 Computer kernel: [ 9538.060996] RAX: ffffffffffffffda RBX: 00007f7f3c075cb0 RCX: 00007f7f5a871cc7
Apr 7 08:15:56 Computer kernel: [ 9538.060996] RDX: 00007f7f3c075cb0 RSI: 00000000c020645d RDI: 000000000000001d
Apr 7 08:15:56 Computer kernel: [ 9538.060997] RBP: 00000000c020645d R08: 0000000000000010 R09: 0000000000000009
Apr 7 08:15:56 Computer kernel: [ 9538.060998] R10: 00007fff377ce080 R11: 0000000000000246 R12: 0000000000001000
Apr 7 08:15:56 Computer kernel: [ 9538.060999] R13: 000000000000001d R14: 0000000000001000 R15: 0000000000000009
Apr 7 08:15:56 Computer kernel: [ 9538.061002] Modules linked in: nfnetlink rfkill edac_mce_amd kvm_amd binfmt_misc ccp snd_hda_codec_realtek rng_core snd_hda_codec_generic nls_ascii ledtrig_audio kvm nls_cp437 snd_hda_codec_hdmi vfat fat ghash_clmulni_intel snd_hda_intel snd_intel_dspcfg soundwire_intel soundwire_generic_allocation snd_soc_core snd_compress soundwire_cadence aesni_intel joydev snd_hda_codec libaes crypto_simd snd_hda_core cryptd glue_helper snd_hwdep soundwire_bus snd_pcm rapl wmi_bmof sp5100_tco k10temp pcspkr efi_pstore snd_timer watchdog snd soundcore evdev acpi_cpufreq vfio_pci vfio_virqfd vfio_iommu_type1 vfio irqbypass msr parport_pc ppdev lp parport fuse configfs efivarfs ip_tables x_tables autofs4 ext4 crc16 mbcache jbd2 raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx xor raid6_pq libcrc32c crc32c_generic raid1 raid0 multipath linear md_mod hid_generic usbhid hid amdgpu radeon gpu_sched i2c_algo_bit ttm xhci_pci drm_kms_helper xhci_hcd ahci cec libahci libata r8169 nvme
Apr 7 08:15:56 Computer kernel: [ 9538.061050] drm crc32_pclmul realtek usbcore crc32c_intel nvme_core scsi_mod mdio_devres i2c_piix4 libphy t10_pi crc_t10dif usb_common crct10dif_generic crct10dif_pclmul crct10dif_common wmi button
Apr 7 08:15:56 Computer kernel: [ 9538.061061] ---[ end trace 2e393deec3dd7bda ]---
Apr 7 08:15:56 Computer kernel: [ 9538.213007] RIP: 0010:kmem_cache_alloc_trace+0x8f/0x200
Apr 7 08:15:56 Computer kernel: [ 9538.213009] Code: 27 f8 56 49 8b 00 49 83 78 10 00 48 89 04 24 0f 84 48 01 00 00 48 85 c0 0f 84 3f 01 00 00 41 8b 4c 24 28 49 8b 3c 24 48 01 c1 <48> 8b 19 48 89 ce 49 33 9c 24 b8 00 00 00 48 8d 4a 01 48 0f ce 48
Apr 7 08:15:56 Computer kernel: [ 9538.213010] RSP: 0018:ffffbaf45125bc38 EFLAGS: 00010202
Apr 7 08:15:56 Computer kernel: [ 9538.213011] RAX: 21d0530eb99a3283 RBX: ffff9e09890bc000 RCX: 21d0530eb99a3483
Apr 7 08:15:56 Computer kernel: [ 9538.213012] RDX: 000000000000f045 RSI: 0000000000000dc0 RDI: 00000000000330c0
Apr 7 08:15:56 Computer kernel: [ 9538.213013] RBP: ffff9e0900043500 R08: ffff9e27bee330c0 R09: 0000000000000000
Apr 7 08:15:56 Computer kernel: [ 9538.213013] R10: 0000000000000000 R11: 0000000000000000 R12: ffff9e0900043500
Apr 7 08:15:56 Computer kernel: [ 9538.213014] R13: 0000000000000370 R14: ffffffffc0877f0a R15: 0000000000000dc0
Apr 7 08:15:56 Computer kernel: [ 9538.213015] FS: 00007f7f3c078700(0000) GS:ffff9e27bee00000(0000) knlGS:0000000000000000
Apr 7 08:15:56 Computer kernel: [ 9538.213016] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Apr 7 08:15:56 Computer kernel: [ 9538.213016] CR2: 00007f7f26515000 CR3: 000000034b76a000 CR4: 0000000000750ee0
Apr 7 08:15:56 Computer kernel: [ 9538.213017] PKRU: 55555554
Apr 7 08:15:56 Computer kernel: [ 9538.213028] general protection fault, probably for non-canonical address 0x21d0530eb99a3483: 0000 [#2] SMP NOPTI
Apr 7 08:15:56 Computer kernel: [ 9538.213029] CPU: 16 PID: 908 Comm: kworker/16:2 Tainted: G D W 5.10.0-13-amd64 #1 Debian 5.10.106-1
Apr 7 08:15:56 Computer kernel: [ 9538.213029] Hardware name: Micro-Star International Co., Ltd. MS-7C37/X570-A PRO (MS-7C37), BIOS H.A0 09/07/2020
Apr 7 08:15:56 Computer kernel: [ 9538.213032] Workqueue: events efi_pstore_update_entries [efi_pstore]
Apr 7 08:15:56 Computer kernel: [ 9538.213033] RIP: 0010:kmem_cache_alloc_trace+0x8f/0x200
Apr 7 08:15:56 Computer kernel: [ 9538.213034] Code: 27 f8 56 49 8b 00 49 83 78 10 00 48 89 04 24 0f 84 48 01 00 00 48 85 c0 0f 84 3f 01 00 00 41 8b 4c 24 28 49 8b 3c 24 48 01 c1 <48> 8b 19 48 89 ce 49 33 9c 24 b8 00 00 00 48 8d 4a 01 48 0f ce 48
Apr 7 08:15:56 Computer kernel: [ 9538.213035] RSP: 0018:ffffbaf4423c7d80 EFLAGS: 00010202
Apr 7 08:15:56 Computer kernel: [ 9538.213036] RAX: 21d0530eb99a3283 RBX: ffff9e0901285200 RCX: 21d0530eb99a3483
Apr 7 08:15:56 Computer kernel: [ 9538.213036] RDX: 000000000000f045 RSI: 0000000000000dc0 RDI: 00000000000330c0
Apr 7 08:15:56 Computer kernel: [ 9538.213037] RBP: ffff9e0900043500 R08: ffff9e27bee330c0 R09: ffff9e0927bde000
Apr 7 08:15:56 Computer kernel: [ 9538.213038] R10: 0000000000000018 R11: 0000000000000018 R12: ffff9e0900043500
Apr 7 08:15:56 Computer kernel: [ 9538.213038] R13: 0000000000000400 R14: ffffffffa94a9ab5 R15: 0000000000000dc0
Apr 7 08:15:56 Computer kernel: [ 9538.213039] FS: 0000000000000000(0000) GS:ffff9e27bee00000(0000) knlGS:0000000000000000
Apr 7 08:15:56 Computer kernel: [ 9538.213040] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Apr 7 08:15:56 Computer kernel: [ 9538.213040] CR2: 00007f7f26515000 CR3: 000000034b76a000 CR4: 0000000000750ee0
Apr 7 08:15:56 Computer kernel: [ 9538.213041] PKRU: 55555554
Apr 7 08:15:56 Computer kernel: [ 9538.213041] Call Trace:
Apr 7 08:15:56 Computer kernel: [ 9538.213044] efivar_init+0x75/0x390
Apr 7 08:15:56 Computer kernel: [ 9538.213047] ? efi_pstore_open+0x10/0x10 [efi_pstore]
Apr 7 08:15:56 Computer kernel: [ 9538.213048] ? efi_pstore_update_entries+0x4c/0x70 [efi_pstore]
Apr 7 08:15:56 Computer kernel: [ 9538.213049] ? kmem_cache_alloc_trace+0xf5/0x200
Apr 7 08:15:56 Computer kernel: [ 9538.213051] efi_pstore_update_entries+0x23/0x70 [efi_pstore]
Apr 7 08:15:56 Computer kernel: [ 9538.213053] process_one_work+0x1b6/0x350
Apr 7 08:15:56 Computer kernel: [ 9538.213055] worker_thread+0x53/0x3e0
Apr 7 08:15:56 Computer kernel: [ 9538.213056] ? process_one_work+0x350/0x350
Apr 7 08:15:56 Computer kernel: [ 9538.213057] kthread+0x11b/0x140
Apr 7 08:15:56 Computer kernel: [ 9538.213058] ? __kthread_bind_mask+0x60/0x60
Apr 7 08:15:56 Computer kernel: [ 9538.213059] ret_from_fork+0x22/0x30
Apr 7 08:15:56 Computer kernel: [ 9538.213060] Modules linked in: nfnetlink rfkill edac_mce_amd kvm_amd binfmt_misc ccp snd_hda_codec_realtek rng_core snd_hda_codec_generic nls_ascii ledtrig_audio kvm nls_cp437 snd_hda_codec_hdmi vfat fat ghash_clmulni_intel snd_hda_intel snd_intel_dspcfg soundwire_intel soundwire_generic_allocation snd_soc_core snd_compress soundwire_cadence aesni_intel joydev snd_hda_codec libaes crypto_simd snd_hda_core cryptd glue_helper snd_hwdep soundwire_bus snd_pcm rapl wmi_bmof sp5100_tco k10temp pcspkr efi_pstore snd_timer watchdog snd soundcore evdev acpi_cpufreq vfio_pci vfio_virqfd vfio_iommu_type1 vfio irqbypass msr parport_pc ppdev lp parport fuse configfs efivarfs ip_tables x_tables autofs4 ext4 crc16 mbcache jbd2 raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx xor raid6_pq libcrc32c crc32c_generic raid1 raid0 multipath linear md_mod hid_generic usbhid hid amdgpu radeon gpu_sched i2c_algo_bit ttm xhci_pci drm_kms_helper xhci_hcd ahci cec libahci libata r8169 nvme
Apr 7 08:15:56 Computer kernel: [ 9538.213081] drm crc32_pclmul realtek usbcore crc32c_intel nvme_core scsi_mod mdio_devres i2c_piix4 libphy t10_pi crc_t10dif usb_common crct10dif_generic crct10dif_pclmul crct10dif_common wmi button
Apr 7 08:15:56 Computer kernel: [ 9538.213087] ---[ end trace 2e393deec3dd7bdb ]---
