Will this fit?
After building my latest Haswell build for work, it's now time to build a workstation for the home office.
I want to use the following hardware together :
Asus Rampage IV extreme 2011
Intel Core I7-4930k
Crosair H100i
However I need a case that has the clearance to put the H100i in.  My favorite case to use at the moment is the Fractal Design R4.  I would prefer to use this case again, however I have serious doubts the H100i fans will have enough clearance to fit.  I don't mind snug, but would like to avoid having to bend or cut things to make it fit.
Has anyone built this motherboard/cpucooler combo into an R4?
The front is not an option, I need my hard drive cages as they will filled up to the brim.  So it has to be at the top.
If I have to pick another case, I would ideally want one that can handle an H100i push pull, for possible cooling upgrades down the road.
What are my options for other cases that aren't too flashy (I like sleek, minimalistic, zero LED lights and black)?
Budget is not that much of an issue, although lower is always nice.
Thanks for the input.
Yes, there is plenty of clearance in the R4.
First pic is an H220, but the rads are pretty much the same and they both use 25mm fans.
Thats what she said....
Yes it will fit, but its a bit of a squeeze
youtube.com/watch?v=cbXiMJh3ZZA
