Hey guys.
I am wanting to build a computer soon and will most likely upgrade to crossfire within a few months
i would be using the asrock z77 extreme4 m which has 2x pciE 3.0 slots 1x pciE 2.0 x16 and 1x pciE 2.0 x1
i would be running two 7970 dual slot cards in crossfire and an Avermedia Game capture HD.
Will this all fit in the corsair obsidian 350d? the case is 5 slot which my config would be but will it work with the motherboard
Cheers for any replies
Matt
