What is up guys, I was just wondering if you guys think APUs will soon put an end to desktop graphics for the average consumer, as it stands now APUs are capable of gaming fairly well at lower settings, so it can only go up from here right? I'm just wondering how long before DDR4 apus come out and I can screw an ITX build under my desk as my main PC.
Personally I'm also hoping AMD gets off their butts and talks with some laptop makers to get some convertible laptops made, because currently I haven't been able to find one.
Considering that the only manufacturer for APUs is AMD I'm guessing they wouldn't want to push the technology of these chips too far to the point that the sales of AMD graphics cards start to go down. I think APUs will always be a low budget solution.
That's not true. Intel also makes a type of APU too. Though the only ones I can think of are the new SoCs that were produced for the microcontrolelr market recently. I am specifically referring to the Quark.
GPU sales down down, but APU sales would go up, doesn't seem too bad a trade off. and enthusiasts will never settle so they're always going to try to get the best thing
I thought intel only put their best graphics on their high end chips which doesn't make much sense when you take a moment to think...
I don't see it going that way. If anything a low-mid range APU core will compliment a desktop 6 or 8 core processor for offloading OpenCL based physics onto the APU core instead of forcing the CPU to do physics processing which will be several magnitudes slower when using a CPU. Even with a low-mid range onboard GPU, especially if it's attached to DDR4 system RAM. It will outperform a CPU at OpenCL calculations by a stark contrast.
The way of the future is APU accelerated GPU transcoding and OpenCL workload offload from a dedicated GPU in a gaming environment..Unless they find out a way to cram the performance of a 7970 next to a 100w TDP 8-core CPU die with less than 100W TDP from the graphics core, an APU is never going to replace the desktop processor entirely.
You're right, they only do put it in their top of the line chips... but a lot their video references were AMD based. Also the quark would only have enough basic video for something cheap and simple... Think 80's to early 90's tech.
