Hello!
I'm going to be getting a xbox one and I'm going to be recording. I've decided to get this:http://www.amazon.co.uk/AVerMedia-HD-Lite-Live-Gamer/dp/B00GLPYA1I/ref=sr_1_5?s=computers&ie=UTF8&qid=1418570424&sr=1-5&keywords=avermedia#productDetails
However. I dont know if it will fit next to my large GPU (ASUS 750 ti)
Here's the thingy:
http://i.imgur.com/UBuGCqR.jpg
Thanks!
if space is a problem why not go with a usb 3 solution?
That's a regular PCI slot not a PCIe slot, so no, it won't fit.
Ya might wanna post ur motherboard. Also that's 1x PCIe, there should be a 1x slot on top. If you have a standard looking motherboard before the Main PCIe slot for graphics.
