Yes. The CPU socket on the mobo is AM3+ and the CPU uses AM3+. So yes, the board will work with the CPU. I'm not sure about flashing the BIOS, but since 990FX is the latest AM3+ chipset (I think), it should work natively. The same principle applies to other motherboards. For example, if you have a motherboard that uses socket LGA1155, you have to buy a LGA1155 CPU (LGA sockets are made by Intel. BGA sockets are as well, but they are a package of CPU and socket that are soldered to the motherboard).
It will work but I'd much rather buy an Asus M5A99FX PRO r2.0. I've heard people have BIOS issues with those Gigabyte AM3+ motherboards pretty consistently. Also overclocking an FX-8350 with that motherboard is ill-advised.
for more than a month i've been posting threads on forums asking advice on fx-8350 and that motherboard and i thought the motherboard was a good choice.
I knew i was being misinformed dammit
thank god i kept postponing the purchase of my new build !!
i think i'm done with amd ok ok what about this build:
It works 100% my computer build is 8350 w/ the ud3 board. I'm able to overclock it to 4.5Ghz on stock voltage and keeping all of the power saving features active. I've benchmarked it and works 100% properly.
sorry to hear, my asus m599FX pro gave me so many problems and then took a shit after a year, sent for RMA and 2nd board was the same, after 2 months i turned my pc on and a few of the caps popped. Had bad luck with 990FX boards on ASUS side. Guess you had a defective build.
I have a friend using the 8359 and the ud3 rev3 and we havn't had a single hitch. He's not OC'ing so we were not worried about the open VRM. the VRM is completely fine if you're not OC alot.
