Well, I'm building a gaming computer and one of my questions was: is an wifi connection better or faster than an ethernet cable? None of the guides on youtube mention something about a wifi connector or something like that so I'm not sure wich way is the best.
ethernet
Ethernet is a more reliable, stable, and in most cases, faster solution.
If you're near your router, ethernet for sure. If you have really good wifi, you should be fine if you aren't near the router.
Everything what brennan said. But if you don't have the money or can't route it. wifi is very viable.
NJm has a realy good point
I'll take the guide into consideration. Right now I'm still trying to finish up my outline for WPA
