Why X570 Aorus Master not supporting 3 cards in mining
Hi
I earlier had Gigabyte Aorus 2070 super and added MSI Suprim X RTX 3090 for machine learning and deep learning connected to my motherboard. They used to work fine and I was able to use them.
Last month decided to join mining as a casual miner, so started putting the above 2 GPU for some additional usage. I recently bought Asus ROG RTX 3070 to add some more hashes to the RIG.
This is just to show you what I mean when I say 1,2,3,4 with PCIe numbering.
But the problem is the 3070 and 3090 do not work together. This are my results the settings I have tried with BIOS and results I got.
PCIe Lane Generation PCIEx16 Bifurcation Result PCIE Port Config/ GPU Placement
PCIE-2 4*4 Detect all GPU, 3090 CUDA not detected 1-2070s, 2nd-3070, 3rd-3090
PCIE-3 4*4 Detect all GPU, 3090 CUDA not detected 1-2070s, 2nd-3070, 3rd-3091
Auto 4*4 3070 not detected, 3090 No CUDA 1-2070s, 2nd-3070, 3rd-3092
Auto 1*8/2*4 Only 2070s 1-2070s, 2nd-3090, 3rd-3070
PCIE-4 1*8/2*4 Only 2070s 1-2070s, 2nd-3090, 3rd-3071
PCIE-4 4*4 Only 2070s 1-2070s, 2nd-3090, 3rd-3072
PCIE-4 4*4 Only 2070s 1-2070s, 2nd-3090, 3rd-3070
Auto 4*4 3070 not detected, 3090 No CUDA 1-2070s, 2nd-3090, 3rd-3071
Auto Auto Only 2070s 1-2070s, 2nd-3090, 3rd-3072
Auto Auto Only 2070s 1-2070s, 2nd-3090 (with 2 GPU only)
PCIE-2 Auto 2070s + 3090 Detected and shows CUDA 1-2070s, 2nd-3090 (with 2 GPU only)
PCIE-2 Auto 3070 not detected, 2070s+3090 CUDA Works 1-2070s, 2nd-3090, 3rd-3071
PCIE-2 Auto 3070 not detected, 2070s+3090 CUDA Works 1-2070s, 2nd-3090, 4th-3070
PCIE-2 1*8/2*4 3070 not detected, 2070s+3090 CUDA Works 1-2070s, 2nd-3090, 3rd-3070
PCIE-2 1*8/2*4 3070 not detected, 2070s+3090 CUDA Works 1-2070s, 2nd-3090, 4th-3070
PCIE-2 Auto 2070s + 3070 Detected and shows CUDA 1-2070s, 2nd-3070 (with 2 GPU only)
PCIE-2 2*4/1*8 Detect all GPU, 3090 CUDA not detected 1-2070s, 2nd-3070, 3rd-3090
PCIE-2 2*4/1*8 2070s + 3070 Detected and shows CUDA 1-2070s, 2nd-3070, 4th-3090
PCIE-2 1*8/2*4 3090 not detected 1-3070s, 2nd-3090 (with 2 GPU only)
PCIE-2 Auto 3090 not detected 1-3070s, 2nd-3090 (with 2 GPU only)
Auto Auto 3090 not detected 1-3070s, 2nd-3090 (with 2 GPU only)
Why does 3070 and 3090 do not work together.
According to the specifications of the motherboard, the slots work like this:
  1. x16 if slot 2 is not occupied, x8 otherwise. Powered by CPU.
  2. x8, Powered by CPU.
  3. x1, Powered by chipset and requires a Ryzen 3rd gen (3000+ series I think?)
  4. x4, Powered by chipset and requires a Ryzen 3rd gen
According to the manual you should have 3090 in slot 1, 3070 in slot 2 and 2070 in slot 4, and bifurb should be x8/x8/x4.
However, it is possible that CUDA requires x8 PCIe lanes, or that cards require to be part of the CPU lanes, in which case you need to either get an x8/x8/x4 from CPU motherboard, or perhaps a Threadripper build.
This site here might have better info: GPUDirect RDMA :: CUDA Toolkit Documentation
Highly likely yes. :slight_smile:
Sli on Nvidia does not work on 4x bus either.
Hooray for the ASUS Pro WS X570-ACE, the only AM4 motherboard with an electrical x8 slot coming from the chipset.
