I’m reading “reverse engineering for beginners” and picking up ASM along the way, one thing i couldn’t figure it out however is why this hello world (in C):
Specifically, i don’t understand why it starts with “push ebp”, i know ebp points to the current stack frame, and i imagine that push ebp, mov ebp, esp means “whatever is currently on the stack frame, push it onto the stack and create this new, empty stack frame”. Is that correct?
The push is there to allow you to clear the stack you made without destroying the stack of the calling subroutine/function. A subroutine usually does this:
pushl %ebp
movl %esp, %ebp
# subroutine stuff goes here
movl %ebp, %esp
popl %ebp
ret
Although the leave op can do the same thing (welcome to CISC), so instead you have:
pushl %ebp
movl %esp, %ebp
leave
ret
This just backs up the previous stack base %ebp and restores it after you are done. If the routine doesn’t use the stack, you don’t need that push-mov combo or the leave.
What exactly do you mean by stack cleaning in that snippet of code? If you are talking about the 3rd and 4th instruction those are probably there to align the ESP to 16 bytes (last 4 bits zero).
Sorry, for a second there I thought cleaning the stack was the part where you restore the EBP to the pre-call state. I misunderstood the CDECL example I was looking at.
