Why are these Intel Arc Pro variants so differently priced?
I was considering getting myself an Intel Arc Pro B70 for some local LLM excperimentation. During my search I came across these two variants, normally I would expect the OEM versions are off by a little from the reference cards, but with some obvious differences like clock speed.
Is it because of the blower design? Does that make it unsuitable for a regular tower case. I have Fractal Design Meshify C Mini (it’s an mATX case).
The cards still work in a regular case like yours. I suspect Neweggs supplier had a bunch of those ASRock around, but they had to reorder the Intel branded one and got the newer price.
I see no good reason to not get the ASRock.
Okay thanks, that helps a lot :slight_smile:
