Hi there ! i m looking for an efficient USB key to travel with me and be my OS. When i travel i need a key to plug on computers that i can use with persistence and keep some files, my email client, bookmarks… Just like the TAILS project. But i won t use TAILS because it s rather restrictive in use (systematic tor filter …).
I tried several models of USB with a debian 13. It was so slow and laggy that i couldn t use it sereinely. And maybe i think it comes from the USB… But on the other hand even bad quality USB works fine with TAILS usually so idk…
Has anyone here already done this ? Thx for your help
There’s also the Hynix T31 but it’s a chungus since it’s an actual SSD with an adapter and stick form factor chassis, but it will also have the best random.
Try the Kingston DataTraveler Max - it’s one of the fastest USB 3.2 Gen 2×2 drives out there, with solid random read/write speeds that actually make running a live OS bearable. Unlike cheap sticks that choke on persistent writes, this one handles Debian (or any distro) way more smoothly.
I could go for the samesung Bar which is my cheapest option.
But as i understand some of your advices, i could use a cheap nvme sdd in an enclosure allowing me to plug it on USB A /C sloths of computers. Not using PCIe connectivity doesn t slow down NVME performances ?
I have not. I bought the samsung for the durability and transfer speed. The speed of the encryption is secondary to me as it needs to be more reliable than fast.
