I'm building a computer with a FX-6300(Overclocking it), and I am planning on using a Cooler Master Hyper 212 Evo as a cooler. I did some research and found out that it comes with thermal paste. I am wondering if it is worth the money to get Artic Silver 5(High-Density Polysyntechic Silver) thermal paste. I am happy with a 70 degree celcius max at full load at any clock speed higher than 4.1 Ghz.
The best thermal paste I think is prolimitech PK-1 Its pretty cheap and is a good performer and should last. Its also not conductive and does not need to set to get the best performace like AS5. Both are good but the PK-1 is newer tech and I think is better. Weather its worth getting is up to you check bottom link to look at the performace difference.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835242019
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-January-2012/1468/5
Ketchup is the best thermal paste.
Acording to that website I posted Mayonaise is the best non thermal paste thermal paste lol...
Thats what I have on a i7 3770 with a H50 cooler. Works like a charm. Highly recommend!
