I originally asked for a PC that used an NZXT case, EVGA GTX 770 and an Intel processor. Anyways, that doesn't really matter much, but which PC is the overall best out of all of them for a $1000 price range?
1.) http://pcpartpicker.com/p/2IarR
2.) http://pcpartpicker.com/p/2IaSO
3.) http://pcpartpicker.com/p/2IbEr
4.) http://pcpartpicker.com/p/2Ib0p
Thank a ton guys, any help would be appreciated :D.
"Best" is such a vague term. Best for what? Best for gaming? Best for rendering? Best price/performance ratio? Best looking? Best to use as a nightstand? You get my point lol
What exactly will you be doing with the machine?
Personally i would go with number three. It will perform well and is well priced.
OHMAIGOD!! I'm such a moron for not saying that :P. Best for gaming, and occasional rendering. Hope that cleared it up, if your answer changes, just say. Price doesn't matter with those, so there's no real need to judge it on that :D
i would say build 2 to be the best for you. Only thing i would change is that if you are gona go sli in the future, get the FX version of that mobo, and switch the psu to something liek a 750W. You are gona end up with a pretty simula price since u went with a platinum certified psu, witch isn't nessessary :)
Based on the overall opinion, I'm going to go with 3 :). It seems really solid, so I am going with it :D.
