Which KM and will it work for my needs?
I need to purchase a KM but I am not sure which one of the 2 is best or if they will work like I need.
I have 3 windows PCs with a single monitor for each that I need to share the mouse and keyboard between.
I need the mouse and keyboard to switch automatically between screens/PCs by just moving the mouse to the right screen.
The display configuration is 1 ultrawide on the bottom and 2 smaller displays side by side above the ultrawide.
Been using a Blackbox Freedom KM but it does not like the ultrawide and there are some areas of the screens were the mouse won’t move to the other screen. its finicky… Hoping the Level1Techs KM will fix that issue.
Will the KM work for my application and if so which version is the best for my application?
Hmmmm the widescreen should not be a problem with the aspect ratio hotkey, but I wonder if widescreen + regular monitor would work… Hm. I might have to test this unless @wendell knows the answer
I have a widescreen 34inch 3440x1440p lower screen connected to one PC, with another 4k 27inch screen above it which is connected to my macbook pro. I have the " 4-Port KM Switch with USB SYNC, Serial Control, & Remote"
It works absolutely flawlessly with my setup for a number of years. As my top PC I have used windows, linux and now macos.
One thing I do see, which I think is odd and very likely MacOS being a pain (As it didnt happen on my windows/linux laptop) is that it doesnt like to sweep from the mac laptop built in screen and over to the external display. Again my windows/linux laptop never had this issue and it think its MacOS being MacOS. I use the Mac with the lid closed and just the external display and have no issues.
I hope this helps a bit.
Thanks for the info, that does help! Are you able to move the mouse from anywhere on one screen to the other and back?
Yep just moved from the most left on my ultrawide up and it landed in the bottom left most corner of the 4k screen… i then repeated it with the right hand side and it landed in the bottom right of the 4k screen… In the middle of the ultrawide moving up it goes into the middle of the 4k screen.
Perfect, that is my biggest issue with my current setup, it won’t do that in all areas. Sounds like it should work for my application. I really appreciate the info!
