Oh D: well that’d be good to know before hand lol.
Well, I’d say test all of what you want to do on each. Benchmark every little thing and compare times. I have a stupid lists of benchmarks (literally just search stupid list of benchmarks) and see what tests do what on your hardware.
Personally I like laptops a lot, but you might want 4 physical cores for something. Also keep in mind that scrapping for hardware is an option.
Well, running on real hardware is a lot better than running on a VM. They are two completely different things that aren’t even remotely close to being similar.
That is true, but I need the vm to at least know it will install correctly. I’ve done the respin process before and sometimes the iso messes up. (Also, just tested them out! The desktop is better than the laptop)
