Which custom router firmware?
I'm finally going to flash my Netgear WNR834B router and use it instead of the one that came with my ISP when I moved.
Both ddwrt and openwrt support my router but I'm looking for advice one which I should use. Or is there another out there that would work on my router?
I have more experience with dd-wrt so I would go there if I was to pick one. But really there's nothing to stop you from picking one deciding you like it or not then going to the next. However I would say look for videos and read all you can to help make your first choice but its really going to be your choice in the end.
