Hello everyone, thank you for clicking on this post. I had an AI help me optimize the title and content, so please bear with me.
I like to write on a computer. My only requirements are: it runs Windows or macOS, can smoothly handle 10 open applications, and the cheaper, the better. I don’t need it for gaming or video editing.
I’ve been looking at used OptiPlex models, mini PCs with N100 or Celeron processors, and even the Mac mini [M2].
If I can keep my desktop budget between $300 and $400—though it might be a little higher—the cheaper, the better. Ideally, it should come with a keyboard, mouse, and monitor that work perfectly together.
If it saves money, I’m fine with building it myself. I just want to find a machine that’s as cheap as possible—but one that doesn’t make me want to throw it out the window.
I would personally look into used low/mid end laptops from the past few years that the price has severely dropped on.
For example, a bit ago I got a Dell Latitude 5430, with 16GB RAM for about $250 from eBay. For me it’s a “good enough to run a severely bloated browser session (and office online) while traveling but I don’t cry if it get’s stolen/broken” sort of thing.
While that version of intel p-core processor (Core i5-1235U 4.4GHz) isn’t technically all that efficient, regardless it ends up having at least a 5+ hour battery life, despite the batteries being around 80% health. I run nixos on mine, and it’s surprisingly solid with performance, I don’t encounter hitches or lag doing things at all.
And while the igpu isn’t for games, it’s more than enough for work.
Frankly my only complaint is the design of the horrible half size up/down arrow keys on the keyboard, and the lack of nearby pg-up/pg-down.
For enjoyable writing, you can just attach your own monitor, keyboard and mouse, like usual.
Beelink SER5 PRO, Ryzen 5500u 6c/12t and 16gb of DDR4. However RAM/SSD/Wifi can all be upgraded in it. However the price doesn’t leave you much room for a keyboard and mouse.
Honestly, any <10 year old laptop will do this perfectly. Depending on where you are, there may be lots of ex-company laptops on ebay - often in great condition. I’m partial to Lenovo Thinkpad T series myself. I’d aim for something Intel 6th gen or better. At that age, you’re basically only running Linux.
There are also Lenovo “All in ones”, where the screen and computer are one. But not the best value.
Feel free to mix and match. I would spend another $100 or $200 on this for some less bottom of the barrel stuff, but yeah this is my best take right now and it is already pricier than you would like.
When I wanted something like this I went with a mini-pc from the HardKernel Odroid H4 with an Intel N97 CPU in it. I have been using it as a little browsing machine for a while now and I really like it, and it was pretty affordable.
Hardkernel have recently released the next gen x86 Odroid, the H5 and it is quite frankly even more impressive. A tiny small board computer with an 8 core Intel N300 CPU, four m.2 slots, (three 2x lanes, one 1x lanes) and a 10gig ethernet port, for only $230. At that price those specs are quite amazing.
You do - of course - need to buy parts separately, like:
m.2 or SATA boot drive
1 stick of laptop DDR5 ram (up to DDR5-4800)
60w AC adapter (between 11v and 20v) (they recommend 15v 4A) The CPU itself only draws ~7W, but the higher power is presumably to allow for m.2 cards and transients.
Some sort of case (they sell simple cheap cases to go with them)
Fan (optional). At 7 watts it can run fanless
A CMOS button battery
I love these little things. I run Linux on them though, not Windows, but I’m sure Windows will do just fine on them. They do have a TPM 2.0 chip.
Their main retailer in the U.S. is Ameridroid, but they usually get supply slowly, and mark it up by quite a lot. Last time I bought an Odroid device I ordered it straight from South Korea and it got here reasonably fast and hassle free.
Of course with this setup you’ll need a keyboard, mouse and monitor, but I figured I’d drop that here in case you - like me - happen to prefer the desktop experience.
If it needs to be Windows compatible (because you need/want MS Office), I’ll suggest either a mini PC (capable new models will be around €300–€400) attached to a used screen (€50 or less) and keyboard (peanuts at a second-hand shop), or a used/refurbished laptop (a reasonable ThinkPad T-/X-series, or Dell Latitude, 5–10 years old should be under €300).
For a Mac, try a used Mac mini, or the Macbook Neo; both may cost somewhat more than a used PC.
If Linux would be OK, a Raspberry Pi 500+ is a good option; they went up in price due to chip shortage but should still be reasonable.
If you are planning to sit at the keyboard for hours at a time, you may want to consider trying different keyboards. Just any cheap keyboard will probably not do; many people like mechanical keyboards, with or without click, while some other prefer flat laptop-like keyboards. Either way, a good one will probably set you back considerably north of €100.
Same goes for a decent office chair: the ones used in companies tend to cost more than €500 new but fortunately you can always find a company that went bust, and sells them for cheap.
Buy a busted-up laptop with a broken screen and use it as a desktop. Anything that has 4 or more cores cores and 8gb of ram should be fine, as long as you don’t go down to celerons or pentiums. other people have given pretty great recommendations on this.
A bit of an unorthodox recommendation would be an old iMac depending on where you are. In Australia anyway, iMacs with decent hardware and beautiful, 4-5k of resolution screens are only around 150-200 USD. And you can put Windows or Linux* on them if you don’t like MacOS.
I really would not suggest getting a PC that comes with its own external keyboard, because likely that keyboard will be a terrible 10 dollar plastic piece of crud. Same for the mouse. Set aside some budget for those 2 parts and experiment. Get something that makes you happy!
* Linux on the 5k iMacs is a bit iffy because of the custom shenanigans apple had to pull to feed that high of a resolution.
