Which case should I use to replace my current one?
I've got the Thermaltake Commander G42 ( http://www.thermaltakeusa.com/products-model.aspx?id=C_00002307 ), but I'm heading to college in a little over a month. I feel that it is too big and that it will take up a lot of space on my dorm desk. I've got a handful of cases I found that I like, but any more suggestions are welcomed. My requirements are that the ATX case must support the CM Hyper 212 Evo and two 2 slot Graphics cards up to 275mm w/ drive cages inside the case. It also must have at least two USB 3.0 ports in the front. The cases I'm currently considering:
CM Storm Scout 2 Advanced: http://gaming.coolermaster.com/en/products/cases/scout2advanced/
CM Storm Scout 2: http://gaming.coolermaster.com/en/products/cases/scout_2/
Fractal Design Define R4 Blackout: http://www.fractal-design.com/home/define-r4-blackout
Fractal Design ARC Midi R2: http://www.fractal-design.com/home/product/cases/arc-series/arc-midi-r2
NZXT H230 (Black): https://www.nzxt.com/product/detail/130-H230.html
Thanks in advance for any help!
Edit: My build--> https://pcpartpicker.com/user/reftyuy/saved/Vvf48d
Cases are a personal reference, henceforth why some people go for the superman cases while others go for the clark kent and thus the style of the case is only up to you to decide, however due to the fact you will be living in a dorm and thus will probably have a room mate. you may want to consider the sound dampening of the case, it's going to be a small room and your going to have another person with you, so if you can avoid as much of the strange computer noises it would probably lead to a better dorm environment.
