Can someone please tell me where to find ‘260 pin [sodimm] slot headers’ for sale?
My google-foo doesn’t seem to be good enough for this challenge.
Alternatively, is there a particular syntax needed, on digi-key, or some of the other hobbyist sites to find parts you don’t already have?
Hi, I just checked DigiKey, and they seem to have all of the various memory sockets under the “Inline Module Socket” category.
I selected the 260-pin option, and as of writing, there are about a dozen products that are in stock.
I almost never have luck searching for a particular component like this on google.
I’ve found the best way to search for an unknown component is to use the simplest term possible on a distributor’s site, and look through the most relevent sub-categories.
Thank you! You are an absolute lifesaver!
It even went down to five in stock, between your visit and mine!
Again perfectly anwered!
Thank you!
No problem! I’m glad I could help.
