Funny, I was just tweaking and messing about a few days ago.
CPU : i5-2500 (non-K) with BeQuiet Dark Rock Pro 3
MoBo : MSI Z77A-GD65 Gaming
GFX : 2x MSI GTX 770 4GB on factory OC (GPU-Z says 1175.8 MHz on both)
PSU : BeQuiet Dark Power Pro P10 850W
Case : Cooler master Storm Trooper with 5x BeQuiet SW2 120mm intake, 3x BeQuiet SW2 140mm exhaust, all controlled by the motherboard
Storage : 4x SSD (3x 850PRO 256GB, 1x 840EVO 1TB) for a 1.75TB total, more room on the NAS.
Fan profiles :
CPU : 12.5% until 40°C, then linear increase until 100% at 70°C
GPU : stock MSI profiles (34% until 50°C, 38% at 60°C, 42% at 70°C, 47% at 80°C, 75% at 90°C, highest I’ve seen was 88% at 93°C)
case fans (voltage controlled) : 40% (idle) until the CPU reaches 50°C, then linear increase until 100% at 75°C
Temps @ 18°C ambient :
GPUs idle : 25°C (top) and 22°C (bottom)
GPUs load (10 minutes in Furmark) : 93°C and 82°C
CPU @ stock speed
idle : 22-24°C (throttles down to 1.6-1.7 GHz @ 0.960-0.968V, multiplier keeps jumping between x16 and x17)
load : 39-40°C (3.4GHz @ 1.208V, x34 multiplier)
CPU @ 4.1 GHz (x41 multiplier, 1.344V)
idle : 35-36°C
load : 52-54°C
I usually run it at 3.8GHz and 1.344V, which is the default setting the OC Genie gave me. That gives me 31-33°C on idle and 45-47°C on load, which basically means that the CPU never reaches that 50°C mark where the case fans would come off idle.
While I don’t really notice instability higher up or at slightly lower voltages, I don’t want to take any risks. The OC Genie’s overclock has ran perfectly stable for over 2 years now, so I don’t want to mess anything up. The PC is used for gaming as well as for work (I work from home) and needs to be reliable for the latter.
I’m planning to upgrade the CPU (and hence motherboard and RAM too) this winter, but not sure what to upgrade to.
Z97, Z170, X99 … sigh.
