Whats the difference?
Hey,
i was looking at these two cards (both r9 270x) and the asus model was priced at 187 pounds while the saphire is priced at around 150 whats the difference?how much more frames will i get if i get the asus?or is asus just pricing it higher?
Thanks
-Lee
        http://www.overclockers.co.uk/showproduct.php?prodid=GX-328-SP  (sapphire)  http://www.overclockers.co.uk/showproduct.php?prodid=GX-324-AS  (asus)
Asus Radeon R9 270X DirectCUII TOP 2048MB GDDR5 PCI-Express Graphics CardSapphire Radeon R9 270X Boost OC 2048MB GDDR5 PCI-Express Card
Only differences are the cooler and the clock speed, and by overclocking you can get the Sapphire to same clock speeds and beyond aswell. They have the same performance, but one might run couple degrees cooler than the other. I'd get whatever is cheaper.
There pretty much the same. The better one would be the asus out of the two because you would be able to overclock it much better than the sapphire version.
Well the difference would be more the cooling over all, as the ASUS card has a superior cooler. I have seen from some benchmarks that the ASUS R9 cards has been performing a little better FPS wise out of the box than some of the other competitors. Sapphire is just as good though and I'm sure the FPS increase that the ASUS card has is only by 1-3 FPS. You are more over paying for the better cooler and the ASUS customer service and warranty they provide. Also the ASUS card probably has better quality parts. So basically it's your choice whether you want to spend the extra 40£ to obtain better quality.
