What's the best way to straighten bent pins on a Mobo?
Panel connectors pins 1 an 2 are bent and also both drct pins
damn, whatever you do be careful, bending them back can break them.
maybe heat it up to make them softer then try using a credit card to pivot them back? good luck man.
take a ball point pen and remove the inside workings slip the writing end over the pin and be gentle.
Use a mechanical pen put the pin inside the pen and stand them back up.
They aren't super fragile but you only wan't to do this once
