What video card do i need for bf4?
Motherboard: MSI FM2-A85XMA-E35
Memory: 8gb 1866 Performance Memory
Tower: Fractal Arc Midi R2 Case
Power Supply: Fractal Tesla R2 650W
SSD: Kingston SSDNow V300 Series 2.5″ 60GB SATA III Internal Solid State Drive
DVD Burner: LG 24X DVD Burner
OS: Windows 8 64-BIT
HardDrive: Seagate Barracuda 1TB
Keyboard88: Logiteck K120
Mouse: Logitech g600
HeadSet: Plantronics GameCom 780
what video card do i need for bf4 and do i have to select msi video b/c my motherboard is msi?? or i i just buy the R9 270x or R9 280x?
Can buy any brand you want, ran the beta just fine with my i7 and 7870. 7950 is probably worth it.
No, you don't need a MSI card, and what's your budget?
Also, wait for the 290x and BF4 to be released with Mantle.
nvm... I didn't read the whole OP.
Things like monitor, how much eye candy do you want, what FPS, budget all play into what you get.
your on fm2 so... whatever's on the apu? you don't need any more, unless you have an athlon, inwhich case what do have now
You didn't say what CPU you have. That would help, if you could, kind sir.
Minimum card I would suggest a radeon 7770. A 7979 would max it out, and a 7870 would be a good compromise.
I HAVE AN 6800K APU
MY Motherboard: MSI FM2-A85XMA-E35
my budget is no more than 200
7950 :D
Here is a good one.
For under $200 http://www.newegg.com/Product/Product.aspx?Item=N82E16814127761&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
you need to be more specific about what you want (ie: settings, resolution, framerate) you're asking what you "need" you don't need any more just to play the game
http://www.tomshardware.com/answers/id-1831427/amd-radeon-270x-sapphire-7950.html
These guys think a 7950 is better.
that good 1 but i dont know if my motherboard is compatible with that card b/c i dont see it in there site when i went to msi
my monitor resolution is 1680x1050
i need video card to play bf4 and to stream it without any problems
framerate dunno i am not a pc guy
It has more vram, but they perform about the same in-game as far as I can tell (feel free to give some benchmarks if I am mistaken here), so it might be worth it to grab the newer one. Should have native 4k supportand true-audio (or whatever, if you want that). However, the 7950s right now come with three free games, so that is another thing to take into consideration.
Either a 7950 or a R9 270x should do it. If you can wait, nVidia should drop their prices around November, and I would expect the 760 to be placed around $200, if you want to go that route, but a 7950 should suite your needs more than fine.
According to the article published on here last night, the R9 270X is basically a rebadged 7870. The 7950 you ordered is more powerful.
A 7950 will have native 4k support also. Both the 270x and the 7950 will not have true audio (Only the 260x and 290(x) will).
If the 270x is a re-branded 7870, we already know a 7950 is faster.
ok thank u evey1 i will look to different site and prices. maybe ur right maybe black friday or cyber moday specials on video cards
get a 7950 that is on a sale.. its a better performing card then a 270X
