I need a little help with what type of motherboard I should get. This is my first time building a PC and i'm not sure what type I should get. I am looking for a board that has WIFI and a optical slot. If you have any suggestions please leave a comment. If it helps here is a list of the parts i'm getting.
This is a lttle off your topic but what is the Use case for this because that is a powerful CPU and a soso gpu. Gaming? Editing? Recording? Just lemme know cause even so that helps decide what mobo to go with. If you dont feel like listing that for whatever reason then I will say look for Z97 chipset at least.
I need it for gaming, editing videos, streaming/recording videos, and Photoshop. Right now i'm looking at a ASUS Z97-Deluxe and you said my gpu is soso, do you think it could run games like GTA?
ITX boards are the only motherboards that tend to have Wi-Fi cards built on to the motherboard. so if you Wi-Fi is something you want without spending an extra 50 bucks you'd have to go with a Mini-ITX Motherboard.
As for an Optical Drive. i don't know why you would want one, considering everything now-a-days comes digitally. but most cases are ridding of them. if you really must have a Optical drive you'd have to go Micro-ATX or ATX. but those motherboards don't have built in Wi-Fi. so you'd have to buy a separate Wi-Fi card.
well I will just say the 980Ti I have I use to game at 1080p (please noone comment on the res lets stay focuses) and maxed out it is a heavy load on even that card. Yes still playable but scale the card down to a 750 and you will be cranking down settings only to get probably under 60 fps. Now this is me assuming more or less as I dont have a 750 myself but I thought I would share that with you. I would look for an ATX Z97 board such as this one ( http://www.newegg.com/Product/Product.aspx?Item=N82E16813128706 ) and get a better gpu such as the 970 and if the budget allows a kit of 2x8G Ram would help you a decent amount over the listed one.
Im not the best of the best either so if someone else tell you different or even from reading my post you can never beat your own research. Best of luck to you! I wanna see the finished product posted here though haha
Asus Z97 Pro Wifi Asus Maximus VII Formula Asus Z97 Deluxe Msi Z97 Mpower Max AC Msi Z97 Gaming 9 ACX Msi Z97 Xpower AC Gigabyte Z97X Gaming G1 Wifi BK
But yeah these particular boards, do come with a premium price.
Here's some stuff i recommend. i checked out the ATX Wi-Fi boards and they are rip-offs to holy hell. almost the price of X99 boards. you're better off just getting a good board then getting an add-in wifi-card.
4690k is a good all-around CPU for anything you need to do. the i7 us really a waste of money if you aren't doing some professional tasks like video edting and stuff. your games won't really use those extra threads.
Purpose of gaming ~ high end cpu + low end gpu.... Makes zero sense. Anyways, something like the Asus Z97-A is a great board to pair with a 4790k and has optical output. For wifi just grab a usb or cheap pcie wifi adapter.
Hey! I just wanted to let you know that my new PC is work great. I have been using it for a couple of weeks now and it's fantastic. Thank you for the advice, I really appreciated it.
