i need help picking a monitor for my build i need something that hd or good looking
These are cheap IPS panels:
http://pcpartpicker.com/part/dell-monitor-s2240m
http://pcpartpicker.com/part/viewsonic-monitor-va2249s
Worth considering.
what sizes are good for covering your peripheral
Most 1080p monitors are 21" to 24", which is a decent size. There's a wide availability of 23" which are still reasonably priced.
The two monitors I listed above are less than 23", but if you were to spend $20-30 in addition, you can find the 23" variants of those same panels. 23" is what I would aim for, personally.
e.g
http://pcpartpicker.com/part/dell-monitor-s2340m
OK, thank you
OK, thank you
