Hi all.
I don't suppose you've seen my previous post about if my new PC was stable.
Well, I've had a thought. (uh oh)
I'm trying to save money as much as I can, and I wondered if I could get a smaller PSU.
I was first looking at a CX600M, now I'm looking at a CX430M.
Here's the specs:
AMD FX6300 w/ Stock cooler
Corsair DDR3 8GB
ASUS M5A97 2.0 (Not LE)
Case, 2 DVD drives, a hard drive, all that sort of crap
And the main thing I'm worrying about the most:
Gigabyte GeForce GTX 560Ti OC (2GB DDR5)
What could I use? A 600M, or a 430M? (If you say 500M I'll go for the 600M, as they have almost identical prices!)
Thanks again!
What is your budget, and what country/currency?
About £350. UK country, GBP currency :D
I meant for the PSU, unless you're looking to spend all 350 zed on it ;)
Ah, my apologies. Heh, no, £350's for the whole lot! I'd say, uh, £55-£60?
I've had a butcher at some others, but I'm not sure. I've heard XFX PSUs are excellent, but they're so expensive. I've been looking at the CX PSUs because they're cheap but not a few bits of metal banged together with someone's face.
Well, one thing, is I've just seen an OCZ PSU, 500w, but it's ony 80+ certified, whereas the CXs are 80+Bronze.
I mean, if you want to offer any other PSUs that are in my ~£60 price range, go right ahead, and I'll see what I can do.
i would recommend the XFX PRO 550W core edition 80+bronze.
http://www.amazon.co.uk/dp/B004RJ8EKI/?tag=pcp0f-21
this is a great psu for a realy nice price. 550W should be more then enough for your needs.
Grtz Angel ☺
Ah, excellent! Thanks a ton, its actually cheaper than the corsair PSUs!
That shall be the one that I'm going to buy. Thanks again! :)
yeah the only con is that its not modular, but who cares, you need wires anyway ☺ its a seasonic inside ☺
