What OS to use for virtualization homelab? XCP-NG, Proxmox, Smart-OS, Harvester or other?
Hello.
I recently bought a minisforum Hx90 with the Ryzen 5900hx and 64gb ddr4.
I am hoping to make it a homelab for playing around with windows server/ clients regards to learning how admin tools work, as well as a game server or two, a few home network services and a file server running on it.
I have a 2tb high endurance MSI m.2 has the primary drive and a 3.84 tb samsung pm863a as secondary drive. There is room for an additional sata drive if needed.
I have seen the widespread coverage of proxmox as a good vm os, as well as XCP-NG.
However, it seems other solutions like Unraid, Windows Hyper-v server 2019, Harvester, Smart-os, Xenserver, Xen, Overt and Danube Cloud exist?
https://alternativeto.net/software/vmware-esxi/?p=5
In your opinions, which is the easiest to use and which of these solution that also allows the IGPU/ or a dGPU to be passed thought to a vm? I have a bootleg copy of ESXI somewhere I could try loading up but beyond that I really don’t want to pay much for licensing if it can be avoided.
Additionally, I currently have a Asustor Nas but am looking to possibly set up a server with a large bank of HDDs in the future, and possible a Dgpu. I have heard freenas and a few other Nas OS’s also allow VM’s. Would it be better to host VMs on there?
Thanks for reading!
Josh
Hiya Josh,
I think unRAID might be the easiest, though I’ve no direct experience of it. I’ve been thinking of trying a dedicated VM os myself and initially thought of Promox. Lawrence Systems (Tom) recommends XCP-NG which has better management and expansion facilities I believe, however I bow out to those that are more in the know!
Just if interested, Unky Joe showed Proxmox only today (time stamped if helpful): https://www.youtube.com/live/kND5cgVQtto?si=vssny26OgY0EM5Wp&t=2607
I recommend installing Proxmox and making a VM for each OS listed above. Then check what you like the most. That’s how I did it. Most of them are free, so just get the image and pump it into the VM to boot.
Have fun exploring :slight_smile:
I went with plain old Xen (w/ Debian dom0), I’d cross it off your list.
It’s cool and interesting. But it’s not going to land in the top 10 easiest to use options. It’s more of a primitive that you could use to build your own solution with various other technologies, rather than a solution in itself.
XCP-ng wraps up Xen into what looks like an approachable solution.
Wow that’s good timing, thanks for the info!
Did not know that, thanks for the input!
Proxmox is by far the easiest for VM’s. Xen if great if you have a more enterprise environment but for the average homelab proxmox is the way
As previously stated by the people xcp-ng or proxmox, have been rocking xcp-ng for both work and home lab for the past years, very happy with it but i think proxmox might have a better approach of pci passthrough from what I have seen (not tested)
Proxmox and XCP-NG seem like the best options for your case. Assuming that Proxmox is popular and has a strong community, I would go with it.
Proxmox is pretty easy to configure and use. It makes creating templates and cloning from those templates easy. xcp-ng is probably just as easy to use but the web front-end (GUI) is set up in a discrete VM whereas in Proxmox the hypervisor and GUI are integrated. I have barely begun to learn xcp-ng.
