I regularly use ChatGPT, Gemini and Claude for research and documentation. Copying conversations manually break code blocks, tables, and formatting, especially in longer sessions.
How do you currently archive useful AI conversations?
Note: if possible, i would like to export the AI chat to pdf or word.
Use a harness, export chats as is in full.
Opencode has a webUI if you prefer animations and “default” Chat UI most LLMs have.
/export saves chats in opencode and claude-cli
codex is a PITA I tell the model to copy the chat log to markdown
My harness makes per turn annotation so I made a quick crate to clean up backend and export chats(it autonomous so mostly harness<->model logs)
I’m unaware of web UI setups, I don’t use them.
If you mean AI Conversations on the web. I have a few suggestions:
For regular conversations, i usually use Ctrl + P to save as PDF. Or ask AI to create a word, PDF file directly.
For long conversations that require nice formatting, i usse this extension to export: AI Chat Exporter
Note: This is chrome extension, so you need to check the vendor’s requirements first, but it’s basically been approved by Google
