The use case for my PC is going to primarily for video editing using premier, with gaming as a secondary use.
I’m going to be using a lovely 4tb gen4 m.2 SN850X as my main large drive, a big 16TB HDD for storage of completed projects (video), and I’ll have a Optane 900P 280GB with 4k writes that blow the other two out of the water.
I’ve been looking at ways to use it as a cache for the larger SSD, forcing Readyboost is an option but it can be iffy about keeping it’s settings and deletes the cache on reset. Primocache doesn’t care how big a file is, so could end up slowing things down by caching larger files that will be read sequentially (unless I’m misunderstanding how it could be set up).
One option is to use it as a boot drive and where I install non-gaming applications. Firefox loves a good fast cache and if adobe needs a scratch disk (will have 64GB ram) it’ll be perfect for that as well.
Ideally I’d like to optimally set it as a cache and not need to mess with it in the future, and the above conclusions are ones I’ve made after a bit of research, but you guys likely know way more than the average internet post or page. If anything above is wrong please do correct me!
Any advice you have is what I will likely end up doing. I look forward to seeing what you all have to say. ![]()
Edit: Will be using Windows 11
Edit 2: Selling it is also an option
