it seems like I have been convinced to get open back headphones because they are better for gaming. I was suggested Massdrop x Sennheiser HD 58X Jubilee Headphones and a soundblaster G6 because of my use case.
the next step up would be getting into analytical music listening and would cost about $700-800 for DT1990s w/ schiit heresy and modi. which is more than what I want to pay and need.
also some people in a audiophile discord said the same thing. seems like a common agreed upon thing.
answer: Open is spacious, soundstage and imaging is detailed more and you pinpoint everything way easier instead of closed, which is being all at onceā¦ muddy and just full of bass. Open makes your game feel way bigger, closed makes it smaller.
So because you saw a video now you remember that you donāt actually need isolation at all?.. ok.
And all of a sudden that is important?
You know what, go with the Sennheiser. Youāre most likely not making a mistake with those. Alternatively if you want open fun, big soundstage and a good amount of bass, also look at the Philips Fidelio X2.
No clue what people see in that soundblaster thing. But if you found a reason to go with that, cool. Everyone has to start somewhere.
I would prefer isolation but dont need it. I wanted it because sometimes people in my house are loud and I donāt want it to effect my gaming. But it seems open headphones are better for competitive gaming.
I think the soundblaster dac/amp is because I mentioned consoles. I would prefer another that does the same with optical audio in, but it seems it will fulfill my needs other than optical audio input. It also is $112 which is not bad.
I used to play Q3 in a non-professional competitive manner, and did great with a set of closed back Sennheiser HD280 Proās. Never had issues figuring out where the footsteps were coming from.
Some closed back head phones will have a wide sound stage, some open will have a narrower sound stage.
Donāt think going with a set of closed cans is going to be inferior to some open backs for gaming. If you have a noisy house, find decent set of closed cans and donāt over think it. Itās not a baby; you can sell them if you donāt like them and try a new pair.
Like I said, the FiiO D03K is cheap and converts optical into line level analog. And behind that you can hook up any amp you want. Doesnāt have multi-input or gamery malware to go with butā¦
