I am in the market for a good quality PC headset. I have a blue yeti for mic so no need for a good mic or any at all really. I would like it to work on xb1 and or ps4 as a nice extra feature, but not a must. Would prefer wireless, but doesn’t have to be. Any suggestions? Price isn’t an issue thankfully.
They clearly define their testing methodology and they are rather neutral about their reviews. But don’t ever trust any one source. Look up multiple reviews and see how different or similar they are.
Philips has some good cans too. The SHP 5000 will ocasionally go on sale for $50-60 on newegg. It can be hit or miss some people don’t like fabric around the cups
With Sennheiser, you can just get replacement pads and headband when it happens (in like 6 years or more, depending on climate).
The Sound BlasterX G6 works on all sources you could possible have. Has good reviews and is competetive to similar products at its price range.
With a dedicated DAC/Amp you are open to all kinds of headphones.
No, having a headphone amp just opens up the options.
I had a beyerdynamic DT-770 (250 Ohm) on loan and I had to crank the volume of my onboard to 80% to get acceptable levels. Meanwhile my headphone amps easily push considerable volume with the dial barely past the 10 o’clock mark.
Any headphone between 12 and 100 Ohm will be just fine from onboard audio. Can’t speak for consoles.
First off you linked the Edition, not the Pro. And secondly, the Edition has 32 Ohm (which any mp3 player can drive), 250 Ohm (which any mid-range main board can drive), and 600 Ohm which… yes, you need an Amp but us frankly not necessary.
The DT 880 Pro is 250 Ohm only, but the only thing you get is a different cable (which you can also choose in the Edition variant), and a tighter fit. So unless you like both of that, the Pro is unnecessary.
Besides, personally I don’t see the point in getting the 880 in any variant. It’s a semi-open which IMO doesn’t really make sense. Either go full open with the DT 990 (Edition or Pro) or the DT 770 (only Pro available).
I mostly mentioned it as it allowes to hook headphones to all modern consoles where it will give you an upgrade over the controller integrated audio.
They are mostly the same, some nuances are different. Still a mistake on my end.
IMO the 880’s are the best choice for home use.
The DT-770 has elevated bass, for competetive gaming a disadvantage as it could drown out footsteps. It being closed back could also get a “hot ear” situation during long sessions.
The DT-990 has the Beyerdynamic-V sound right in the ears. I personally dislike the elevated treble as Beyer has it.
nothing fancy, but I really like my hyper x cloud II’s. As far as I know they work on the ps4/xbone and the mic is detachable if you don’t want it in the way.
Only thing I’m iffy on it is it’s lack of noise cancelling but that may not be an issue.
I can’t speak for sound quality since I have nothing to compare them too, other than the razer man of war which was in my opinion trash.
