I’m planing my PC upgrade to a Threadripper 7970X or 7975WX. As my current cooling solution won’t work with the sTR5 CPUs I want to go custom loop for the first time. I have tried to compare the available waterblocks that are compatible with sTR5 but there don’t seem to exist any up to date reviews comparing the latest blocks.
I need help deciding between these blocks:
EK-Quantum Magnitude sTRX4
EK-Pro CPU WB sTR
Alphacool Eisblock XPX Pro Aurora - Full Brass Chrome Digital RGB
Alphacool Eisblock XPX Pro 1U
HEATKILLER IV PRO for Threadripper COPPER NICKEL
or maybe you have an even better block you would recomend?
I understand that you need help choosing between some blocks. I use the AMD Threadripper 3X block with the EK-Quantum Magnitude sTRX4 - Full Nickel block, one of the best blocks I have ever used. EK informed me that the block’s solid mass and material give it more physical weight than any other block from EK or most competitors. Due to this, it can disperse heat effectively and provide excellent results. I have read many reviews on Alphacool blocks, but the research never seems to add up. I also looked into the Watercool block, but it was not present when I tested. I am partial to the EK brand, so I do not want to sound biased, but out of the blocks you listed, I would say that EK-Quantum Magnitude sTRX4 - Full Nickel is the best option available.
