I'm going to watercool my computer. And i have a choise between these cooling fluids.
AquaComputer Double protect Ultra
EK - Ekoolant
Feser One Cooling Fluid
So, which one?
EK - Ekoolant
So, which one?
I'm not an expert, but I've heard that distilled water is better than any other coolant.
I like Mayhems coolant, but it depends on what components you are using. Feser, especially their red coolant, will stain your tubing and linger stubbornly in your radiators. Just to note, almost every colored fluid will dye flexible tubing. To an extent, Mayhems pastel gets around this by not using a dye in their fluid, instead using very, very small particles of colorant. It is a good idea to use at least an anticorrosion additive if you aren't using a premix or a concentrate (in the case of using distilled water.)
