This might be hardware, but I see it as an audio category.
Is there a standard to run a DAW? I don't think I would need like 8 gores or anything crazy like that and even a PPC G5 would probably do, I'm just wondering if theres any real specifics when in working with music (aside from good sound).
If nothing else my G5 project will turn into a music station lol. If I can't do that project at all.... I have pentium 4's and athlons by the multiple..... And an i7 870 with no ram or GPU.... Shit.
Cores > CPU Speed > Memory bandwidth > Storage speed.
If you're doing nothing but recording tracks,
Cores (almost)= CPU Speed.
I did some tests in PT last year regarding memory bandwidth and it made an astonishingly large impact on number of plugins. This is really only relevant if you are doing post-production, using massive sample libraries, or editing very long compositions.
All other components the same, RAM speed yeilded: 3000 MHz 1340 Dverbs
1333 MHz 945 Dverbs
2250 MHz 1100 Dverbs
Remember, DAWs have been around since at least the 1980's, so there will be something you're able to run. Try Reaper if you're having problems running something else. It's pretty light and feature-rich, indeed.
