Hello everyone. I will display the spec’s of my PC down below. On November 3, 2024 I recently purchase a Western Digital Easy Store 20TB Hard Drive that I snagged for $299.99 from Best Buy. On the same day I decided to shuck the drive since Western Digital uses an external bridge connector from the SATA connector to the Micro USB Type-B. My plan was to have a high capacity drive inside my desktop for backup and media content on my personal rig. However, over 2 months from now I recently open HDD Tune Pro and realized an unwanted attention that is bugging me for a while. Mind you that the drive is brand new and I do not access the drive for a while.
I have currently did some minor changes on Window’s Power Settings Option, most notable the USB selective suspend from enable to disable.
As for the Device Manager, the Write Caching is enable but the Power Management tab option is nowhere to be found. I believe this has to do with Window’s 10 & 11 power integration for easy of use for many hardware peripherals.
Lastly, my ASUS BIOS USB Power Saving was disable and the SATA configuration was set to AHCI. I won’t be doing RAID on my main computer.
After the changes were made on the Windows boot my WD 20TB was sitting on 867 Unsafe Shutdown. After a Bios change and a full proper shutdown & reboot, my WD 20TB is at 868.
