So every boot I get a popup once the network comes on line. Header shows Index of and shows the following:
Index of /
[ICO] Name Last modified Size Description [TXT] check_network_status.txt 27-Jun-2013 10:13 25 Apache/2.2.15 (Red Hat) Server at nmcheck.gnome.org Port 80
Attached is a screenshot. I just want to stop it from popping up all the time. I am not finding anything via googlefu.
It's just the bounce site for Gnome network manager connectivity check. If you don't want it, kill nmapplet, it will remov ethe networkmanager applet in the top bar, but it won't check connectivity at startup any more.
Only thing i had different on this box then the others was a bridge. I had this setup so my VM for PCI passthrough got a local ip from the DHCP server. I deleted the bridge and network profile, then created a new profile. I didn't create another bridge. Issue no longer occurs. Not sure if that was the root cause though, I have been using that bridge for a long time, this just started to happen since January.
