Bought this used off ebay recently. Everything was going fine until a couple days ago I’d switched around some drives and pcie cards. I was modifying my Proxmox config to use the new network card I’d installed and the motherboard powered down. The Standby Power and BMC Heart Beat LEDs light but the power switch doesn’t do anything. I get a login screen for the BMC but I’d never messed with it and the recycler I bought it from didn’t reset the password. All the components work fine in other systems, 5900XT, 64GB ECC Ram, Power supply. I’m led to believe that if I bought another one, an X570D4U, or another of the BMC Roms I could swap it and regain access.
I could possibly flash the BMC via serial but I don’t have a serial to USB adapter and haven’t found a system with serial output.
Any ideas?
Does the X570D4U have fewer problems?
Flashing the BMC probably won’t do much for it not booting, other than giving you a webui to observe the lack of booting. These boards are definitely temperamental though, do a cmos reset and maybe leave it without power for a few hours. Also try booting it prior to the BMC coming up (eg. flip the psu power on and start mashing the case power button)
I agree with the above. These boards are finicky.
While I haven’t experienced this per say, I agree that factory resetting / pulling the CMOS battery, would be first steps here. I’d also make sure it’s the latest BIOS and BMC versions.
In addition, I would absolutely log into the BMC and verify all is well. There’s a system error log there that tracks failed boots, though not a lot of info.
The key thing I can think of is the BMC feature called '“Watchdog.” If Watchdog is enabled in the BMC, your OS needs to know and support this. This is because the BMC will check for a heartbeat at those intervals and if your OS doesn’t respond, the BMC will reboot or shutdown.
So the BMC does play a role in booting if everything is not set right. So read up on the BMC, login with default credentials (and change them!!), and verify no real issues or errors.
I’ve previously had other ASRock Rack mobos that stopped working and had all sorts of BMC errors. A new BMC chip (they are in serviceable sockets!!), and a special flash their support gave me, restored that board.
