PC1 is my personal Desktop with Windows 10
PC2 is my work laptop with Windows 11
Both are connected to the KVM.
Webcam is connected to the front USB3 port, and other peripheries (mouse, kbd) are connected to the rear HID ports.
When I connect the webcam to my laptop directly to the usb 3.0A port, it is correctly recognized. However, if I connect to the KVM, it is only recognized in PC1 and not in PC2. Nothing appears in the Device Manager. I have used a powered USB 3.0 dock and attached the dock to the KVM, and connected the webcam to the dock, but same issue persists. The webcam is only recognized in PC1.
The webcam is Logitech C615.
Would there be any way to fix the issue?
I do not have Logitech software/drivers installed manually in neither of the PCs. It is a simple plug and play in the PC1. In PC2, I cannot install any driver by my own as I do not have the admin privilege. Would that be an issue?
If I plug the webcam in HID port, PC1 freezes when I try to open the “sounds” console. Stutters, and connection becomes extremely instable. PC2 does not recognize anything.
I’m a little confused by what’s PC 1 and what’s PC 2.
Your title is “Webcam not recognized in PC1 but works fine in PC2”
Your post says " if I connect to the KVM, it is only recognized in PC1 and not in PC2"
Regardless of the numbers, it’s working with the personal PC, but not on the work laptop right?
