I bought the Anker Powerconf C300 webcam, but it appears all I get out of programs on Linux is a 640x360 YUYV RAW output. On Windows 10 I’m able to get the full 1080p60fps output.
Here’s the output of v4l2-ctl -d /dev/video1 --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'MJPG' (Motion-JPEG, compressed)
Size: Discrete 1920x1080
Interval: Discrete 0.017s (60.000 fps)
Interval: Discrete 0.033s (30.000 fps)
Interval: Discrete 0.067s (15.000 fps)
Interval: Discrete 0.100s (10.000 fps)
Interval: Discrete 0.200s (5.000 fps)
[1]: 'YUYV' (YUYV 4:2:2)
[2]: 'H264' (H.264, compressed)
Interval: Discrete 0.040s (25.000 fps)
Interval: Discrete 0.050s (20.000 fps)
[3]: '' (35363248-0000-0010-8000-00aa003, compressed)
Running v4l2-ctl -d /dev/video1 -V I get this:
Format Video Capture:
Width/Height : 640/360
Pixel Format : 'YUYV' (YUYV 4:2:2)
Field : None
Bytes per Line : 1280
Size Image : 460800
Colorspace : Default
Transfer Function : Default (maps to Rec. 709)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Limited Range)
Flags :
So then trying v4l2-ctl -d /dev/video1 -v width=1920,height=1080,pixelformat=H264 and then running v4l2-ctl -d /dev/video1 -V again I get this:
Width/Height : 1920/1080
Pixel Format : 'H264' (H.264)
Field : None
Bytes per Line : 0
Size Image : 4147200
Quantization : Default (maps to Full Range)
Flags :
But then running OBS, Cheese, Teams, anything in Chrome to capture the webcam it goes back to this output:
Field : None
Size Image : 460800
Flags :
Anyway to force using MJPG or H264? Or make those the default that applications use? I’ve seen some others use v4l2loopback for similar things, is this the solution?
