big question an sorry if i sound the noob but her goes
my next two pop builds are going to use wayland compositor
over xorg an one will run on a
nvidia gpu an the other an AMD i need gpu an fans control for both im currently
using xorg an for when GWE doesnt work i use a custom .desktop file in the autorun folder to control
the fans at an during boot an login an when ever GWE fails
[Desktop Entry]
Type=Application
Exec=nvidia-settings -a “[gpu:0]/GPUFanControlState=1” -a
“[fan:0]/GPUTargetFanSpeed=75”
X-GNOME-Autostart-enabled=true
Name=nvidia-fan-speed
what i want to know an need help with is this 1.can this be edited to cover
variable temps an speeds ie 50% speed at 30c an so on rather then one fixed speed
an for the AMD gpu can i make a similar .desktop file to control auto start , fans an temps , an clock
speeds i need to know if it can be made exaclty how to write an formate the file.
the nvidia build will run on my gigabyte 1660 super oc
2nd on my powercolor 6700xt fighter
