In a couple of Level1Techs build videos, I think I’ve heard off hand references to mounting a three fan radiator in Silver Stone 4U cases. But I haven’t actually been able to find any video or pictures showing where and how this is done.
Any pointers or links would be appreciated.
I’m building a new rack mounted system in a Silver Stone RM41-506 case, in large part because I want a number of hot swap spinning disks for easy offline and offsite backups. With only a couple 80mm fans, the airflow probably isn’t going to be that great. I have several years of experience building and working with custom water loops for cooling lasers (including multi kilowatt lasers). Water loops can be super easy if you know where on McMaster Carr to look for the right push-lock parts. So I’m thinking that I might give a custom water loop a try.
Are you using the Drive cages? If not remove them and then you have plenty of room, if so maybe you can create a custom mount that brings it above the motherboard but still gives you room to plug in drives…
The front accessible drive cages are one of the main features I’m after for this PC. It’s an upgrade from an old HP-Proliant DL380 G5 that I picked up used five or six years ago. I’ve really liked the hot swappable RAID and want something similar (but ZFS based) in the new box.
I got the case in and the computer built, though I’ve currently got just a AMD Wraith Max CPU heat sink installed at the moment. So no crazy overclocking. (Yet?)
It looks like I might be able to fit a two fan radiator between right + center drive cages and the memory (center) and PSU (right). Though I may need to get creative with some cable routing.
