Anyone wall mount some of their old GPUs for a display? I’m thinking about some hooks or something but I can’t find any that seem wide enough. And I don’t want shelves, I want them bare. Help?
Pull everything but the PCB and chips off, and frame it?
This looks cool
I’m more inclined, to setting up shelving, for older GPUs
This was done with some of those furniture tacks and a few leftover finishing nails from a project. Super simple, super easy. Not fancy.
Command strips may also be strong enough to accomplish this, but wasteful.
nah! not really seen it done well…
especially like above.
to me you would need to cover a whole wall with everything packed as tight as possible to make it look like something other than a bunch of pc parts ducktaped to the wall ![]()
why not mount them all separately in shallow cabinets or deep frames, under glass. then each becomes its own thing rather than as i said e-waste you stuck to the wall.
