Hello all,
I have a home network setup as in the image
I intend to increase the network security and to improve latency, so I have decided that is time to implemet VLANs but I am a noob so I am asking your help.
My router is Asus RT-AX86U running Asuswrt-Merlin and seems that it can support VLANs in the LAN->IPTV tab. On the WiFi I have several sensors and Devices connected to MQTT server.
My T1500G-10PS switch supports VLANs
To this switch I have devices connected from the default network as well as from IoT and Security.
I need your help on setting up the HW and SW to get the network setup as in the first image considering VLANs.
My Ubuntu server netplan is network: version: 2 ethernets: enp6s0: dhcp4: false dhcp6: false addresses: ['10.0.1.2/24'] routes: - to: default via: 10.0.1.1 nameservers: addresses: [8.8.8.8, 8.8.4.4] enp5s0: dhcp4: false dhcp6: false addresses: ['192.168.1.1/24'] vlans: IoT: id: 2 link: enp6s0 addresses: [10.0.2.2/24] Security: id: 3 link: enp6s0 addresses: [10.0.3.2/24]
I also need help to configure the Docker Compose YAML for Frigate and Compreface considering that they have to communicate with MQTT and OpenHAB.
