Trying to make my MSI laptop work with virtualization with windows 10, gpu passthrough.
I tried following a couple blog posts on how to install it and a youtube video, I got the virtual machine working but I wasn’t able to change my drivers to Nvidia drivers, windows couldn’t install it.
Here are a couple of logs you’ll need?
dmesg | grep -e DMAR -e IOMMU
[ 0.000000] ACPI: DMAR 0x000000007C7C07E8 0000A8 (v01 INTEL KBL 00000001 INTL 00000001)
[ 0.000000] DMAR: IOMMU enabled
[ 0.004000] DMAR: Host address width 39
[ 0.004000] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[ 0.004000] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 19e2ff0505e
[ 0.004000] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[ 0.004000] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[ 0.004000] DMAR: RMRR base: 0x0000007c0e0000 end: 0x0000007c0fffff
[ 0.004000] DMAR: RMRR base: 0x0000007d800000 end: 0x0000007fffffff
[ 0.004000] DMAR-IR: IOAPIC id 2 under DRHD base 0xfed91000 IOMMU 1
[ 0.004000] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[ 0.004000] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[ 0.004000] DMAR-IR: Enabled IRQ remapping in x2apic mode
[ 0.861661] DMAR: No ATSR found
[ 0.861694] DMAR: dmar0: Using Queued invalidation
[ 0.861811] DMAR: dmar1: Using Queued invalidation
[ 0.861939] DMAR: Setting RMRR:
[ 0.861989] DMAR: Setting identity map for device 0000:00:02.0 [0x7d800000 - 0x7fffffff]
[ 0.862032] DMAR: Setting identity map for device 0000:00:14.0 [0x7c0e0000 - 0x7c0fffff]
[ 0.862038] DMAR: Prepare 0-16MiB unity mapping for LPC
[ 0.862072] DMAR: Setting identity map for device 0000:00:1f.0 [0x0 - 0xffffff]
[ 0.862185] DMAR: Intel(R) Virtualization Technology for Directed I/O
dmesg | grep -i vfio
[ 3.483224] VFIO - User Level meta-driver version: 0.3
[ 3.508154] vfio_pci: add [10de:1c8d[ffff:ffff]] class 0x000000/00000000
/etc/default/grub
GRUB_DEFAULT=0
GRUB_TIMEOUT_STYLE=hidden
GRUB_TIMEOUT=0
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash intel_iommu=on"
GRUB_CMDLINE_LINUX=""
/etc/modprobe.d/vfio.conf
options vfio-pci ids=10de:1c8d
lspci -nn | grep -i nvidia
01:00.0 3D controller [0302]: NVIDIA Corporation GP107M [GeForce GTX 1050 Mobile] [10de:1c8d] (rev a1)
/etc/modprobe.d/blacklist-nouveau.conf
blacklist nouveau
options nouveau modeset=0
virsh edit win (/tmp/virshIVIlsw.xml)
<domain type='kvm'>
<name>win</name>
<uuid>6d0aecf0-3fd8-4c02-bd48-e9c22a8e0398</uuid>
<memory unit='KiB'>8388608</memory>
<currentMemory unit='KiB'>8388608</currentMemory>
<vcpu placement='static' current='1'>8</vcpu>
<os>
<type arch='x86_64' machine='pc-q35-2.11'>hvm</type>
<loader readonly='yes' type='pflash'>/usr/share/OVMF/OVMF_CODE.fd</loader>
<nvram>/var/lib/libvirt/qemu/nvram/win_VARS.fd</nvram>
<bootmenu enable='yes'/>
</os>
<features>
<acpi/>
<apic/>
<hyperv>
<relaxed state='on'/>
<vapic state='on'/>
<spinlocks state='on' retries='8191'/>
<vendor_id state='on' value='whatever'/>
</hyperv>
<kvm>
<hidden state='on'/>
</kvm>
<vmport state='off'/>
</features>
<cpu mode='host-model' check='partial'>
<model fallback='allow'/>
<topology sockets='1' cores='4' threads='2'/>
</cpu>
<clock offset='localtime'>
<timer name='rtc' tickpolicy='catchup'/>
<timer name='pit' tickpolicy='delay'/>
<timer name='hpet' present='no'/>
<timer name='hypervclock' present='yes'/>
</clock>
<on_poweroff>destroy</on_poweroff>
<on_reboot>restart</on_reboot>
<on_crash>destroy</on_crash>
<pm>
<suspend-to-mem enabled='no'/>
<suspend-to-disk enabled='no'/>
</pm>
<devices>
<emulator>/usr/bin/kvm-spice</emulator>
<disk type='file' device='cdrom'>
<driver name='qemu' type='raw'/>
<source file='/home/meyilmaz/Downloads/Win10_1809Oct_v2_EnglishInternational_x64.iso'/>
<target dev='sda' bus='sata'/>
<readonly/>
<boot order='1'/>
<address type='drive' controller='0' bus='0' target='0' unit='0'/>
</disk>
<source file='/home/meyilmaz/Downloads/virtio-win-0.1.141.iso'/>
<target dev='sdb' bus='sata'/>
<readonly/>
<address type='drive' controller='0' bus='0' target='0' unit='1'/>
</disk>
<disk type='file' device='disk'>
<driver name='qemu' type='qcow2' cache='writeback'/>
<source file='/mnt/sdc1/Windows 10/win10.qcow2'/>
<target dev='vda' bus='virtio'/>
<boot order='2'/>
<address type='pci' domain='0x0000' bus='0x04' slot='0x00' function='0x0'/>
</disk>
<controller type='usb' index='0' model='ich9-ehci1'>
<address type='pci' domain='0x0000' bus='0x00' slot='0x1d' function='0x7'/>
</controller>
<controller type='usb' index='0' model='ich9-uhci1'>
<master startport='0'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x1d' function='0x0' multifunction='on'/>
</controller>
<controller type='usb' index='0' model='ich9-uhci2'>
<master startport='2'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x1d' function='0x1'/>
</controller>
<controller type='usb' index='0' model='ich9-uhci3'>
<master startport='4'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x1d' function='0x2'/>
</controller>
<controller type='sata' index='0'>
<address type='pci' domain='0x0000' bus='0x00' slot='0x1f' function='0x2'/>
</controller>
<controller type='pci' index='0' model='pcie-root'/>
<controller type='pci' index='1' model='pcie-root-port'>
<model name='pcie-root-port'/>
<target chassis='1' port='0x8'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x0' multifunction='on'/>
</controller>
<controller type='pci' index='2' model='dmi-to-pci-bridge'>
<model name='i82801b11-bridge'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x1e' function='0x0'/>
</controller>
<controller type='pci' index='3' model='pci-bridge'>
<model name='pci-bridge'/>
<target chassisNr='3'/>
<address type='pci' domain='0x0000' bus='0x02' slot='0x00' function='0x0'/>
</controller>
<controller type='pci' index='4' model='pcie-root-port'>
<target chassis='4' port='0x9'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x1'/>
</controller>
<controller type='pci' index='5' model='pcie-root-port'>
<target chassis='5' port='0xa'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x2'/>
</controller>
<controller type='pci' index='6' model='pcie-root-port'>
<target chassis='6' port='0xb'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x3'/>
</controller>
<controller type='pci' index='7' model='pcie-root-port'>
<target chassis='7' port='0xc'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x4'/>
</controller>
<interface type='network'>
<mac address='52:54:00:68:d0:80'/>
<source network='default'/>
<model type='virtio'/>
<address type='pci' domain='0x0000' bus='0x01' slot='0x00' function='0x0'/>
</interface>
<input type='mouse' bus='ps2'/>
<input type='keyboard' bus='ps2'/>
<sound model='ich6'>
<address type='pci' domain='0x0000' bus='0x03' slot='0x01' function='0x0'/>
</sound>
<hostdev mode='subsystem' type='usb' managed='yes'>
<source>
<vendor id='0x03f0'/>
<product id='0x304a'/>
</source>
<address type='usb' bus='0' port='1'/>
</hostdev>
<source>
<product id='0x134a'/>
</source>
<address type='usb' bus='0' port='2'/>
</hostdev>
<hostdev mode='subsystem' type='pci' managed='yes'>
<source>
<address domain='0x0000' bus='0x01' slot='0x00' function='0x0'/>
</source>
<address type='pci' domain='0x0000' bus='0x05' slot='0x00' function='0x0'/>
</hostdev>
<memballoon model='virtio'>
<address type='pci' domain='0x0000' bus='0x06' slot='0x00' function='0x0'/>
</memballoon>
</devices>
</domain>
QEMU/KVM:
