upgraded to kernel 5.0.7 with the acs patch
I notice there’s a new bios, 12e out now… wonder if I should try that, or try going back to version 10?
dmesg dmesg.txt (138.4 KB)
lspci -vnnk
00:00.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Root Complex [1022:1450]
Subsystem: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Root Complex [1022:1450]
Flags: fast devsel, NUMA node 0
00:00.2 IOMMU [0806]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) I/O Memory Management Unit [1022:1451]
Subsystem: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) I/O Memory Management Unit [1022:1451]
Flags: fast devsel, IRQ 26, NUMA node 0
Capabilities: [40] Secure device <?>
Capabilities: [64] MSI: Enable+ Count=1/4 Maskable- 64bit+
Capabilities: [74] HyperTransport: MSI Mapping Enable+ Fixed+
00:01.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge [1022:1452]
00:01.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe GPP Bridge [1022:1453] (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 27, NUMA node 0
Bus: primary=00, secondary=01, subordinate=08, sec-latency=0
I/O behind bridge: 00001000-00003fff [size=12K]
Memory behind bridge: d9200000-d98fffff [size=7M]
Prefetchable memory behind bridge: 00000000d2100000-00000000d24fffff [size=4M]
Capabilities: [50] Power Management version 3
Capabilities: [58] Express Root Port (Slot+), MSI 00
Capabilities: [a0] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [c0] Subsystem: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe GPP Bridge [1022:1453]
Capabilities: [c8] HyperTransport: MSI Mapping Enable+ Fixed+
Capabilities: [100] Vendor Specific Information: ID=0001 Rev=1 Len=010 <?>
Capabilities: [270] Secondary PCI Express <?>
Capabilities: [370] L1 PM Substates
Capabilities: [380] Downstream Port Containment
Capabilities: [3c4] Designated Vendor-Specific <?>
Kernel driver in use: pcieport
00:01.2 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe GPP Bridge [1022:1453] (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 28, NUMA node 0
Bus: primary=00, secondary=09, subordinate=09, sec-latency=0
I/O behind bridge: None
Memory behind bridge: d9d00000-d9dfffff [size=1M]
Prefetchable memory behind bridge: None
00:02.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge [1022:1452]
00:03.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge [1022:1452]
00:03.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe GPP Bridge [1022:1453] (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 29, NUMA node 0
Bus: primary=00, secondary=0a, subordinate=0a, sec-latency=0
I/O behind bridge: 00004000-00004fff [size=4K]
Memory behind bridge: d8000000-d90fffff [size=17M]
Prefetchable memory behind bridge: 00000000c0000000-00000000d1ffffff [size=288M]
00:04.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge [1022:1452]
00:07.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge [1022:1452]
00:07.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Internal PCIe GPP Bridge 0 to Bus B [1022:1454] (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 30, NUMA node 0
Bus: primary=00, secondary=0b, subordinate=0b, sec-latency=0
Memory behind bridge: d9900000-d9bfffff [size=3M]
Capabilities: [58] Express Root Port (Slot-), MSI 00
Capabilities: [c0] Subsystem: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Internal PCIe GPP Bridge 0 to Bus B [1022:1454]
00:08.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge [1022:1452]
00:08.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Internal PCIe GPP Bridge 0 to Bus B [1022:1454] (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 32, NUMA node 0
Bus: primary=00, secondary=0c, subordinate=0c, sec-latency=0
Memory behind bridge: d9c00000-d9cfffff [size=1M]
00:14.0 SMBus [0c05]: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller [1022:790b] (rev 59)
Subsystem: Gigabyte Technology Co., Ltd Device [1458:5001]
Flags: 66MHz, medium devsel, NUMA node 0
Kernel modules: i2c_piix4, sp5100_tco
00:14.3 ISA bridge [0601]: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge [1022:790e] (rev 51)
Flags: bus master, 66MHz, medium devsel, latency 0, NUMA node 0
00:18.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 0 [1022:1460]
00:18.1 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 1 [1022:1461]
00:18.2 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 2 [1022:1462]
00:18.3 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 3 [1022:1463]
Kernel driver in use: k10temp
Kernel modules: k10temp
00:18.4 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 4 [1022:1464]
00:18.5 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 5 [1022:1465]
00:18.6 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 6 [1022:1466]
00:18.7 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 7 [1022:1467]
00:19.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 0 [1022:1460]
00:19.1 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 1 [1022:1461]
00:19.2 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 2 [1022:1462]
00:19.3 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 3 [1022:1463]
00:19.4 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 4 [1022:1464]
00:19.5 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 5 [1022:1465]
00:19.6 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 6 [1022:1466]
00:19.7 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 7 [1022:1467]
01:00.0 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] X399 Series Chipset USB 3.1 xHCI Controller [1022:43ba] (rev 02) (prog-if 30 [XHCI])
Subsystem: ASMedia Technology Inc. Device [1b21:1142]
Flags: fast devsel, IRQ 35, NUMA node 0
Memory at d98a0000 (64-bit, non-prefetchable) [size=32K]
Capabilities: [50] MSI: Enable- Count=1/8 Maskable- 64bit+
Capabilities: [68] MSI-X: Enable- Count=8 Masked-
Capabilities: [78] Power Management version 3
Capabilities: [80] Express Legacy Endpoint, MSI 00
Capabilities: [100] Advanced Error Reporting
Capabilities: [200] Secondary PCI Express <?>
Capabilities: [300] Latency Tolerance Reporting
Capabilities: [400] L1 PM Substates
Kernel driver in use: vfio-pci
01:00.1 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] X399 Series Chipset SATA Controller [1022:43b6] (rev 02) (prog-if 01 [AHCI 1.0])
DeviceName: Promontory SATA
Subsystem: ASMedia Technology Inc. Device [1b21:1062]
Flags: bus master, fast devsel, latency 0, IRQ 48, NUMA node 0
Memory at d9880000 (32-bit, non-prefetchable) [size=128K]
Expansion ROM at d9800000 [disabled] [size=512K]
Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit+
Kernel driver in use: ahci
01:00.2 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] X399 Series Chipset PCIe Bridge [1022:43b1] (rev 02) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 34, NUMA node 0
Bus: primary=01, secondary=02, subordinate=08, sec-latency=0
Memory behind bridge: d9200000-d97fffff [size=6M]
Capabilities: [80] Express Upstream Port, MSI 00
Capabilities: [c0] Subsystem: ASMedia Technology Inc. Device [1b21:0201]
02:00.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port [1022:43b4] (rev 02) (prog-if 00 [Normal decode])
DeviceName: Onboard LAN Atheros
Flags: bus master, fast devsel, latency 0, IRQ 36, NUMA node 0
Bus: primary=02, secondary=03, subordinate=03, sec-latency=0
Memory behind bridge: None
Capabilities: [80] Express Downstream Port (Slot+), MSI 00
Capabilities: [c0] Subsystem: ASMedia Technology Inc. Device [1b21:3306]
02:01.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port [1022:43b4] (rev 02) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 38, NUMA node 0
Bus: primary=02, secondary=04, subordinate=04, sec-latency=0
I/O behind bridge: 00003000-00003fff [size=4K]
Memory behind bridge: d9700000-d97fffff [size=1M]
02:02.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port [1022:43b4] (rev 02) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 39, NUMA node 0
Bus: primary=02, secondary=05, subordinate=05, sec-latency=0
Memory behind bridge: d9600000-d96fffff [size=1M]
02:03.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port [1022:43b4] (rev 02) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 41, NUMA node 0
Bus: primary=02, secondary=06, subordinate=06, sec-latency=0
I/O behind bridge: 00002000-00002fff [size=4K]
Memory behind bridge: d9500000-d95fffff [size=1M]
02:04.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port [1022:43b4] (rev 02) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 42, NUMA node 0
Bus: primary=02, secondary=07, subordinate=08, sec-latency=0
I/O behind bridge: 00001000-00001fff [size=4K]
Memory behind bridge: d9200000-d94fffff [size=3M]
04:00.0 Ethernet controller [0200]: Intel Corporation I211 Gigabit Network Connection [8086:1539] (rev 03)
Subsystem: Gigabyte Technology Co., Ltd Device [1458:e000]
Flags: bus master, fast devsel, latency 0, IRQ 37, NUMA node 0
Memory at d9700000 (32-bit, non-prefetchable) [size=128K]
I/O ports at 3000 [size=32]
Memory at d9720000 (32-bit, non-prefetchable) [size=16K]
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
Capabilities: [70] MSI-X: Enable+ Count=5 Masked-
Capabilities: [a0] Express Endpoint, MSI 00
Capabilities: [140] Device Serial Number b4-2e-99-ff-ff-31-7d-2d
Capabilities: [1a0] Transaction Processing Hints
Kernel driver in use: igb
Kernel modules: igb
05:00.0 Network controller [0280]: Intel Corporation Wireless 8265 / 8275 [8086:24fd] (rev 78)
DeviceName: Onboard LAN Realtek
Subsystem: Intel Corporation Dual Band Wireless-AC 8265 [8086:1010]
Flags: fast devsel, IRQ 5, NUMA node 0
[virtual] Memory at d9600000 (64-bit, non-prefetchable) [size=8K]
Capabilities: [c8] Power Management version 3
Capabilities: [d0] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [40] Express Endpoint, MSI 00
Capabilities: [140] Device Serial Number 1c-1b-b5-ff-ff-31-8d-87
Capabilities: [14c] Latency Tolerance Reporting
Capabilities: [154] L1 PM Substates
Kernel modules: iwlwifi
06:00.0 Ethernet controller [0200]: Intel Corporation I211 Gigabit Network Connection [8086:1539] (rev 03)
Flags: bus master, fast devsel, latency 0, IRQ 40, NUMA node 0
Memory at d9500000 (32-bit, non-prefetchable) [size=128K]
I/O ports at 2000 [size=32]
Memory at d9520000 (32-bit, non-prefetchable) [size=16K]
Capabilities: [140] Device Serial Number b4-2e-99-ff-ff-31-7d-2f
Kernel modules: igb
07:00.0 Ethernet controller [0200]: Intel Corporation Ethernet 10G 2P X520 Adapter [8086:154d] (rev 01)
Subsystem: Intel Corporation 10GbE 2P X520 Adapter [8086:7b11]
Flags: bus master, fast devsel, latency 0, IRQ 35, NUMA node 0
Memory at d9380000 (64-bit, non-prefetchable) [size=512K]
I/O ports at 1020 [size=32]
Memory at d9404000 (64-bit, non-prefetchable) [size=16K]
Expansion ROM at d9300000 [disabled] [size=512K]
Capabilities: [70] MSI-X: Enable+ Count=64 Masked-
Capabilities: [e0] Vital Product Data
Capabilities: [140] Device Serial Number 00-00-00-ff-ff-00-00-00
Capabilities: [150] Alternative Routing-ID Interpretation (ARI)
Capabilities: [160] Single Root I/O Virtualization (SR-IOV)
Kernel driver in use: ixgbe
Kernel modules: ixgbe
07:00.1 Ethernet controller [0200]: Intel Corporation Ethernet 10G 2P X520 Adapter [8086:154d] (rev 01)
Memory at d9280000 (64-bit, non-prefetchable) [size=512K]
I/O ports at 1000 [size=32]
Memory at d9400000 (64-bit, non-prefetchable) [size=16K]
Expansion ROM at d9200000 [disabled] [size=512K]
09:00.0 Non-Volatile memory controller [0108]: Silicon Motion, Inc. Device [126f:2262] (rev 03) (prog-if 02 [NVM Express])
Subsystem: Silicon Motion, Inc. Device [126f:2262]
Flags: bus master, fast devsel, latency 0, IRQ 84, NUMA node 0
Memory at d9d00000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [50] MSI: Enable- Count=1/8 Maskable+ 64bit+
Capabilities: [70] Express Endpoint, MSI 00
Capabilities: [b0] MSI-X: Enable+ Count=16 Masked-
Capabilities: [158] Secondary PCI Express <?>
Capabilities: [178] Latency Tolerance Reporting
Capabilities: [180] L1 PM Substates
Kernel driver in use: nvme
Kernel modules: nvme
0a:00.0 VGA compatible controller [0300]: NVIDIA Corporation GP104 [GeForce GTX 1080] [10de:1b80] (rev a1) (prog-if 00 [VGA controller])
Subsystem: ASUSTeK Computer Inc. Device [1043:85aa]
Flags: fast devsel, IRQ 53, NUMA node 0
Memory at d8000000 (32-bit, non-prefetchable) [size=16M]
Memory at c0000000 (64-bit, prefetchable) [size=256M]
Memory at d0000000 (64-bit, prefetchable) [size=32M]
I/O ports at 4000 [size=128]
Expansion ROM at d9000000 [disabled] [size=512K]
Capabilities: [60] Power Management version 3
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Legacy Endpoint, MSI 00
Capabilities: [100] Virtual Channel
Capabilities: [250] Latency Tolerance Reporting
Capabilities: [128] Power Budgeting <?>
Capabilities: [420] Advanced Error Reporting
Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Capabilities: [900] Secondary PCI Express <?>
Kernel modules: nouveau
0a:00.1 Audio device [0403]: NVIDIA Corporation GP104 High Definition Audio Controller [10de:10f0] (rev a1)
Flags: fast devsel, IRQ 54, NUMA node 0
Memory at d9080000 (32-bit, non-prefetchable) [size=16K]
Capabilities: [78] Express Endpoint, MSI 00
Kernel modules: snd_hda_intel
0b:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Zeppelin/Raven/Raven2 PCIe Dummy Function [1022:145a]
Subsystem: Advanced Micro Devices, Inc. [AMD] Zeppelin/Raven/Raven2 PCIe Dummy Function [1022:145a]
Capabilities: [48] Vendor Specific Information: Len=08 <?>
Capabilities: [64] Express Endpoint, MSI 00
0b:00.2 Encryption controller [1080]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Platform Security Processor [1022:1456]
Subsystem: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Platform Security Processor [1022:1456]
Flags: bus master, fast devsel, latency 0, IRQ 238, NUMA node 0
Memory at d9a00000 (32-bit, non-prefetchable) [size=1M]
Memory at d9b00000 (32-bit, non-prefetchable) [size=8K]
Capabilities: [a0] MSI: Enable- Count=1/2 Maskable- 64bit+
Capabilities: [c0] MSI-X: Enable+ Count=2 Masked-
Kernel driver in use: ccp
Kernel modules: ccp
0b:00.3 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Zeppelin USB 3.0 Host controller [1022:145f] (prog-if 30 [XHCI])
Subsystem: Gigabyte Technology Co., Ltd Device [1458:5007]
Flags: bus master, fast devsel, latency 0, IRQ 61, NUMA node 0
Memory at d9900000 (64-bit, non-prefetchable) [size=1M]
Capabilities: [a0] MSI: Enable- Count=1/8 Maskable- 64bit+
Capabilities: [c0] MSI-X: Enable+ Count=8 Masked-
Kernel driver in use: xhci_hcd
0c:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Zeppelin/Renoir PCIe Dummy Function [1022:1455]
Subsystem: Advanced Micro Devices, Inc. [AMD] Zeppelin/Renoir PCIe Dummy Function [1022:1455]
0c:00.2 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] [1022:7901] (rev 51) (prog-if 01 [AHCI 1.0])
DeviceName: DIE0 M.2 SATA
Subsystem: Gigabyte Technology Co., Ltd Device [1458:b002]
Flags: bus master, fast devsel, latency 0, IRQ 50, NUMA node 0
Memory at d9c08000 (32-bit, non-prefetchable) [size=4K]
Capabilities: [a0] MSI: Enable+ Count=1/16 Maskable- 64bit+
Capabilities: [d0] SATA HBA v1.0
0c:00.3 Audio device [0403]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) HD Audio Controller [1022:1457]
DeviceName: Audio Codec ALC1220
Subsystem: Gigabyte Technology Co., Ltd Device [1458:a0c2]
Flags: fast devsel, IRQ 4, NUMA node 0
Memory at d9c00000 (32-bit, non-prefetchable) [disabled] [size=32K]
Capabilities: [a0] MSI: Enable- Count=1/1 Maskable- 64bit+
40:00.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Root Complex [1022:1450]
Flags: fast devsel
40:00.2 IOMMU [0806]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) I/O Memory Management Unit [1022:1451]
Flags: fast devsel
Capabilities: [64] MSI: Enable- Count=1/4 Maskable- 64bit+
40:01.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge [1022:1452]
Flags: fast devsel
40:01.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe GPP Bridge [1022:1453] (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 43
Bus: primary=40, secondary=41, subordinate=41, sec-latency=0
Memory behind bridge: 9ff00000-9fffffff [size=1M]
40:02.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge [1022:1452]
Flags: fast devsel
40:03.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge [1022:1452]
Flags: fast devsel
40:03.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe GPP Bridge [1022:1453] (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 44
Bus: primary=40, secondary=42, subordinate=42, sec-latency=0
I/O behind bridge: 00005000-00005fff [size=4K]
Memory behind bridge: 9fe00000-9fefffff [size=1M]
Prefetchable memory behind bridge: 0000000080000000-000000008fffffff [size=256M]
40:04.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge [1022:1452]
Flags: fast devsel
40:07.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge [1022:1452]
Flags: fast devsel
40:07.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Internal PCIe GPP Bridge 0 to Bus B [1022:1454] (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 45
Bus: primary=40, secondary=43, subordinate=43, sec-latency=0
Memory behind bridge: 9fa00000-9fcfffff [size=3M]
40:08.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge [1022:1452]
Flags: fast devsel
40:08.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Internal PCIe GPP Bridge 0 to Bus B [1022:1454] (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 47
Bus: primary=40, secondary=44, subordinate=44, sec-latency=0
Memory behind bridge: 9fd00000-9fdfffff [size=1M]
41:00.0 Non-Volatile memory controller [0108]: Sandisk Corp WD Black 2018/PC SN720 NVMe SSD [15b7:5002] (prog-if 02 [NVM Express])
Subsystem: Sandisk Corp WD Black 2018/PC SN720 NVMe SSD [15b7:5002]
Flags: bus master, fast devsel, latency 0, IRQ 86, NUMA node 0
Memory at 9ff00000 (64-bit, non-prefetchable) [size=16K]
Memory at 9ff04000 (64-bit, non-prefetchable) [size=256]
Capabilities: [80] Power Management version 3
Capabilities: [90] MSI: Enable- Count=1/32 Maskable- 64bit+
Capabilities: [b0] MSI-X: Enable+ Count=65 Masked-
Capabilities: [c0] Express Endpoint, MSI 00
Capabilities: [150] Device Serial Number 00-00-00-00-00-00-00-00
Capabilities: [1b8] Latency Tolerance Reporting
Capabilities: [300] Secondary PCI Express <?>
Capabilities: [900] L1 PM Substates
42:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Juniper XT [Radeon HD 5770] [1002:68b8] (prog-if 00 [VGA controller])
Subsystem: Hightech Information System Ltd. Device [1787:200a]
Flags: bus master, fast devsel, latency 0, IRQ 245
Memory at 80000000 (64-bit, prefetchable) [size=256M]
Memory at 9fe20000 (64-bit, non-prefetchable) [size=128K]
I/O ports at 5000 [size=256]
Expansion ROM at 000c0000 [disabled] [size=128K]
Capabilities: [58] Express Legacy Endpoint, MSI 00
Capabilities: [150] Advanced Error Reporting
Kernel driver in use: radeon
Kernel modules: radeon
42:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Juniper HDMI Audio [Radeon HD 5700 Series] [1002:aa58]
Subsystem: Hightech Information System Ltd. Device [1787:aa58]
Memory at 9fe40000 (64-bit, non-prefetchable) [size=16K]
43:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Zeppelin/Raven/Raven2 PCIe Dummy Function [1022:145a]
Flags: fast devsel
43:00.2 Encryption controller [1080]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Platform Security Processor [1022:1456]
Flags: bus master, fast devsel, latency 0, IRQ 241
Memory at 9fb00000 (32-bit, non-prefetchable) [size=1M]
Memory at 9fc00000 (32-bit, non-prefetchable) [size=8K]
Kernel modules: ccp
43:00.3 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Zeppelin USB 3.0 Host controller [1022:145f] (prog-if 30 [XHCI])
Subsystem: Advanced Micro Devices, Inc. [AMD] Device [1022:145c]
Flags: bus master, fast devsel, latency 0, IRQ 70
Memory at 9fa00000 (64-bit, non-prefetchable) [size=1M]
44:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Zeppelin/Renoir PCIe Dummy Function [1022:1455]
Flags: fast devsel
44:00.2 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] [1022:7901] (rev 51) (prog-if 01 [AHCI 1.0])
Flags: bus master, fast devsel, latency 0, IRQ 52
Memory at 9fd00000 (32-bit, non-prefetchable) [size=4K]
iommu groups, video card in slot 1 not even shown!? it’s a radeon 7750. the gtx 1080 is in slot 4 (2nd full x16 slot)
IOMMU Group 0 00:01.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge [1022:1452]
IOMMU Group 10 00:08.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Internal PCIe GPP Bridge 0 to Bus B [1022:1454]
IOMMU Group 11 00:14.0 SMBus [0c05]: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller [1022:790b] (rev 59)
IOMMU Group 11 00:14.3 ISA bridge [0601]: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge [1022:790e] (rev 51)
IOMMU Group 12 00:18.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 0 [1022:1460]
IOMMU Group 12 00:18.1 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 1 [1022:1461]
IOMMU Group 12 00:18.2 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 2 [1022:1462]
IOMMU Group 12 00:18.3 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 3 [1022:1463]
IOMMU Group 12 00:18.4 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 4 [1022:1464]
IOMMU Group 12 00:18.5 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 5 [1022:1465]
IOMMU Group 12 00:18.6 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 6 [1022:1466]
IOMMU Group 12 00:18.7 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 7 [1022:1467]
IOMMU Group 13 00:19.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 0 [1022:1460]
IOMMU Group 13 00:19.1 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 1 [1022:1461]
IOMMU Group 13 00:19.2 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 2 [1022:1462]
IOMMU Group 13 00:19.3 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 3 [1022:1463]
IOMMU Group 13 00:19.4 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 4 [1022:1464]
IOMMU Group 13 00:19.5 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 5 [1022:1465]
IOMMU Group 13 00:19.6 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 6 [1022:1466]
IOMMU Group 13 00:19.7 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 7 [1022:1467]
IOMMU Group 14 01:00.0 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] X399 Series Chipset USB 3.1 xHCI Controller [1022:43ba] (rev 02)
IOMMU Group 14 01:00.1 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] X399 Series Chipset SATA Controller [1022:43b6] (rev 02)
IOMMU Group 14 01:00.2 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] X399 Series Chipset PCIe Bridge [1022:43b1] (rev 02)
IOMMU Group 14 02:00.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port [1022:43b4] (rev 02)
IOMMU Group 14 02:01.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port [1022:43b4] (rev 02)
IOMMU Group 14 02:02.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port [1022:43b4] (rev 02)
IOMMU Group 14 02:03.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port [1022:43b4] (rev 02)
IOMMU Group 14 02:04.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port [1022:43b4] (rev 02)
IOMMU Group 14 04:00.0 Ethernet controller [0200]: Intel Corporation I211 Gigabit Network Connection [8086:1539] (rev 03)
IOMMU Group 14 05:00.0 Network controller [0280]: Intel Corporation Wireless 8265 / 8275 [8086:24fd] (rev 78)
IOMMU Group 14 06:00.0 Ethernet controller [0200]: Intel Corporation I211 Gigabit Network Connection [8086:1539] (rev 03)
IOMMU Group 14 07:00.0 Ethernet controller [0200]: Intel Corporation Ethernet 10G 2P X520 Adapter [8086:154d] (rev 01)
IOMMU Group 14 07:00.1 Ethernet controller [0200]: Intel Corporation Ethernet 10G 2P X520 Adapter [8086:154d] (rev 01)
IOMMU Group 15 09:00.0 Non-Volatile memory controller [0108]: Silicon Motion, Inc. Device [126f:2262] (rev 03)
IOMMU Group 16 0a:00.0 VGA compatible controller [0300]: NVIDIA Corporation GP104 [GeForce GTX 1080] [10de:1b80] (rev a1)
IOMMU Group 16 0a:00.1 Audio device [0403]: NVIDIA Corporation GP104 High Definition Audio Controller [10de:10f0] (rev a1)
IOMMU Group 17 0b:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Zeppelin/Raven/Raven2 PCIe Dummy Function [1022:145a]
IOMMU Group 17 0b:00.2 Encryption controller [1080]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Platform Security Processor [1022:1456]
IOMMU Group 17 0b:00.3 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Zeppelin USB 3.0 Host controller [1022:145f]
IOMMU Group 18 0c:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Zeppelin/Renoir PCIe Dummy Function [1022:1455]
IOMMU Group 18 0c:00.2 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] [1022:7901] (rev 51)
IOMMU Group 18 0c:00.3 Audio device [0403]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) HD Audio Controller [1022:1457]
IOMMU Group 1 00:01.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe GPP Bridge [1022:1453]
IOMMU Group 2 00:01.2 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe GPP Bridge [1022:1453]
IOMMU Group 3 00:02.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge [1022:1452]
IOMMU Group 4 00:03.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge [1022:1452]
IOMMU Group 5 00:03.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe GPP Bridge [1022:1453]
IOMMU Group 6 00:04.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge [1022:1452]
IOMMU Group 7 00:07.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge [1022:1452]
IOMMU Group 8 00:07.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Internal PCIe GPP Bridge 0 to Bus B [1022:1454]
IOMMU Group 9 00:08.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge [1022:1452]
