Ever since my last post, it has become really clear that considering all my options, the most viable route for me would be to upgrade from my Ryzen 1800X to a Core i9 11900K.
That, of course, necessitates a motherboard change. That, of course, means I have to buy a new one and you know what that means… it needs to avoid the problems my current motherboard has given me. Some of them are…
- Bad IOMMU groups (even with patching the kernel to separate each device into its own group)
- Lack of multiple M.2 NVME expansion slots (I bought an expansion card to mitigate this and my hackintosh threw a fit so now it’s just collecting dust)
- Buggy firmware (I remember trying to boot into Qubes and having to rename the BOOT/EFI/[filename].efi to BOOT/EFI/BOOT64.efi for the BIOS to catch it, also random freezes and hangs when booting between multiple drives and platforms)
- USB-C connector doesn’t cooperate with macOS (this isn’t strictly a motherboard issue, maybe I didn’t figure it out correctly so it probably doesn’t count)
- Dead SATA ports (it’s pretty much stayed in one place for its entire lifecycle and for some reason some ports are dead)
I already own an RX480 so Dortania’s observations on Xe graphics aren’t as big of a deal for me. As this is a sidegrade, it’s just going to replace my CPU and motherboard, everything else remains the same and works with my hackintosh.
I’m looking for a board that can be used to bare-metal hackintosh and also be VFIO-friendly/have good IOMMU groups in case I wish to experiment or try new things down the line.
The following motherboards have been documented to work with Hackintoshes:
- Gigabyte Z590 Vision (G/D) [source]
- Gigabyte Z590 Aorus Elite AX [source]
- Asus Prime Z590 [source]
- MSI Z590 Gaming Carbon WiFi [source]
- ASUS ROG MAXIMUS XIII HERO [source]
That covers the hackintosh part… now about the VFIO friendlines
Any help would be really appreciated! Thanks!
Note: Despite 10th gen’s relative stability to 11th gen when it comes to Hackintoshing, for some reason the processors are priced the same and the boards are more expensive in my local region
