I had previously posted here about how I couldn’t get the GPU to pass through unless I swapped the GPUs to the other slots.
Obviously this wasn’t ideal as the Vega is 2.5 slots and I prefer to also keep slots available.
So I had originally asked Asrock about a possible option to select boot GPU, but they said no and I haven’t seen that on any of their BIOSes (either never seen it, or not seen in years).
However I discovered that by turning the compatibility support module (CSM) off in the BIOS any extra option is unnecessary. Once that option is off, I can boot to the host GPU no matter what slot it is in. (even 1x slot is ok)
The BIOS will remember this. So you setup which GPU is host by unplugging monitors from the other cards. Then after the first boot you can plug them back in. The BIOS screen will still only show on the host GPU card.
However by doing this, some initialization will still happen on the VEGA, (can see monitor light come on even though black screen) and the passthrough was broken. I had even tried supplying the BIOS manually to the GPU, but it still did not work.
After updating Qemu to 2.12 (along with the related libvirt and virt-manager packages) using this PPA and using kernel 4.19 RC1 the problem is now gone.
In addition the VEGA reset issues now appear to be fixed for good, compared to Kernel 4.17 where I still had them.
Here is my current setup example for reference. I have in this example how to do the Qemu command line from the XML so that you can enable the ioh3420 option to prevent crashes on AMD driver install. I need to do another driver install before knowing 100% that this fixes it but I believe it does so far. I also show the Ryzen CPU pinning to pass through just the physical cores of the 1600x. Also this example shows the actual CPU model getting passed through, so it says Ryzen now instead of EPYC in the VM. Finally I have working Hugepages shown here. You must add the hugepages to the xml or it will not use it and you will waste RAM.
Also I pass through the mobo audio and 4 of the USB3 ports perfectly fine.
To re-iterate this is on the Asrock X370 Pro Gaming with BIOS 4.64.
https://www.asrock.com/MB/AMD/Fatal1ty%20X370%20Professional%20Gaming/index.asp
The USB and Audio passthrough setup works perfectly. Now that VEGA reset issue is fixed I can start the VM and the connected devices (game controllers, mouse/keyboard, etc) perfectly pass through to the VM. On VM shutdown the devices work fine on the host again automatically (no restarting needed, audio can automatically switch on host after few sec). Then I can restart the VM whenever.
The USB ports that get passed through from this one controller are the 2 next to the PS2 port and the 2 underneath the 1gb ethernet. The other ports are all in the other controller, and crowded grouping.
Here is the config snippet minus storage and extra controllers.
Note that when I moved the host gpu from the 8x slot to a 1x slot, the IOMMU groupings moved around. The numbers for the audio or usb changed. If I re-populate the 8x slot with something else the groupings will change again, so I would need to change the device in virt-manager to get the USB/audio working again.
<domain type='kvm' xmlns:qemu='http://libvirt.org/schemas/domain/qemu/1.0'>
<name>win7</name>
<uuid>07d336e7-eb30-4c63-a520-576389a73442</uuid>
<memory unit='KiB'>16777216</memory>
<currentMemory unit='KiB'>16777216</currentMemory>
<memoryBacking>
<hugepages/>
</memoryBacking>
<vcpu placement='static'>6</vcpu>
<cputune>
<vcpupin vcpu='0' cpuset='0'/>
<vcpupin vcpu='1' cpuset='2'/>
<vcpupin vcpu='2' cpuset='4'/>
<vcpupin vcpu='3' cpuset='6'/>
<vcpupin vcpu='4' cpuset='8'/>
<vcpupin vcpu='5' cpuset='10'/>
<vcpusched vcpus='0' scheduler='fifo' priority='1'/>
<vcpusched vcpus='1' scheduler='fifo' priority='1'/>
<vcpusched vcpus='2' scheduler='fifo' priority='1'/>
<vcpusched vcpus='3' scheduler='fifo' priority='1'/>
<vcpusched vcpus='4' scheduler='fifo' priority='1'/>
<vcpusched vcpus='5' scheduler='fifo' priority='1'/>
</cputune>
<os>
<type arch='x86_64' machine='pc-i440fx-bionic'>hvm</type>
<loader readonly='yes' type='pflash'>/usr/share/OVMF/OVMF_CODE.fd</loader>
<nvram>/var/lib/libvirt/qemu/nvram/win7_VARS.fd</nvram>
<bootmenu enable='no'/>
</os>
<features>
<acpi/>
<apic/>
<vmport state='off'/>
</features>
<cpu mode='host-model' check='partial'>
<model fallback='allow'/>
<topology sockets='1' cores='6' threads='1'/>
<feature policy='disable' name='hypervisor'/>
</cpu>
<clock offset='utc'>
<timer name='rtc' tickpolicy='catchup'/>
<timer name='pit' tickpolicy='delay'/>
<timer name='hpet' present='no'/>
</clock>
<on_poweroff>destroy</on_poweroff>
<on_reboot>restart</on_reboot>
<on_crash>destroy</on_crash>
<pm>
<suspend-to-mem enabled='no'/>
<suspend-to-disk enabled='no'/>
</pm>
<devices>
<emulator>/usr/bin/kvm-spice</emulator>
<controller type='pci' index='0' model='pci-root'/>
<interface type='direct'>
<mac address='52:54:00:be:0e:35'/>
<source dev='enp42s0' mode='bridge'/>
<model type='e1000'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x0a' function='0x0'/>
</interface>
<hostdev mode='subsystem' type='pci' managed='yes'>
<source>
<address domain='0x0000' bus='0x31' slot='0x00' function='0x3'/>
</source>
<address type='pci' domain='0x0000' bus='0x00' slot='0x09' function='0x0'/>
</hostdev>
<source>
<address domain='0x0000' bus='0x2f' slot='0x00' function='0x0'/>
</source>
<rom bar='on' file='/home/bill/VBIOS/Vega10P.rom'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x0d' function='0x0'/>
</hostdev>
<source>
<address domain='0x0000' bus='0x2f' slot='0x00' function='0x1'/>
</source>
<address type='pci' domain='0x0000' bus='0x00' slot='0x0e' function='0x0'/>
</hostdev>
<source>
<address domain='0x0000' bus='0x30' slot='0x00' function='0x3'/>
</source>
<address type='pci' domain='0x0000' bus='0x00' slot='0x08' function='0x0'/>
</hostdev>
<memballoon model='virtio'>
<address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x0'/>
</memballoon>
</devices>
<qemu:commandline>
<qemu:arg value='-device'/>
<qemu:arg value='ioh3420,bus=pci.0,addr=1c.0,multifunction=on,port=1,chassis=1,id=root.1'/>
<qemu:arg value='-cpu'/>
<qemu:arg value='host,kvm=off'/>
</qemu:commandline>
</domain>
